  <title>CAD F&#243;rum : Script ssget = 0</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Script ssget = 0]]></description>
  <pubDate>Wed, 04 Nov 2026 00:18:43 +0000</pubDate>
  <lastBuildDate>Mon, 02 Sep 2019 08:25:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=29313</WebWizForums:feedURL>
   <title><![CDATA[Script ssget = 0 : jj d&#237;ky ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117436&amp;title=script-ssget-0#117436</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=428">MILKA</a><br /><strong>Předmět:</strong> 29313<br /><strong>Zasláno:</strong> 02.zář.2019 v 08:25<br /><br />jj díky<br>]]>
   <pubDate>Mon, 02 Sep 2019 08:25:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117436&amp;title=script-ssget-0#117436</guid>
   <title><![CDATA[Script ssget = 0 :  To je &#250;pln&#283; stejn&#233;:(setq a (ssget...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117435&amp;title=script-ssget-0#117435</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=99">pavelstyl</a><br /><strong>Předmět:</strong> 29313<br /><strong>Zasláno:</strong> 01.zář.2019 v 16:30<br /><br />To je úplně stejné:<div>&nbsp;</div><div><div>(setq a (ssget "X" (list (cons&nbsp;8 "nejaka_hladina") ) ) )<br>(if a (command "_erase" a "")) </div><div>&nbsp;</div><div>Pavel Š.</div></div>]]>
   <pubDate>Sun, 01 Sep 2019 16:30:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117435&amp;title=script-ssget-0#117435</guid>
   <title><![CDATA[Script ssget = 0 : D&#237;ky, funguje to.Nemohl by jste...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117433&amp;title=script-ssget-0#117433</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=428">MILKA</a><br /><strong>Předmět:</strong> 29313<br /><strong>Zasláno:</strong> 30.srp.2019 v 15:24<br /><br /><div>Díky, funguje to.</div><div><br></div><div>Nemohl by jste mi to samé předhodit pro výběr hladiny ?<br></div><div>něco jako (sssetfirst nil (ssget "_X" '((8 . "název_hladiny"))))<br></div><div><br></div><div><br></div>]]>
   <pubDate>Fri, 30 Aug 2019 15:24:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117433&amp;title=script-ssget-0#117433</guid>
   <title><![CDATA[Script ssget = 0 :  J&#225; pou&#382;&#237;v&#225;m n&#283;co takov&#233;ho(setq...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117422&amp;title=script-ssget-0#117422</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=99">pavelstyl</a><br /><strong>Předmět:</strong> 29313<br /><strong>Zasláno:</strong> 30.srp.2019 v 10:03<br /><br />Já používám něco takového<div></div><div>(setq a (ssget "X" (list (cons 0 "POINT") ) ) )<br>(if a (command "_erase" a "")) </div><div>&nbsp;</div><div>Pavel Š.</div>]]>
   <pubDate>Fri, 30 Aug 2019 10:03:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117422&amp;title=script-ssget-0#117422</guid>
   <title><![CDATA[Script ssget = 0 : Zdrav&#237;m,pro automatizaci &#269;i&#353;t&#283;n&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117421&amp;title=script-ssget-0#117421</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=428">MILKA</a><br /><strong>Předmět:</strong> 29313<br /><strong>Zasláno:</strong> 30.srp.2019 v 09:26<br /><br /><div>Zdravím,</div><div><br></div><div>pro automatizaci čištění dxf souborů mám vytvořen script s několika řádky </div><div> kde se odmazávají body a některé hladiny např.:</div><div><br></div><div>(sssetfirst nil (ssget "_X" '((0 . "POINT"))))<br>_erase</div><div><br></div><div><br></div><div>Může mi někdo poradit, jak se má zapsat, aby "erase" vykonal pouze v případě</div><div>že nejaké entity nalezne ? (v opačném by měl script pokračovat na další řádek)</div><div><br></div><div>Díky<br></div>]]>
   <pubDate>Fri, 30 Aug 2019 09:26:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29313&amp;PID=117421&amp;title=script-ssget-0#117421</guid>
