  <title>CAD F&#243;rum : Autocad Mechanical 2017</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Autocad Mechanical 2017]]></description>
  <pubDate>Wed, 04 Nov 2026 21:29:56 +0000</pubDate>
  <lastBuildDate>Wed, 07 Dec 2016 15:10:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=23590</WebWizForums:feedURL>
   <title><![CDATA[Autocad Mechanical 2017 : Zasilam printscreen obou pripadu....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101738&amp;title=autocad-mechanical-2017#101738</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=47747">kgrygar</a><br /><strong>Předmět:</strong> 23590<br /><strong>Zasláno:</strong> 07.pro.2016 v 15:10<br /><br />Zasilam printscreen obou pripadu. Nastaveni verikalni polohy (sedy text) v nastaveni se neda jakkoli zmenit. Toto se deje vicemene nahodile, jak program uzna za vhodne. Klasicky AutoCAD nepouzivame, pouze Mechanical (nyni 2017) .<br><br><a href="uploads/47747/Kota_-_zmenitelna_vertikalni_poloha_textu.pdf" target="_blank" rel="nofollow">uploads/47747/Kota_-_zmenitelna_vertikalni_poloha_textu.pdf</a><br><a href="uploads/47747/Kota_-_nezmenitelna_vertikalni_poloha_textu.pdf" target="_blank" rel="nofollow">uploads/47747/Kota_-_nezmenitelna_vertikalni_poloha_textu.pdf</a><br><a href="uploads/47747/Kota_-_nezmenitelna_vertikalni_poloha_textu.pdf" target="_blank" rel="nofollow"></a>]]>
   <pubDate>Wed, 07 Dec 2016 15:10:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101738&amp;title=autocad-mechanical-2017#101738</guid>
   <title><![CDATA[Autocad Mechanical 2017 :  Co hl&#225;s&#237; AutoCAD jako typ objektu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101737&amp;title=autocad-mechanical-2017#101737</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 23590<br /><strong>Zasláno:</strong> 07.pro.2016 v 14:53<br /><br />Co hlásí AutoCAD jako typ objektu (v okně Vlastnosti)? Otočená kóta?<div>Dělá to i v holém AutoCADu? V Mechanicalu je zřejmě vynucení chování podle nastaveného standardu.</div>]]>
   <pubDate>Wed, 07 Dec 2016 14:53:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101737&amp;title=autocad-mechanical-2017#101737</guid>
   <title><![CDATA[Autocad Mechanical 2017 : Dobry den,casto se mi stava, ze...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101729&amp;title=autocad-mechanical-2017#101729</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=47747">kgrygar</a><br /><strong>Předmět:</strong> 23590<br /><strong>Zasláno:</strong> 07.pro.2016 v 13:45<br /><br />Dobry den,<br><br>casto se mi stava, ze po okotovani nelze u nekterych kot manualne nastavit pozici textu ve vertikalnim smeru (nahore, centr, dole, ....) Vyznacuje se to zesednutim textu v moznostech nastaveni textu koty v panelu vlastnosti. Toto se mi opakuje jiz od predchozich verzi AutoCADu. Nyni ve vetsi mire. Je na to nejaky trik nebo lek :-) ?<br><br>Diky za odezvy a pekny den<br>KG<br>]]>
   <pubDate>Wed, 07 Dec 2016 13:45:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23590&amp;PID=101729&amp;title=autocad-mechanical-2017#101729</guid>
