  <title>CAD F&#243;rum : Problém vkladania blokov</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : Problém vkladania blokov]]></description>
  <pubDate>Wed, 30 Sep 2026 03:19:23 +0000</pubDate>
  <lastBuildDate>Thu, 15 Jun 2006 17:16:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2708</WebWizForums:feedURL>
   <title><![CDATA[Problém vkladania blokov :   Tu je definicia bloku &amp;#0...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12207&amp;title=problem-vkladania-blokov#12207</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1389">Statik</a><br /><strong>Předmět:</strong> 2708<br /><strong>Zasláno:</strong> 15.čer.2006 v 17:16<br /><br />Tu je definicia bloku<br><br><table width="99%"><tr><td><pre class="BBcode"><br>"---------------------------------------"<br>"TLACIM DEFINICIU BLOKU: $BV-PP"<br>"---------------------------------------"<br>((-1 . &lt;Entity name: 400790f0&gt;) (0 . "BLOCK") (330 . &lt;Entity name: 400790e8&gt;) <br>(5 . "1FE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockBegin") <br>(70 . 2) (10 0.0 0.0 0.0) (-2 . &lt;Entity name: 400790f8&gt;) (2 . "$BV-PP") (1 . <br>"$BV-PP"))<br>((-1 . &lt;Entity name: 400790f8&gt;) (0 . "LINE") (330 . &lt;Entity name: 400790e8&gt;) (5 <br>. "1FF") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 0) (100 . "AcDbLine") <br>(10 0.0 0.0 0.0) (11 1.0 0.0 0.0) (210 0.0 0.0 1.0))<br>((-1 . &lt;Entity name: 40079100&gt;) (0 . "ATTDEF") (330 . &lt;Entity name: 400790e8&gt;) <br>(5 . "200") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 31) (100 . <br>"AcDbText") (10 0.0 0.0 0.0) (40 . 50.0) (1 . "") (50 . 1.5708) (41 . 1.0) (51 <br>. 0.0) (7 . "STANDARD") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) <br>(100 . "AcDbAttributeDefinition") (3 . "Za&#232;iatok") (2 . "ZNS") (70 . 8) (73 . <br>0) (74 . 0))<br>((-1 . &lt;Entity name: 40079108&gt;) (0 . "ATTDEF") (330 . &lt;Entity name: 400790e8&gt;) <br>(5 . "201") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 31) (100 . <br>"AcDbText") (10 1.0 0.0 0.0) (40 . 50.0) (1 . "") (50 . 0.0) (41 . 1.0) (51 . <br>0.0) (7 . "STANDARD") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 <br>. "AcDbAttributeDefinition") (3 . "Koniec") (2 . "ZNE") (70 . 8) (73 . 0) (74 . <br>0))<br></pre></td></tr></table><br><br><br>kod 70 - hodnota 8<br><br>8 = Attribute is preset (no prompt during insertion) -&gt; Je prednastaveny, nie je vyzva pocas vkladania<br><br>ale tie atributy sa fyzicky nedostanu do databazy.<br>V Rel 14 mi to bezi bez problémov skoro 8 rokov<br><span style="font-size:10px"><br /><br />Upravil Statik - 15.čer.2006 v 17:19</span>]]>
   <pubDate>Thu, 15 Jun 2006 17:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12207&amp;title=problem-vkladania-blokov#12207</guid>
   <title><![CDATA[Problém vkladania blokov : Ty atributy jsou nastaveny na...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12203&amp;title=problem-vkladania-blokov#12203</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 2708<br /><strong>Zasláno:</strong> 15.čer.2006 v 16:36<br /><br />Ty atributy jsou nastaveny na <span style="font-style: italic;">Unvisible</span>? Mají prázdnou přednastavenou hodnotu (pro řádek <span style="font-style: italic;">Default</span>)?]]>
   <pubDate>Thu, 15 Jun 2006 16:36:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12203&amp;title=problem-vkladania-blokov#12203</guid>
   <title><![CDATA[Problém vkladania blokov : Dobr&#253; de&#328;M&#225;m spraven&#233; programy...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12178&amp;title=problem-vkladania-blokov#12178</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1389">Statik</a><br /><strong>Předmět:</strong> 2708<br /><strong>Zasláno:</strong> 15.čer.2006 v 08:26<br /><br />Dobrý deň<br><br>Mám spravené programy v LISP pre vkladanie výstuže v pohľade, pôdoryse, reze a pod...<br>LISPY boli robené pre R14 po prechode na R2002 je lispy potrebné upraviť, čo robím priebežne počas prechodu.<br><br>Z jedným problémom si však neviem rady:<br><br>Mám nadefinovaný blok pozostávajúci z 3 entít<br>1.LINE<br>2.ATRIBUTE (na zaciatku LINE)<br>3.ATRIBUTE (na konci LINE)<br><br>ATRIBUTE sú vlastne koncové značky, ktoré zobrazujú začiatok a koniec výstuže (prepínaju sa programovo podľa potreby)<br><br>Mám nasledovný problém:<br><span style="font-style: italic;">(Poznámka Blok sa vkladá do výkresu s nerovnakými mierkami X Y Z</span><br style="font-style: italic;"><span style="font-style: italic;">X je vzdy rozne od 1 radovo do 12000, Y=1 a Z = 1)</span><br><br>1/ Keď vkladám blok ručne príkazom INSERT všetko je v poriadku<br><br>2/ Keď vkladám blok ručne príkazom MINSERT (viacnásobné vloženie), blok sa vloží aj s atribútmi, ktoré sa dajú potom ručne editovať, ale majú nekorektnú mierku vloženia a niektoré ďaľšie parametre, ale ručne sa to dá editovať a napraviť.<br>Pozri obrázok 1<br>&nbsp;<a href="http://img46.imagevenue.com/img.php?loc=loc151&amp;image=52049_Obr1.jpg" target="_blank"><img src="http://img46.imagevenue.com/loc151/th_52049_Obr1.jpg" border="0"></a><br><br><br>3/ Keď vkladám ten istý blok programovo žiadne atribúty vo výkresovej databáze neexistujú<br>Pozri obrázok 2<br>&nbsp;<a href="http://img44.imagevenue.com/img.php?loc=loc117&amp;image=52055_Obr2.jpg" target="_blank"><img src="http://img44.imagevenue.com/loc117/th_52055_Obr2.jpg" border="0"></a><br><br>V rel 14 to všetko funguje perfektre.<br><br>Ešte poznámky:<br>1/ Keď otvorím výkres R14 blok je zo značkami, existujúce bloky sa dajú programovo editovať (cez entmod)<br>2/ akonahle ho programovo vložím už atribúty neexistujú<br><br>Programove vkladanie bloku je nasledovne:<br>1/ pomocou funkcie (command "INSERT" .....) sa vlozi blok pricom sa vsetky vyzvi programovo potvrdia<br><br>2/ potom sa pristupi k bloku a edituju sa pomocu ENTMOD<br>a/ mierka bloku - X (kluc 41 entity INSERT)<br>b/ hodnota atributu 1 (kluc 2 entity ATTRIB)<br>c/ hodnota atributu 2 (kluc 2 entity ATTRIB)<br><br>Nevie mi prosím niekto poradiť ? (nemal podobný problém ?)<br>]]>
   <pubDate>Thu, 15 Jun 2006 08:26:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2708&amp;PID=12178&amp;title=problem-vkladania-blokov#12178</guid>
