  <title>CAD F&#243;rum : Aktualizace pro AutoCAD 2016</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Aktualizace pro AutoCAD 2016]]></description>
  <pubDate>Tue, 04 Aug 2026 08:04:43 +0000</pubDate>
  <lastBuildDate>Sat, 29 Apr 2017 09:51:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=24278</WebWizForums:feedURL>
   <title><![CDATA[Aktualizace pro AutoCAD 2016 : Byl uvedena aktualizace pro rodinu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=24278&amp;PID=106819&amp;title=aktualizace-pro-autocad-2016#106819</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 24278<br /><strong>Zasláno:</strong> 29.dub.2017 v 09:51<br /><br />Byl uvedena aktualizace pro rodinu AutoCADu 2016 se SP1 - verze 2016.0.10. Update si stáhnete z Desktop App nebo z vašeho účtu Autodesk Account nebo <a href="http://up.autodesk.com/2016/ACD/AutoCAD_2016.0.10_Update_x64.exe" target="_blank" rel="nofollow">zde</a>.<br /><br />Přehled oprav:<br /><br />* Enterprise Single Sign On accounts are signed out when multiple users have the same credentials.<br />* Cloud Rendering URLs are updated to the current https location.<br />* Can initiate the 3dpoly command after undo without crashing.<br />* STEPIMPORT imports the full STEP model in specific cases.<br />* Sheet set publishing to PDF is faster.<br />* F8 Key during an active command no longer freezes AutoCAD in Windows 10<br />* Language switching between Korean and English works after using the move command.<br />* Publish no longer cuts off the borders of A size paper.<br />* Elliptical arcs do not display extra lines when plotting while shaded.<br />* Keynote fields no longer lose the association to a value for editing Xref in place.<br />* Edit block in place no longer crashes when Factory Utilities are loaded.<br />* ECW images no longer display distorted after applying the ATIL update.<br /><br />]]>
   <pubDate>Sat, 29 Apr 2017 09:51:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=24278&amp;PID=106819&amp;title=aktualizace-pro-autocad-2016#106819</guid>
