  <title>CAD F&#243;rum : Příkaz SPOJ</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Příkaz SPOJ]]></description>
  <pubDate>Fri, 04 Sep 2026 12:33:03 +0000</pubDate>
  <lastBuildDate>Fri, 10 Feb 2017 13:14:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=23876</WebWizForums:feedURL>
   <title><![CDATA[Příkaz SPOJ : aaa...., to m&#283; nenapadlo, d&#237;ky,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104571&amp;title=prikaz-spoj#104571</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=75873">Čanda</a><br /><strong>Předmět:</strong> 23876<br /><strong>Zasláno:</strong> 10.úno.2017 v 13:14<br /><br />aaa...., to mě nenapadlo, díky, pomohlo to.]]>
   <pubDate>Fri, 10 Feb 2017 13:14:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104571&amp;title=prikaz-spoj#104571</guid>
   <title><![CDATA[Příkaz SPOJ : Zkuste na to FLATTEN. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104570&amp;title=prikaz-spoj#104570</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1045">johny</a><br /><strong>Předmět:</strong> 23876<br /><strong>Zasláno:</strong> 10.úno.2017 v 13:08<br /><br />Zkuste na to FLATTEN.]]>
   <pubDate>Fri, 10 Feb 2017 13:08:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104570&amp;title=prikaz-spoj#104570</guid>
   <title><![CDATA[Příkaz SPOJ : Pros&#237;m o radu, najednou mi p&#345;i...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104569&amp;title=prikaz-spoj#104569</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=75873">Čanda</a><br /><strong>Předmět:</strong> 23876<br /><strong>Zasláno:</strong> 10.úno.2017 v 12:40<br /><br />Prosím o radu, najednou mi při použití příkazu SPOJ pro spojení úsečeky a oblouku vzniká spline místo obyčejné křivky. Oblouk i křivka jsou na výšce 0 a nejedná se o eliptický oblouk. Nejde to nějak nastavit??]]>
   <pubDate>Fri, 10 Feb 2017 12:40:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23876&amp;PID=104569&amp;title=prikaz-spoj#104569</guid>
