  <title>CAD F&#243;rum : UR14 pro Revit 2015</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : UR14 pro Revit 2015]]></description>
  <pubDate>Mon, 21 Sep 2026 19:26:44 +0000</pubDate>
  <lastBuildDate>Thu, 02 Jun 2016 12:32:56 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=22830</WebWizForums:feedURL>
   <title><![CDATA[UR14 pro Revit 2015 :  A je&#353;t&#283; jeden update pro Revit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=22830&amp;PID=99244&amp;title=ur14-pro-revit-2015#99244</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 22830<br /><strong>Zasláno:</strong> 02.čer.2016 v 12:32<br /><br />A ještě jeden update pro Revit - Update Release 14 (UR14) pro Revit 2015 a Revit LT 2015. Ke stažení opět přes Application Manager, přes Autodesk Accounts nebo zde na stránce Download.<div>&nbsp;</div><div>Přehled oprav:</div><div>&nbsp;</div><div>Autodesk® Revit® Platform 2015 Updates</div><div>&#61623; Improves stability during Sync with Central&gt;Reload Latest when project utilizes Revit Server.*</div><div>&#61623; Corrects an issue which prevented the replacement of an existing project within Revit Server.*</div><div>&#61623; Improves stability when reloading links within work shared projects.*</div><div>Autodesk® Revit® Architecture 2015 Updates</div><div>&#61623; Improves stability during creation of a stair by component when the stair path text type becomes invalid.*</div>]]>
   <pubDate>Thu, 02 Jun 2016 12:32:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=22830&amp;PID=99244&amp;title=ur14-pro-revit-2015#99244</guid>
