  <title>CAD F&#243;rum : Revit 2018.0.2</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Revit 2018.0.2]]></description>
  <pubDate>Tue, 22 Sep 2026 20:26:45 +0000</pubDate>
  <lastBuildDate>Wed, 07 Jun 2017 21:37:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=24446</WebWizForums:feedURL>
   <title><![CDATA[Revit 2018.0.2 : U&#382;ivatel&#233; Revitu 2018 si ode dne&#353;ka...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=24446&amp;PID=107316&amp;title=revit-201802#107316</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 24446<br /><strong>Zasláno:</strong> 07.čer.2017 v 21:37<br /><br />Uživatelé Revitu 2018 si ode dneška mohou z Desktop App nebo z Account stáhnout Hotfix 2, tedy aktualizaci na verzi 2018.0.2. Po úspěšné aktualizaci bude Revit hlásit verzi 18.0.2.11 (build 20170525_2315).<br /><br />Opravy:<br /><br />Platform <br />* Annotation <br />- Improved stability when using temporary UI controls in an active viewport on a sheet.<br />- Fixed an issue causing superscript characters to display incorrectly in some Windows OS locales.<br />* Collaboration for Revit <br />- Improved publish operation efficiency and stability by reducing nested link data sets size and removing globally unloaded link data.<br />* Error Handling <br />- Fixed an issue in which an error dialog appeared behind other Revit dialogs and did not behave properly.<br />- Improved stability during startup of Revit.<br />* IFC <br />- Added the ability to link IFC files in cloud-based models used with Collaboration for Revit.<br />* Materials <br />- Corrected behavior of the materials browser when opening for the first time then properties tabs were not expanded.<br />* User Interface <br />- Corrected a grammatical error in the Coordinate System Is Already In Use dialog.<br />- Fixed an issue causing File tab ribbon and AppStore icon to display incorrectly in non-English languages.<br /><br />Architecture <br />* Stair <br />- Improved stability when connecting levels to create Multistory Stair by Monolithic and Precast stair types.<br />- Improved stability when disconnecting a precast/cast-in-place multi-story stair.<br /><br />API <br />- Improved stability when using the API to print or export from modal dialogs.<br />]]>
   <pubDate>Wed, 07 Jun 2017 21:37:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=24446&amp;PID=107316&amp;title=revit-201802#107316</guid>
