  <title>CAD F&#243;rum : Aktualizace AutoCAD for Mac 2020.1.2</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Aktualizace AutoCAD for Mac 2020.1.2]]></description>
  <pubDate>Tue, 08 Sep 2026 11:53:11 +0000</pubDate>
  <lastBuildDate>Fri, 17 Jan 2020 16:43:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=29920</WebWizForums:feedURL>
   <title><![CDATA[Aktualizace AutoCAD for Mac 2020.1.2 : Byla vyd&#225;na aktualizace pro AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=29920&amp;PID=118883&amp;title=aktualizace-autocad-for-mac-202012#118883</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 29920<br /><strong>Zasláno:</strong> 17.led.2020 v 16:43<br /><br />Byla vydána aktualizace pro AutoCAD a AutoCAD LT for Mac 2020.1.2. Ke stažení je na Autodesk Account nebo v Desktop App.<div><br></div><div>Přehled oprav:</div><div><br></div><div><ul style="font-size: medium;"><li>Xref cannot be snapped or selected in some drawings.</li><li>Customized plot style path reverts to default when restart AutoCAD.</li><li>Color dependent plot style shows blank if the ctb file name contains non-English characters.</li><li>Sometimes crashes when open/close drawings.</li><li>Sometimes crashes when run CUI command.</li><li>Sometimes properties of block objects missing.</li><li>Sometimes recently used blocks does not show in the block palette.</li><li>Sometimes hangs when open some special drawings.</li><li>Sometimes crashes when work on drawings with PDF underlay.</li><li>Removes unnecessary 3rd party modules.</li></ul></div>]]>
   <pubDate>Fri, 17 Jan 2020 16:43:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=29920&amp;PID=118883&amp;title=aktualizace-autocad-for-mac-202012#118883</guid>
