  <title>CAD F&#243;rum : Inventor HSM 2018.1 (R2)</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAM, 3D tisk a ReCap : Inventor HSM 2018.1 (R2)]]></description>
  <pubDate>Sat, 03 Oct 2026 11:57:10 +0000</pubDate>
  <lastBuildDate>Mon, 10 Jul 2017 19:56:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=24591</WebWizForums:feedURL>
   <title><![CDATA[Inventor HSM 2018.1 (R2) : Byla uvedena aktualizace Inventoru...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=24591&amp;PID=107736&amp;title=inventor-hsm-20181-r2#107736</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 24591<br /><strong>Zasláno:</strong> 10.čvc.2017 v 19:56<br /><br />Byla uvedena aktualizace Inventoru HSM (Ultimate) 2018 - HSM 2018.1 (R2). Ke stažení je ve vašem účtu Autodesk Account (viz Download).<br /><br />Přehled novinek:<br /><br />Improved turning toolpath preview for ID operations. Toolpath is now shown through the model, and the stock area preview is shown without edges. #6423<br /><br />Added parametric confinement for turning, and removed the old confinement. #2894<br /><br />Added retract height to Profiling and Grooving. #7290<br /><br />Added retract height to turning Face, Part, Single Groove and Chamfer. #7291<br /><br />Added support for embedding pictures in Setup Sheet.<br /><br />Added relevant turning tool information in Setup Sheet.<br /><br />Added support for turning tool preview in Setup Sheet. #2501<br /><br />Added retract height for turning threading. Removed inner and outer radius as they did not affect the generated toolpaths. #4042<br /><br />IdeaStation: Support ability for user to choose which license level (Premium/Ultimate) to use. #7412<br /><br />Added dwell option for the Single Groove opration #7451<br /><br />Allow user to disable toolpath generation on creation/change of an operation. This option can be changed in Inventor HSM options. #6422<br /><br />IdeaStation: Use program name/comment from setup if only operation(s) selected. #7138<br /><br />Fixed wrong stock simulation issue when milling comes after a Turning Thread operation. #7582<br /><br />Simple ordering functionality for Parallel operation is now obeying the setting. #7593<br /><br />Ensure that vertical moves for 2D Contour are generated with Plunge feed. #7512<br /><br />Prevent unnecessary invalidation of operations using rest machining from tool (instead of operations) when re-ordering operations. #7458<br /><br />Fix misspelling in Preserve Order tooltip. #7517<br /><br />Prevent overwriting of all tool parameters just by re-selecting the same tool (with no changes). #7450<br /><br />The Leads on all Finishing Passes parameter in 2D Contour / 2D Pocket is now being obeyed. #1366<br /><br />Fixed wrong start position for bore milling cycle when using conventional milling direction. #7496<br /><br />Avoid text truncation on Product Information button. #7026<br /><br />When copying a pattern containing a drill operation from one document to another, Fusion would crash when attempting to fix the missing selections in the pasted pattern/operations. #7506<br /><br />Custom value specified as size of a turning insert is now being persisted #7443<br /><br />Calculating proper compensation point when selecting ‘Tip tangent’ for inserts without holder. #6742<br /><br />Fix scenario in Inventor 2018 where CAM-specific marking menu would not be shown in simulate command if CAM browser is not active. #7383]]>
   <pubDate>Mon, 10 Jul 2017 19:56:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=24591&amp;PID=107736&amp;title=inventor-hsm-20181-r2#107736</guid>
