  <title>CAD F&#243;rum : echo</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : echo]]></description>
  <pubDate>Tue, 29 Sep 2026 18:11:35 +0000</pubDate>
  <lastBuildDate>Mon, 19 Jun 2006 14:36:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2570</WebWizForums:feedURL>
   <title><![CDATA[echo : Dobr&#253; den, to nepom&#225;h&#225;? M&#367;&#382;ete...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12308&amp;title=echo#12308</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=95">Vaclav Hryz</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 19.čer.2006 v 14:36<br /><br /><P>Dobrý den,</P><P>to nepomáhá? Můžete mi poslat ten lisp?</P><P>V. Hryz</P>]]>
   <pubDate>Mon, 19 Jun 2006 14:36:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12308&amp;title=echo#12308</guid>
   <title><![CDATA[echo : To j&#225; taky  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12244&amp;title=echo#12244</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 16.čer.2006 v 14:19<br /><br />To já taky&nbsp;<img src="https://www.cadforum.cz/forum/smileys/smiley1.gif" border="0">]]>
   <pubDate>Fri, 16 Jun 2006 14:19:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12244&amp;title=echo#12244</guid>
   <title><![CDATA[echo : Dobr&#253; den, trochu pozd&#283; ale t&#345;eba...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12158&amp;title=echo#12158</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=95">Vaclav Hryz</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 14.čer.2006 v 12:38<br /><br /><P>Dobrý den,</P><P>trochu pozdě ale třeba pomůže. Na konec lispu dávám (princ)...</P><P>V. Hryz</P>]]>
   <pubDate>Wed, 14 Jun 2006 12:38:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=12158&amp;title=echo#12158</guid>
   <title><![CDATA[echo :   ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11822&amp;title=echo#11822</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 05.čer.2006 v 15:45<br /><br /><img src="https://www.cadforum.cz/forum/smileys/smiley25.gif" border="0">]]>
   <pubDate>Mon, 05 Jun 2006 15:45:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11822&amp;title=echo#11822</guid>
   <title><![CDATA[echo : Ani jedno nen&#237; ono - po&#345;&#225;d to...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11303&amp;title=echo#11303</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 15.kvě.2006 v 18:27<br /><br />Ani jedno není ono - pořád to hlásí. Na <span style="color: rgb(255, 0, 0);">Nomutt</span>(=1) vůbec nereaguje...]]>
   <pubDate>Mon, 15 May 2006 18:27:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11303&amp;title=echo#11303</guid>
   <title><![CDATA[echo : Zkusil bych nastavit hodnotu EXPERT....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11292&amp;title=echo#11292</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 15.kvě.2006 v 17:43<br /><br />Zkusil bych nastavit hodnotu EXPERT. Pokud nepomůže, tak vypnout veškeré projevy pomocí NOMUTT. Viz:<BR><A href="http://www.cadforum.cz/cadforum/qaID.asp?tip=234" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=234</A>]]>
   <pubDate>Mon, 15 May 2006 17:43:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11292&amp;title=echo#11292</guid>
   <title><![CDATA[echo : Nemohu naj&#237;t n&#283;jak&#253; typ pro potla&#269;en&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11291&amp;title=echo#11291</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2570<br /><strong>Zasláno:</strong> 15.kvě.2006 v 17:34<br /><br />Nemohu najít nějaký typ pro potlačení hlášek na příkazovém řádku.<br>Nemyslím <span style="color: rgb(255, 0, 0);">cmdecho</span>, to mám <span style="font-weight: bold;">0</span>.<br>Potřebuji, aby po skončení lispovské procedury tam nebyla hláska&nbsp; (např.):<br><span style="font-style: italic; font-weight: bold;">1 block deleted.<br></span>]]>
   <pubDate>Mon, 15 May 2006 17:34:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2570&amp;PID=11291&amp;title=echo#11291</guid>
