  <title>CAD F&#243;rum : Array</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Array]]></description>
  <pubDate>Sat, 31 Oct 2026 04:36:25 +0000</pubDate>
  <lastBuildDate>Tue, 22 May 2018 14:21:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=26131</WebWizForums:feedURL>
   <title><![CDATA[Array :  MOveCOpyROtate v jednom pr&#237;kaze....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111623&amp;title=array#111623</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 26131<br /><strong>Zasláno:</strong> 22.kvě.2018 v 14:21<br /><br />MOveCOpyROtate v jednom príkaze. Mne celkom slúži.]]>
   <pubDate>Tue, 22 May 2018 14:21:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111623&amp;title=array#111623</guid>
   <title><![CDATA[Array :  Sk&#250;ste, &#269;i V&#225;m sta&#269;&#237; pr&#237;kaz...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111622&amp;title=array#111622</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 26131<br /><strong>Zasláno:</strong> 22.kvě.2018 v 14:20<br /><br />Skúste, či Vám stačí príkaz MOCORO]]>
   <pubDate>Tue, 22 May 2018 14:20:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111622&amp;title=array#111622</guid>
   <title><![CDATA[Array :  Array je pravideln&#233; pravo&#250;hl&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111596&amp;title=array#111596</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 26131<br /><strong>Zasláno:</strong> 18.kvě.2018 v 10:41<br /><br />Array je pravidelné pravoúhlé nebo radiální pole, s pravidelnými rozestupy. Pokud chcete rozestupy odlišné, musí se prvky nakopírovat ručně nebo nějakým způsobem parametricky - např. LISP utilitou.]]>
   <pubDate>Fri, 18 May 2018 10:41:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111596&amp;title=array#111596</guid>
   <title><![CDATA[Array : Chcel by som sa op&#253;ta&#357; &#269;i existuje...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111593&amp;title=array#111593</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=66291">PNCibiku</a><br /><strong>Předmět:</strong> 26131<br /><strong>Zasláno:</strong> 18.kvě.2018 v 10:14<br /><br />Chcel by som sa opýtať či existuje taká funkcia array - kde sa ale zadávajú rôzne hodnoty, napr.&nbsp;<div><br></div><div>array ako taký funguje, že kopíruje do stĺpcov alebo do riadkov len jeden zadaný rozmer. Ja by som to potreboval využiť v kopírovaní základného objektu/čiary ale boli by tam rôzne rozmery 150, 356, 1000 a pod... lebo takto vždy musím znova označiť-spustiť príkaz-zadať hodnotu...&nbsp;</div><div><br></div><div>ďakujem</div>]]>
   <pubDate>Fri, 18 May 2018 10:14:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=26131&amp;PID=111593&amp;title=array#111593</guid>
