  <title>CAD F&#243;rum : Hotfix AutoCAD 2019.0.1</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Hotfix AutoCAD 2019.0.1]]></description>
  <pubDate>Wed, 02 Sep 2026 06:19:29 +0000</pubDate>
  <lastBuildDate>Thu, 19 Apr 2018 11:00:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=25952</WebWizForums:feedURL>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 : Nov&#253; Service Pack to vyrie&#353;il...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111281&amp;title=hotfix-autocad-201901#111281</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 19.dub.2018 v 11:00<br /><br /><p>Nový Service Pack to vyriešil obmedzením zoomovania (<span lang="EN-GB" style='color: rgb31, 56, 100; font-family: "Arial",sans-serif; font-size: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-: EN-GB; mso-fareast-: EN-US; mso-bidi-: AR-SA;'>Cannot zoom further while a command is active)</span></p><div>a už mi to teda nepadá ani pri zapnutej High quality geometry.</div>]]>
   <pubDate>Thu, 19 Apr 2018 11:00:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111281&amp;title=hotfix-autocad-201901#111281</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 : Naviac pomohlo vypn&#250;&#357; High quality...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111215&amp;title=hotfix-autocad-201901#111215</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 16.dub.2018 v 09:59<br /><br /><p>Naviac pomohlo vypnúť High quality geometry.</p>]]>
   <pubDate>Mon, 16 Apr 2018 09:59:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111215&amp;title=hotfix-autocad-201901#111215</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 :  Tak som op&#228;&#357; zapla HW akceler&#225;ciu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111201&amp;title=hotfix-autocad-201901#111201</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 13.dub.2018 v 13:16<br /><br />Tak som opäť zapla HW akceleráciu graf. karty a skrátila som&nbsp;cestu pre XRefy, a zatiaľ to pri "kritických" operáciách nespadlo. Ak spadne určite sa ozvem.<div>V predchádzajúcich verziách AutoCADu&nbsp;sme problém s dĺžkou cesty už párkrát mali a presunutie súborov (skrátenie cesty), prípadne zmena názvu pomohli.</div><div>Niektorí subdodávatelia projektových častí si proste nedajú povedať.</div><div>Pred pár rokmi koloval mailom článok ako IT správca "šťavnato"&nbsp;nadával na ekonómky, že&nbsp;dokážu nazvať súbor:</div><div>"Zápis z dnešnej&nbsp;porady konanej&nbsp;dňa XX.XX.XXXX.doc"</div><div>&nbsp;žiaľ sa to stalo "zlozvykom" aj&nbsp;v odbornej technickej obci :(</div>]]>
   <pubDate>Fri, 13 Apr 2018 13:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111201&amp;title=hotfix-autocad-201901#111201</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 :  Vypla som graf. akceler&#225;ciu,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111194&amp;title=hotfix-autocad-201901#111194</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 13.dub.2018 v 11:09<br /><br />Vypla som graf. akceleráciu, ale bolo to nepoužiteľné, t.j. tak pomalé, že to ani nestihlo spadnúť :)<div>&nbsp;</div>(HP ZBook 15 G4 model Y6K27EA#BCM&nbsp;/ W10 64b)]]>
   <pubDate>Fri, 13 Apr 2018 11:09:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111194&amp;title=hotfix-autocad-201901#111194</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 :  Probl&#233;my p&#345;i rychl&#253;ch zoomech...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111193&amp;title=hotfix-autocad-201901#111193</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 13.dub.2018 v 09:18<br /><br />Problémy při rychlých zoomech bývají spíš způsobeny grafikou, popř. driverem myši. Zkuste na chvíli vypnout grafickou akceleraci.]]>
   <pubDate>Fri, 13 Apr 2018 09:18:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111193&amp;title=hotfix-autocad-201901#111193</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 :  V&#269;era mi padal AutoCAD 2019...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111192&amp;title=hotfix-autocad-201901#111192</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 13.dub.2018 v 08:23<br /><br />Včera mi padal AutoCAD 2019 (súčasť Electrical) pri zoomovaní pomocou otáčania stredného tlačítka myši. (Keď som zoomovala ZOOM-&gt;Window / bolo všetko OK)<div>Podľa mňa to bolo spôsobené množstvom pripojených XRef, ale čo vidím pravdepodobnejšie, že 2 z Xref-ov mali dlhú cestu. (Skúsim to ešte dnes odskúšať).</div><div>Stretli ste sa niekto s tým? Ďakujem za odpoveď.</div><div>&nbsp;</div><div>Inak som s AutoCAD 2019 zatiaľ veľmi spokojná:</div><div>- Zrýchlilo sa značne prekresľovanie súborov s objemnými XRefmi</div><div>- Import&nbsp;PDF (s prevodom na objekty AutoCADu)&nbsp;je mnohokrát rýchlejší</div>]]>
   <pubDate>Fri, 13 Apr 2018 08:23:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111192&amp;title=hotfix-autocad-201901#111192</guid>
   <title><![CDATA[Hotfix AutoCAD 2019.0.1 : Byl uveden prvn&#237; hotfix pro rodinu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111191&amp;title=hotfix-autocad-201901#111191</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 25952<br /><strong>Zasláno:</strong> 13.dub.2018 v 06:47<br /><br />Byl uveden první hotfix pro rodinu AutoCAD 2019. Ke stažení je v Desktop App a v Autodesk Account.<br /><br />Opravy:<br /><br />Obecné<br />* K občasným selháním programu při načítání částečných souborů CUIX po obnovení nastavení na výchozí hodnotu již nedochází. <br /><br />Zobrazit<br />* Pořadí bloků se při vkládání některých speciálních výkresů zobrazuje správně. <br /><br />Úpravy<br />* Jedním stisknutím klávesy Tab je možné při kreslení lomené čáry úspěšně přepnout z možnosti Plná vzdálenost na možnost Úhel.<br /><br />Obecné<br />* Tlačítka Otevřít/Uložit na web na panelu nástrojů Rychlý přístup je možné správně skrýt. (pouze 64bitová verze) <br />* Víceřádkový příkaz TEXT nyní umí vytvářet šikmé zlomky bez úvodní mezery. <br />* Změna cesty k paletě nástrojů v dialogu Možnosti se po kliknutí na tlačítko Zavřít nebo Použít správně uloží. <br />]]>
   <pubDate>Fri, 13 Apr 2018 06:47:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=25952&amp;PID=111191&amp;title=hotfix-autocad-201901#111191</guid>
