  <title>CAD F&#243;rum : Binding xrefs pri exportu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Architecture, MEP, Fabrication, Plant 3D : Binding xrefs pri exportu]]></description>
  <pubDate>Sun, 11 Oct 2026 07:18:28 +0000</pubDate>
  <lastBuildDate>Wed, 12 Jul 2006 15:24:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2822</WebWizForums:feedURL>
   <title><![CDATA[Binding xrefs pri exportu : V tom samem vykresu jako minule...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2822&amp;PID=12744&amp;title=binding-xrefs-pri-exportu#12744</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 2822<br /><strong>Zasláno:</strong> 12.čvc.2006 v 15:24<br /><br /><DIV>V tom samem vykresu jako minule mi adt hrozí:</DIV><DIV>Binding Xref "A3-07E-b"...</DIV><DIV>&nbsp;</DIV><DIV>** Xref-Bind operation on scaled Xref with unequal units. **<BR>** Results may not be as  expected.&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;&nbsp;&nbsp; **</DIV><DIV>&nbsp;</DIV><DIV>Binding Xref "A3-07W-b"...</DIV><DIV>&nbsp;</DIV><DIV>** Xref-Bind operation on scaled Xref with unequal units. **<BR>** Results may not be as  expected.&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;&nbsp;&nbsp; **</DIV><DIV>&nbsp;</DIV><DIV>list toho xrefu je:</DIV><DIV>BLOCK REFERENCE&nbsp; Layer: "A-Koty"<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;  Space: Model space<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;  Handle = 16b8<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Block Name: "A3-07W-b"<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;  External reference<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; at point, X= 0.000000&nbsp; Y= 0.000000&nbsp; Z= 0.000000<BR>&nbsp;&nbsp; X scale factor: 1000.000000<BR>&nbsp;&nbsp; Y scale factor: 1000.000000<BR>&nbsp;&nbsp; rotation angle:&nbsp;&nbsp; 0.00<BR>&nbsp;&nbsp; Z scale factor: 1000.000000<BR>&nbsp; Scale uniformly: No<BR>&nbsp; Allow exploding: Yes</DIV><DIV>&nbsp;</DIV><DIV>ten scale 1000 je tam kvuli jednotkam (m-mm) a dělá si je adt samo. Proč se mu ten xref nelíbí?</DIV>]]>
   <pubDate>Wed, 12 Jul 2006 15:24:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2822&amp;PID=12744&amp;title=binding-xrefs-pri-exportu#12744</guid>
