  <title>CAD F&#243;rum : Predefinovanie bloku</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : Predefinovanie bloku]]></description>
  <pubDate>Thu, 17 Sep 2026 05:20:55 +0000</pubDate>
  <lastBuildDate>Wed, 10 May 2006 15:47:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2518</WebWizForums:feedURL>
   <title><![CDATA[Predefinovanie bloku : Tak&#382;e rad&#283;ji pou&#382;&#237;t...(command...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=11168&amp;title=predefinovanie-bloku#11168</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 10.kvě.2006 v 15:47<br /><br />Takže raději použít<br>...<br><font face="Tahoma, Arial, Sans serif"><span style="font-weight: bold;">(command&nbsp; "_-insert" VLBL "_PS" MM pause MM MM </span><span style="color: rgb(255, 0, 0); font-weight: bold;">nil</span><span style="font-weight: bold;">)<br>...<br><img src="https://www.cadforum.cz/forum/smileys/smiley25.gif" border="0"><br></span></font>]]>
   <pubDate>Wed, 10 May 2006 15:47:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=11168&amp;title=predefinovanie-bloku#11168</guid>
   <title><![CDATA[Predefinovanie bloku : Jak prost&#233; :-) ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10991&amp;title=predefinovanie-bloku#10991</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=54">Seiner</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 10:56<br /><br />Jak prosté&nbsp; :-)]]>
   <pubDate>Thu, 04 May 2006 10:56:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10991&amp;title=predefinovanie-bloku#10991</guid>
   <title><![CDATA[Predefinovanie bloku : LISP &#382;&#225;dn&#233; ^C^C nezn&#225;, ale shodou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10990&amp;title=predefinovanie-bloku#10990</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 10:53<br /><br />LISP žádné <strong>^C^C</strong> nezná, ale <EM>shodou okolností</EM> je <EM>vámi definovaný</EM> symbol s názvem "^C^C" vyhodnocen jako <strong>nil</strong>, takže to zafunguje :-)]]>
   <pubDate>Thu, 04 May 2006 10:53:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10990&amp;title=predefinovanie-bloku#10990</guid>
   <title><![CDATA[Predefinovanie bloku : Vid&#237;te - to mne nenapadlo. J&#225;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10982&amp;title=predefinovanie-bloku#10982</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=54">Seiner</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 10:09<br /><br />Vidíte - to mne nenapadlo. Já to zkoušel v uvozovkách. ]]>
   <pubDate>Thu, 04 May 2006 10:09:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10982&amp;title=predefinovanie-bloku#10982</guid>
   <title><![CDATA[Predefinovanie bloku : P&#345;&#237;klad: z&#237;sk&#225;n&#237; vkl. bodu ZB(defun...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10980&amp;title=predefinovanie-bloku#10980</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 10:04<br /><br />Příklad: získání vkl. bodu ZB<br><br>(defun C:VLOZ ( / ZB MM)<br>(SETQ MM (GETINT "\nZadejte měřítko pro vkládaný blok:"))<br><span style="font-weight: bold;">(command&nbsp; "_-insert" VLBL "_PS" MM pause MM MM </span><span style="color: rgb(255, 0, 0); font-weight: bold;">^C^C</span><span style="font-weight: bold;">)</span><br>(setq ZB (getvar "lastpoint"))<br>(command "_-insert" VLBL "_PS" MM ZB MM "" "0")<br>(princ)<br>)<br>]]>
   <pubDate>Thu, 04 May 2006 10:04:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10980&amp;title=predefinovanie-bloku#10980</guid>
   <title><![CDATA[Predefinovanie bloku : V lispu? Jak? Pokud to nen&#237; v...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10978&amp;title=predefinovanie-bloku#10978</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=54">Seiner</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 09:49<br /><br /><P>V lispu? Jak? Pokud to není v menu.</P><span style="font-size:10px"><br /><br />Upravil Seiner - 04.kvě.2006 v 09:51</span>]]>
   <pubDate>Thu, 04 May 2006 09:49:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10978&amp;title=predefinovanie-bloku#10978</guid>
   <title><![CDATA[Predefinovanie bloku : J&#225; pro Cancel pou&#382;&#237;v&#225;m^C^C  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10977&amp;title=predefinovanie-bloku#10977</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 04.kvě.2006 v 09:47<br /><br />Já pro <span style="color: rgb(255, 0, 0);">Cancel</span> používám<br><span style="font-weight: bold;">^C^C</span>]]>
   <pubDate>Thu, 04 May 2006 09:47:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10977&amp;title=predefinovanie-bloku#10977</guid>
   <title><![CDATA[Predefinovanie bloku : Volat (command) uvnit&#345; (command)...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10964&amp;title=predefinovanie-bloku#10964</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 03.kvě.2006 v 15:11<br /><br /><P>Volat (command) uvnitř (command) není dobrý nápad. LISP ekvivalent pro "cancel" je <strong>nil</strong>. Tedy:</P><P><table width="99%"><tr><td><pre class="BBcode">(command "_INSERT" (strcat oldBlock "=" newBlock) "_Y" nil)</pre></td></tr></table></P>]]>
   <pubDate>Wed, 03 May 2006 15:11:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10964&amp;title=predefinovanie-bloku#10964</guid>
   <title><![CDATA[Predefinovanie bloku : Tak&#382;e met&#243;dou pokus-omyl+help...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10963&amp;title=predefinovanie-bloku#10963</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=789">Jozef Lovás</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 03.kvě.2006 v 14:26<br /><br /><P>Takže metódou pokus-omyl+help som dospel k fungujúcemu riešeniu:</P><P>(command "_insert" (strcat OldBlock "=" NewBlock) "Y" (command))</P><P>(Volanie command bez parametrov = ESC)</P>]]>
   <pubDate>Wed, 03 May 2006 14:26:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10963&amp;title=predefinovanie-bloku#10963</guid>
   <title><![CDATA[Predefinovanie bloku : M&#225;m vo v&#253;krese cca 15 blokov,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10960&amp;title=predefinovanie-bloku#10960</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=789">Jozef Lovás</a><br /><strong>Předmět:</strong> 2518<br /><strong>Zasláno:</strong> 03.kvě.2006 v 13:53<br /><br /><P>Mám vo výkrese cca 15 blokov, ktoré potrebujem predefinovať novými a tie mám v extra súboroch (dwg). Takýchto výkresov mám asi 10 takže to potrebujem nejak zautomatizovať.</P><P>V príkaze insert sa potrebujem dostať až po potvrdenie či chcem predefinovať existujúci blok, a potom príkaz zrušiť.</P>]]>
   <pubDate>Wed, 03 May 2006 13:53:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2518&amp;PID=10960&amp;title=predefinovanie-bloku#10960</guid>
