  <title>CAD F&#243;rum : klapka plech</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : klapka plech]]></description>
  <pubDate>Sat, 12 Sep 2026 18:15:31 +0000</pubDate>
  <lastBuildDate>Tue, 09 May 2006 10:46:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2544</WebWizForums:feedURL>
   <title><![CDATA[klapka plech : diky, to by slo. VS ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11132&amp;title=klapka-plech#11132</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21">svarc.vl</a><br /><strong>Předmět:</strong> 2544<br /><strong>Zasláno:</strong> 09.kvě.2006 v 10:46<br /><br /><P>diky, to by slo. VS</P>]]>
   <pubDate>Tue, 09 May 2006 10:46:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11132&amp;title=klapka-plech#11132</guid>
   <title><![CDATA[klapka plech : ked uz mate tento nacrt, staci...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11131&amp;title=klapka-plech#11131</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=324">Rumisch</a><br /><strong>Předmět:</strong> 2544<br /><strong>Zasláno:</strong> 09.kvě.2006 v 10:40<br /><br />ked uz mate tento nacrt, staci plech vytiahnut cez konturu, to jest v nactre nadefinovat ciary pre plech a pomocne ciary. Nezabudnut, kde bude plech rozdeleny.]]>
   <pubDate>Tue, 09 May 2006 10:40:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11131&amp;title=klapka-plech#11131</guid>
   <title><![CDATA[klapka plech : jeste vecer jsem uspesnenacrt...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11125&amp;title=klapka-plech#11125</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21">svarc.vl</a><br /><strong>Předmět:</strong> 2544<br /><strong>Zasláno:</strong> 09.kvě.2006 v 09:45<br /><br /><IMG alt=klapka src="http://vsvs.album.cz/klapka/t50c197d1432cea73.jpg" border="0">jeste vecer jsem uspesne&nbsp;nacrt v rovine&nbsp;udelal a odmeril uhel pro ohyb podle bodu co jsem nakreslil v nacrtu, takze uspech-napul. Nepodarilo se mi ohnout plech na obe strany, dovoli mi to ohnout jenom jedno rameno horniho plechu. U&nbsp; druheho ramena to nejde asi pouzivam stejnou osu ohybu. Stejne by to melo asi kreslit tak aby jsem si zadal sirku klapky a pak plech nejak orezal ale nevim jak na to. Je to teda do semestralky, takze jsem takovy samouk. diky VS]]>
   <pubDate>Tue, 09 May 2006 09:45:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11125&amp;title=klapka-plech#11125</guid>
   <title><![CDATA[klapka plech : Poslite skicu. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11121&amp;title=klapka-plech#11121</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=324">Rumisch</a><br /><strong>Předmět:</strong> 2544<br /><strong>Zasláno:</strong> 09.kvě.2006 v 08:00<br /><br />Poslite skicu.]]>
   <pubDate>Tue, 09 May 2006 08:00:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11121&amp;title=klapka-plech#11121</guid>
   <title><![CDATA[klapka plech : dobry den potrebuji vymodelovat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11115&amp;title=klapka-plech#11115</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1324">VSvarc</a><br /><strong>Předmět:</strong> 2544<br /><strong>Zasláno:</strong> 08.kvě.2006 v 23:02<br /><br />dobry den potrebuji vymodelovat klapku na hrideli&nbsp; ohnutim&nbsp;plechu tak ze&nbsp; dam plech nahoru a dolu na hridel a soumerne ohnu aby se setkaly&nbsp; asi takhle &lt;o&gt;.Nevim jak udelat prac rovinu kolno na plech abych mohl nejak definovat ohyb a nakreslit kruznici. diky za kazdou radu&nbsp;<IMG src="http://www.cadforum.cz/forum/smileys/smiley2.gif" border="0">]]>
   <pubDate>Mon, 08 May 2006 23:02:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2544&amp;PID=11115&amp;title=klapka-plech#11115</guid>
