  <title>CAD F&#243;rum : Vault 2016.0.5 update</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Data management, PDM/PLM/CDE : Vault 2016.0.5 update]]></description>
  <pubDate>Wed, 30 Sep 2026 02:07:04 +0000</pubDate>
  <lastBuildDate>Wed, 22 Feb 2017 07:44:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=23941</WebWizForums:feedURL>
   <title><![CDATA[Vault 2016.0.5 update :  Byl uveden Update 5 pro Vault...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=23941&amp;PID=104792&amp;title=vault-201605-update#104792</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 23941<br /><strong>Zasláno:</strong> 22.úno.2017 v 07:44<br /><br />Byl uveden Update 5 pro Vault 2016 SP1 - verze Basic, Workgroup i Professional. Obsahuje i předchozí hotfixy uvedené po SP1. Aktualizaci je nutné provést na klientech i na serveru.<div>&nbsp;</div><div>Hotfix: <a href="http://download.autodesk.com/us/support/files/vault_2016_update/2016.0.5.zip" target="_blank" rel="nofollow">http://download.autodesk.com/us/support/files/vault_2016_update/2016.0.5.zip</a></div><div>Readme: <a href="https://knowledge.autodesk.com/sites/default/files/file_downloads/Vault_2016_0_5_readme.html" target="_blank" rel="nofollow">https://knowledge.autodesk.com/sites/default/files/file_downloads/Vault_2016_0_5_readme.html</a></div><div>&nbsp;</div><div>Přehled oprav:</div><div>&nbsp;</div><div><p style="text-align: left; color: rgb0, 0, 0; text-trans: n&#111;ne; text-indent: 0px; letter-spacing: normal; font-family: Verdana; font-size: 13.33px; font-style: normal; font-weight: normal; margin-top: 10pt; margin-bottom: 0px; margin-left: 7px; word-spacing: 0px; white-space: normal; orphans: 2; widows: 2; font-variant-ligatures: normal; font-variant-caps: normal; -webkit-text-stroke-width: 0px;"><u>2016.0.5 Updates</u></p><ol style="text-align: left; color: rgb0, 0, 0; text-trans: n&#111;ne; text-indent: 0px; letter-spacing: normal; font-family: Verdana; font-size: 13.33px; font-style: normal; font-weight: normal; word-spacing: 0px; white-space: normal; orphans: 2; widows: 2; font-variant-ligatures: normal; font-variant-caps: normal; -webkit-text-stroke-width: 0px;"><li>AutoCAD XREFs could not be resolved...</li><ol ="a"><li>When using Copy Design for a parent DWG copied to a new folder without its XREFs.</li><li>When performing a Move for a parent DWG moved to a new folder without its XREFs and additional attachments are created on the parent.</li></ol><li>Performing a Get on an Inventor assembly with substitute parts would sometimes result in a CER.</li><li>When selecting 'Open from Vault' in AutoCAD, the error message "Value cannot be null. Parameter name: path1" is thrown if the working folder is mapped to the root of a drive.</li><li>When mapping file properties with Classification = Standard, properties for files attached to Items were not being updated when performing Assign/Update Item.</li><li>A duplicate file link to an Item could be created when an Assign Item is cancelled and the part is replaced in Vault prior to a second Assign Item.</li><li>After a DTU import of files, items and BOM, some position were missing in the BOM in Vault.</li><li>An enhancement to Project Sync that helps reduce intermittent and unpredictable connectivity behavior during syncs.</li><li>Update to a security patch that address a vulnerability where a specially crafted raster image in a drawing can trigger unauthorized code execution.</li><li>Unable to close Microsoft Excel files when Vault add-in for Excel is installed.</li><li>Resolved an "Index was out of range" error when performing a 'Go To Item'.</li></ol></div>]]>
   <pubDate>Wed, 22 Feb 2017 07:44:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=23941&amp;PID=104792&amp;title=vault-201605-update#104792</guid>
