  <title>CAD F&#243;rum : Hotfix Revit 2020.2.3</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Hotfix Revit 2020.2.3]]></description>
  <pubDate>Thu, 15 Oct 2026 03:39:25 +0000</pubDate>
  <lastBuildDate>Thu, 03 Sep 2020 06:33:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=30962</WebWizForums:feedURL>
   <title><![CDATA[Hotfix Revit 2020.2.3 : Byl uvoln&#283;n hotfix pro Revit 2020...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=30962&amp;PID=121270&amp;title=hotfix-revit-202023#121270</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 30962<br /><strong>Zasláno:</strong> 03.zář.2020 v 06:33<br /><br />Byl uvolněn hotfix pro Revit 2020 a Revit LT 2020. Ke stažení je před Desktop App nebo na Autodesk Account. Opravuje následující chyby.<div><br></div><div><h2 id="issues-resolved">Issues Resolved</h2><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Background Processes</th></tr></t><t><tr><td>Resolved a Windows 7 specific issue where application level macros could cause deletion of non-Revit files.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Duct</th></tr></t><t><tr><td>Fixed an issue that caused instability when placing duct elements created using direct shapes.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Duct/Pipe Display</th></tr></t><t><tr><td>Fixed an issue that prevented offset tags from reporting a value for design duct and pipe fittings.</td></tr><tr><td>Fixed an issue that caused single line vertical pipes and pipe fittings to not display properly beneath pipe accessories.</td></tr><tr><td>Fixed an issue that caused symbolic lines in a family to not display correctly.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Export DWG/DXF</th></tr></t><t><tr><td>Fixed an issue where lines would be missing when exporting certain slightly curved elements to DWG.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Link Topography</th></tr></t><t><tr><td>Fixed an issue where Link Topography didn't work when Windows Region Format is set to use a period as the digit grouping symbol.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">MEP Analytical Systems</th></tr></t><t><tr><td>Fixed a conversion error for the Airflow per area parameter of analytical spaces.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Pipe</th></tr></t><t><tr><td>Fixed an issue that caused instability in Revit when modifying a duct or pipe system.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Project Browser</th></tr></t><t><tr><td>Improved stability when renaming views (and using the delete key) in the Project Browser.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Revit Cloud Model (workshared)</th></tr></t><t><tr><td>Fixed an issue where a Revit Cloud Worksharing link path could incorrectly resolve to the Collaboration Cache directory.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Steel Connections</th></tr></t><t><tr><td>Fixed an issue in which the "Cannot perform this action because calculations for steel elements are in progress" message always appeared when a steel connection was edited from the Type Properties dialog.</td></tr></t></table></div><div ="ui-table-wrap"><table><t><tr><th style="text-align: left;">Upgrade</th></tr></t><t><tr><td>Fixed an issue that upgrading failed for models that contain conduit fittings without connectors.</td></tr></t></table></div><h2 id="imant-notes"></h2></div>]]>
   <pubDate>Thu, 03 Sep 2020 06:33:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=30962&amp;PID=121270&amp;title=hotfix-revit-202023#121270</guid>
