  <title>CAD F&#243;rum : Uveden hotfix Revit 2020.2.2</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Uveden hotfix Revit 2020.2.2]]></description>
  <pubDate>Tue, 22 Sep 2026 02:21:24 +0000</pubDate>
  <lastBuildDate>Thu, 07 May 2020 21:57:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=30487</WebWizForums:feedURL>
   <title><![CDATA[Uveden hotfix Revit 2020.2.2 : Byla vyd&#225;na aktualizace 2020.2.2...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=30487&amp;PID=120222&amp;title=uveden-hotfix-revit-202022#120222</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 30487<br /><strong>Zasláno:</strong> 07.kvě.2020 v 21:57<br /><br />Byla vydána aktualizace 2020.2.2 pro Revit a Revit LT (2020). Ke stažení na Autodesk Account nebo v Desktop App.<div><br></div><div>Novinky a opravy:</div><div><br></div><div><div ="_" id="-"><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Software embedded in the update executable:</th></tr></t><t><tr><td>Revit 2020 - version 20.2.20.31</td></tr><tr><td>Autodesk Cloud Models for Revit 2020 - version 20.2.20.31</td></tr><tr><td>Personal Accelerator for Revit - version 21.0.11.0</td></tr><tr><td>OpenStudio - version 0.1.9</td></tr></t></table></div><h2 id="issues-resolved">Issues Resolved</h2><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Annotation - Dimensions</th></tr></t><t><tr><td>Fixed an issue when upgrading a model with an incorrect dimension leader style.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Beams, Braces</th></tr></t><t><tr><td>Fixed an issue that structural framing elements might be incorrect for cloud rendering.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Fabrication - MEP</th></tr></t><t><tr><td>Fixed an issue that could lead to product instability when dragging to connect open ends of inline fittings.</td></tr><tr><td>Fixed an issue with the Optimized Straights feature which was occasionally incorrectly altering the length option from Auto to Value.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Family Editor</th></tr></t><t><tr><td>Improved stability when using Create Similar with certain families.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">File Open/Save Internals</th></tr></t><t><tr><td>Improved stability when saving a family file from a cloud model after changing the Maximum backups in File Save Options dialog.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Floor</th></tr></t><t><tr><td>Improved stability when orbiting or editing elements in a 3D view.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">gbXML</th></tr></t><t><tr><td>Fixed an issue that caused exterior wall surfaces to be assigned to a space without a spaceIdRef when exported to gbXML.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Import/Export Other</th></tr></t><t><tr><td>Updated Revit to use FBX Toolkit version 2020.0.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Licensing</th></tr></t><t><tr><td>Fixed an issue which caused Revit to become unresponsive.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Link Topography</th></tr></t><t><tr><td>Fixed an issue where coordinates were changed when the linked topography was reloaded.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">MEP Other</th></tr></t><t><tr><td>Improved stability when editing a family that had been corrupted.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">MEP Pipe</th></tr></t><t><tr><td>Fixed an issue that caused instability when switching views while editing a pipe's diameter.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Reinforcement - Shape Driven Rebar</th></tr></t><t><tr><td>Improved stability when upgrading a Revit project containing rebar.</td></tr><tr><td>Improved stability when editing rebar constraints.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Revit Home</th></tr></t><t><tr><td>Fixed an issue where the name of the local copy instead central model was displayed on the Recent Files page.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Startup/Shutdown</th></tr></t><t><tr><td>Removed potential security vulnerability.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">User Interface</th></tr></t><t><tr><td>When an unrecoverable error happens, a clear link from Revit to the self-service support page is provided.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">View - Analysis Visualization</th></tr></t><t><tr><td>Improved the performance of the display of Analysis Visualization entities when more than one set of independent results is added to a view simultaneously.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">ViewCube Navigation</th></tr></t><t><tr><td>Improved stability when click on the navigation bar.</td></tr></t></table></div><h2 id="imant-notes">Important Notes</h2><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Dynamo for Revit</th></tr></t><t><tr><td>In some cases Dynamo will not be visible within the Manage tab after 2020.2.2 Hotfix is applied.  To restore Dynamo, replace <a href="http://revit.downloads.autodesk.com//download/2020RVT_RTM/Media/2020_2_2/DynamoRevitDS.sig" target="_blank" rel="nofollow">DynamoRevitDS.sig</a> and <a href="http://revit.downloads.autodesk.com//download/2020RVT_RTM/Media/2020_2_2/DynamoRevitVersi&#111;nSelector.sig" target="_blank" rel="nofollow">DynamoRevitVersionSelector.sig</a> the following location:   C:\Program Files\Autodesk\Revit 2020\Addins\DynamoForRevit\Revit\</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Content</th></tr></t><t><tr><td>Updated Content for Revit 2020.2 is not included in the patch deliverable and is provided on the Autodesk Knowledge Network, <a href="https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/c&#111;ntent/autodesk-revit-20202-c&#111;ntent.html" target="_blank" rel="nofollow">link</a>.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Uninstall</th></tr></t><t><tr><td>Revit updates cannot be uninstalled to revert Autodesk Revit 2020 to its pre-update state. If you need to remove the update, please uninstall Autodesk Revit 2020 and then reinstall it.</td></tr></t></table></div>  </div>    <div ="related-s">      <div ="familys">      <div ="parent">        <strong></strong></div></div></div></div>]]>
   <pubDate>Thu, 07 May 2020 21:57:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=30487&amp;PID=120222&amp;title=uveden-hotfix-revit-202022#120222</guid>
