  <title>CAD F&#243;rum : Export z civilu do hec rasu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Civil 3D, Map, InfraWorks, GIS : Export z civilu do hec rasu]]></description>
  <pubDate>Fri, 09 Oct 2026 23:50:04 +0000</pubDate>
  <lastBuildDate>Tue, 03 Dec 2019 14:36:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=29739</WebWizForums:feedURL>
   <title><![CDATA[Export z civilu do hec rasu : Moc d&#283;kuji za rady ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118432&amp;title=export-z-civilu-do-hec-rasu#118432</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=89330">JosefLudik91</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 14:36<br /><br />Moc děkuji za rady]]>
   <pubDate>Tue, 03 Dec 2019 14:36:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118432&amp;title=export-z-civilu-do-hec-rasu#118432</guid>
   <title><![CDATA[Export z civilu do hec rasu : Expert :-) D&#283;kuji. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118431&amp;title=export-z-civilu-do-hec-rasu#118431</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=29643">Jan Jirásek</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 13:19<br /><br />Expert :-) Děkuji.]]>
   <pubDate>Tue, 03 Dec 2019 13:19:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118431&amp;title=export-z-civilu-do-hec-rasu#118431</guid>
   <title><![CDATA[Export z civilu do hec rasu : Dobr&#253; den,potvzuji &#250;sp&#283;&#353;n&#253; export...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118429&amp;title=export-z-civilu-do-hec-rasu#118429</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=3054">martinfolber</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 13:13<br /><br />Dobrý den,<div>potvzuji úspěšný export do HEC-RASu a děkuji kolegovi Jiráskovi za podrobný návod...:) Má s tím přece jako expert vodař zkušenosti. Jenom připomínám možnosti Civilu, že umíme "zrcadlit" jak PP tak i příčné řezy.</div>]]>
   <pubDate>Tue, 03 Dec 2019 13:13:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118429&amp;title=export-z-civilu-do-hec-rasu#118429</guid>
   <title><![CDATA[Export z civilu do hec rasu : Zdrav&#237;m,co se t&#253;&#269;e exportu, tak...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118428&amp;title=export-z-civilu-do-hec-rasu#118428</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=29643">Jan Jirásek</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 12:53<br /><br />Zdravím,<div><br></div><div>co se týče exportu, tak jsem na žádný problém nenarazil. V dialogovém okně si mohu vybrat jak povrch, tak trasu a příslušné SPR. Otázkou je, zda problémy s exportem na vašem PC mohou mít příčinu ve studentské verzi Civilu. Tohle by Vám asi řekli kolegové z CAD Studia.<div><br></div><div>Dovolím si přidat pár rad (kolega Folbr doufám promine).</div></div><div><br></div><div>1. Na orientaci osy a její staničení, jak je prezentována ve videu, viz odkaz výše, zapomeňte. To není správná cesta ... Vždy si připravte dvě totožné osy položené na sobě. Jedna z nich je "klasickou" osou pro výkresovou dokumentaci a druhá je určená právě pro export do HEC-RASu (ta pak není samozřejmě viditelná). První z nich má staničení ve směru proti vodě a druhá PO VODĚ! Každá z tras má ve STEJNÉM MÍSTĚ situované SPR (díky opačným směrům budou odlišná staničení, ale toto se vyřeší v dalších krocích). Pokud nebudete takto postupovat, tak budete mít špatně vykreslené podélné profily (tedy ne zleva doprava, ale opačně). Jo a mějte vždy řezy na začátku a na konci tras, jinak vám to bude při importu zpět do Civilu zlobit.</div><div><br></div><div>2. Vyhněte se na trase obloukům, s nimi i HEC nepracuje.&nbsp;</div><div><br></div><div>3. Při importu geo souboru do HEC-RASu postupujte dle tohoto návodu:</div><div><br></div><div><a href="http://tomsthird.blogspot.com/2016/01/simplest-method-to-export-geometry-from.html" target="_blank" rel="nofollow">http://tomsthird.blogspot.com/2016/01/simplest-method-to-export-geometry-from.html</a></div><div><br></div><div>Na 3. obrázku je uveden převod staničení v excelu, pokud nebudete mít začátek staničení v 0, tak v uvedeném vzorci =0,181-A1 je nutné přičíst koncové staničení.</div><div><br></div><div>4. Trasa i SPR musejí být uvnitř povrchu (ve vašich výkresech řezy přesahují). Vyhnete se tak problémům v HEC-RASu.</div><div><br></div><div>5. Křivky levého a pravého břehu musejí být delší než je trasa (jinak vám bude chybět označení v HECu) a musejí mít stejný směr jako trasa (shora dolů).</div><div><br></div><div>6. S importem SDF souboru do Civilu mám špatné zkušenosti; řeším to importem psaného profilu (do trasy té první "klasické").</div><div><br></div><div>J.</div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 03 Dec 2019 12:53:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118428&amp;title=export-z-civilu-do-hec-rasu#118428</guid>
