  <title>CAD F&#243;rum : PocketPC / PDA</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Obecn&#283; o oboru CAD (CAx a BIM) : PocketPC / PDA]]></description>
  <pubDate>Sat, 10 Oct 2026 11:19:20 +0000</pubDate>
  <lastBuildDate>Fri, 18 Aug 2006 10:53:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2952</WebWizForums:feedURL>
   <title><![CDATA[PocketPC / PDA : http://www.cadsofttools.com/en...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13543&amp;title=pocketpc-pda#13543</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1225">Pipa</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 18.srp.2006 v 10:53<br /><br /> http://www.cadsofttools.com/en/products/pocket_pc_cad_viewer .html<br /><br />je to jen prohlížeč DWG/DXF s možností konverze do bmp]]>
   <pubDate>Fri, 18 Aug 2006 10:53:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13543&amp;title=pocketpc-pda#13543</guid>
   <title><![CDATA[PocketPC / PDA : Na http://www.pocketpc.cz/appdetail.php?id=1582...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13542&amp;title=pocketpc-pda#13542</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=13">Jan Rais</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 18.srp.2006 v 10:46<br /><br />Na http://www.pocketpc.cz/appdetail.php?id=1582 je <span ="REQ-d">Freeware p</span><span ="DESC">rohlížeč formátu DXF.</span>]]>
   <pubDate>Fri, 18 Aug 2006 10:46:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13542&amp;title=pocketpc-pda#13542</guid>
   <title><![CDATA[PocketPC / PDA : U kreslen&#237; asi budete v&#253;razn&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13467&amp;title=pocketpc-pda#13467</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 15.srp.2006 v 08:23<br /><br />U kreslení asi budete výrazně omezen uživatelským rozhraním PocketPC, ale na prohlížení popř. připomínkování CAD dat PDA použít lze. Namísto DWG (kde budou obtíže s objemem dat a custom objekty) je asi lepší lehčí CAD formát - DWF.]]>
   <pubDate>Tue, 15 Aug 2006 08:23:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13467&amp;title=pocketpc-pda#13467</guid>
   <title><![CDATA[PocketPC / PDA : zkousen powercad, vectorcad, cecad...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13465&amp;title=pocketpc-pda#13465</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=58">Rostislav Říha</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 15.srp.2006 v 07:56<br /><br />zkousen powercad, vectorcad, cecad - vsechny maji svuj "protikus" na PC, ktery vykresy konvertuje, ani jeden neumi prevest vykresy, ktere obsahuji chytre (desktop) entity...]]>
   <pubDate>Tue, 15 Aug 2006 07:56:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13465&amp;title=pocketpc-pda#13465</guid>
   <title><![CDATA[PocketPC / PDA : &#352;lo mi jen o doporu&#269;en&#237; n&#283;jak&#233;ho...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13458&amp;title=pocketpc-pda#13458</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 14.srp.2006 v 19:41<br /><br />Šlo mi jen o doporučení nějakého odzkoušeneného mini-prohlížeče. Je mi jasné, že LCD a 19" ani notebook to nenahradi ;)]]>
   <pubDate>Mon, 14 Aug 2006 19:41:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13458&amp;title=pocketpc-pda#13458</guid>
   <title><![CDATA[PocketPC / PDA : zkusenost je takova, ze programu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13457&amp;title=pocketpc-pda#13457</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=58">Rostislav Říha</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 14.srp.2006 v 19:33<br /><br />zkusenost je takova, ze programu je povicero, umi i dwg (zkuste hledat treba na pocketgearu), ale prakticka vyuzitelnost se blizi nule, protoze vzdy je nakonec jednodussi rozklapnout notebook...]]>
   <pubDate>Mon, 14 Aug 2006 19:33:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13457&amp;title=pocketpc-pda#13457</guid>
   <title><![CDATA[PocketPC / PDA : Nevim jestli je to presne co hledate...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13447&amp;title=pocketpc-pda#13447</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1495">czidla</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 14.srp.2006 v 09:24<br /><br />Nevim jestli je to presne co hledate a uz to pry neni v prodeji ale zkuste se podivat na Autodesk&nbsp;OnSite Enterprise treba na:  http://south-apac.autodesk.com/adsk/servlet/index?siteID=115 7326&amp;id=1922337]]>
   <pubDate>Mon, 14 Aug 2006 09:24:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13447&amp;title=pocketpc-pda#13447</guid>
   <title><![CDATA[PocketPC / PDA : Dobr&#253; den, r&#225;d bych se zeptal...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13443&amp;title=pocketpc-pda#13443</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 2952<br /><strong>Zasláno:</strong> 13.srp.2006 v 17:32<br /><br /><DIV>Dobrý den, rád bych se zeptal zda má někdo zkušenosti s prohlížením&nbsp; a kreslením (nějakých náčrtků) na Windows Mobile 5, popř. prosím o doporuručení vhodných aplikací.</DIV><DIV>&nbsp;</DIV><DIV>Předem díky za informace</DIV>]]>
   <pubDate>Sun, 13 Aug 2006 17:32:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2952&amp;PID=13443&amp;title=pocketpc-pda#13443</guid>