   <title><![CDATA[Export z civilu do hec rasu : https://drive.google.com/open?...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118427&amp;title=export-z-civilu-do-hec-rasu#118427</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=89330">JosefLudik91</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 10:56<br /><br /><a href="https://drive.google.com/open?id=1XcKiEePa6IzXovEE7OiXW34klCaqND35" target="_blank" rel="nofollow">https://drive.google.com/open?id=1XcKiEePa6IzXovEE7OiXW34klCaqND35</a><div><br></div><div>U všech je stejný problém, stopy aj trasa snad ok. A přitom se mi to už kdysi podařilo&nbsp;</div>]]>
   <pubDate>Tue, 03 Dec 2019 10:56:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118427&amp;title=export-z-civilu-do-hec-rasu#118427</guid>
   <title><![CDATA[Export z civilu do hec rasu : Zdrav&#237;m, staveni&#353;t&#283; b&#253;t nemus&#237;,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118425&amp;title=export-z-civilu-do-hec-rasu#118425</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=29643">Jan Jirásek</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 08:56<br /><br />Zdravím, staveniště být nemusí, mám vyzkoušeno ... Podíval bych se ještě na trasu a stopy, zda nejsou někde mimo povrch nebo zda není v povrchu "díra" ...]]>
   <pubDate>Tue, 03 Dec 2019 08:56:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118425&amp;title=export-z-civilu-do-hec-rasu#118425</guid>
   <title><![CDATA[Export z civilu do hec rasu : Dobr&#253; den, mus&#237;te m&#237;t vytvo&#345;en&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118421&amp;title=export-z-civilu-do-hec-rasu#118421</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=3054">martinfolber</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 03.pro.2019 v 08:21<br /><br />Dobrý den, musíte mít vytvořené stopy příčných řezů a (myslím) být ještě ve staveništi. viz můj článek na blogu&nbsp;<a href="https://www.civil3d.cz/2010/03/hec-ras-export-z-c3d.html" target="_blank" rel="nofollow">https://www.civil3d.cz/2010/03/hec-ras-export-z-c3d.html</a>]]>
   <pubDate>Tue, 03 Dec 2019 08:21:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118421&amp;title=export-z-civilu-do-hec-rasu#118421</guid>
   <title><![CDATA[Export z civilu do hec rasu : Zdrav&#237;m, pr&#225;v&#283; jsem to vyzkou&#353;el...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118419&amp;title=export-z-civilu-do-hec-rasu#118419</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=29643">Jan Jirásek</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 02.pro.2019 v 20:45<br /><br />Zdravím, právě jsem to vyzkoušel v Civilu 2020 a zde to funguje. Možná byste měl problém více popsat nebo přiložit předmětný výkres. J.]]>
   <pubDate>Mon, 02 Dec 2019 20:45:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118419&amp;title=export-z-civilu-do-hec-rasu#118419</guid>
   <title><![CDATA[Export z civilu do hec rasu : Dobry den,m&#225; tady n&#283;kdo zku&#353;enosti...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118413&amp;title=export-z-civilu-do-hec-rasu#118413</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=89330">JosefLudik91</a><br /><strong>Předmět:</strong> 29739<br /><strong>Zasláno:</strong> 02.pro.2019 v 17:53<br /><br />Dobry den,&nbsp;<div>má tady někdo zkušenosti s exportem dat z civilu do hec rasu?&nbsp;</div><div>Po kliknutí na ikonku export se v dialogovém okně nezobrazuje vytvořený povrch ani trasa.</div><div>Děkuji za odpovědi&nbsp;&nbsp;</div><span style="font-size:10px"><br /><br />Upravil JosefLudik91 - 03.pro.2019 v 10:52</span>]]>
   <pubDate>Mon, 02 Dec 2019 17:53:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29739&amp;PID=118413&amp;title=export-z-civilu-do-hec-rasu#118413</guid>
