  <title>CAD F&#243;rum : Definice čar</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Definice čar]]></description>
  <pubDate>Mon, 21 Sep 2026 05:43:21 +0000</pubDate>
  <lastBuildDate>Wed, 07 Apr 2021 13:50:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=31821</WebWizForums:feedURL>
   <title><![CDATA[Definice čar : Inventor - objemov&#253; model&#225;&#345; -...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123356&amp;title=definice-car#123356</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=81">vbehun</a><br /><strong>Předmět:</strong> 31821<br /><strong>Zasláno:</strong> 07.dub.2021 v 13:50<br /><br />Inventor - objemový modelář - má trochu jiný pohled na věc ... i když uživatelé se vlastních typů čar dožadují.&nbsp;<div>Tady jsem vyšťoural dotazy na Autodesk (Inventor fórum) - řazeno podle data:<div>---</div><div><div>09-27-2005</div><div><a href="https://forums.autodesk.com/t5/inventor-forum/custom-linetypes/td-p/1443343" target="_blank" rel="nofollow">Inventor Forum - Custom Linetypes</a></div><div>---</div><div>&#8206;08-21-2014&nbsp;</div><div><a href="https://forums.autodesk.com/t5/inventor-ideas/drawings-make-linetype-custom-linetype/idi-p/5226057" target="_blank" rel="nofollow">Idea Board - Drawings : Make Linetype / Custom Linetype</a></div><div>---</div><div>Feb 13 2014</div><div><a href="https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-28F90BD6-0812-4FED-8A54-DAF6361717D3-htm.html" target="_blank" rel="nofollow">Inventor - Sketch Properties reference</a></div><div>---</div><div>&#8206;10-14-2016</div><div>Inventor Forum</div><div><a href="https://forums.autodesk.com/t5/inventor-forum/custom-more-linetypes-in-inventor/td-p/6623509" target="_blank" rel="nofollow">Custom/more linetypes in inventor?</a></div><div>---</div><div>Feb 09 2016</div><div><a href="https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Inventor-Help/files/GUID-42857C7D-600F-4DFC-8FFE-5E4C41D7F492-htm.html" target="_blank" rel="nofollow">Inventor Support and learning - To Load a Line Type (LIN File)</a></div><div>---</div><div><i>Linetype Control</i></div><div><i>Specifies the linetype to apply to newly created sketch geometry or displays the linetype of selected geometry. The default linetype is Continuous.</i></div><div><i>Linetype options are available for selection in the drop-down list. At the bottom of the list, Other opens the Select Line Type dialog box, where you can add linetypes to the list.</i></div><div><i>Note: To load an AutoCAD .lin file, click Load at the bottom of the Select Line Type dialog box. For more information, see Load Line Type (LIN file).</i></div><div>---</div><div><br></div><div>Nov 20 2020</div><div><a href="https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Inventor-Help/files/GUID-33EE57FB-9343-4647-83F0-B737F80B7E9C-htm.html" target="_blank" rel="nofollow">Inventor - About Styles in Drawings</a></div><div>&nbsp;- To Load a Line Type (LIN File)</div><div><br></div><div>Nov 20 2020</div><div><a href="https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Inventor-Help/files/GUID-42857C7D-600F-4DFC-8FFE-5E4C41D7F492-htm.html" target="_blank" rel="nofollow">Inventor - To Load a Line Type (LIN File)</a></div></div><div><br></div><div>---Inventor online help---</div><div><br></div><div><a href="https://knowledge.autodesk.com/support/inventor/downloads/caas/downloads/c&#111;ntent/inventor-2021-&#111;nline-help-and-local-help-page.html" target="_blank" rel="nofollow">Inventor 2021 Online Help and Local Help page</a></div></div><span style="font-size:10px"><br /><br />Upravil vbehun - 07.dub.2021 v 13:53</span>]]>
   <pubDate>Wed, 07 Apr 2021 13:50:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123356&amp;title=definice-car#123356</guid>
   <title><![CDATA[Definice čar : Dobr&#253; den,d&#283;kuji, jenom j&#225; jsem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123349&amp;title=definice-car#123349</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=94724">sucha.ladislava</a><br /><strong>Předmět:</strong> 31821<br /><strong>Zasláno:</strong> 06.dub.2021 v 23:59<br /><br />Dobrý den,<div>děkuji, jenom já jsem potřeboval do Inventoru. Ne AutoCadu :-)</div><div><br></div><div>Děkuji za další pomoc</div>]]>
   <pubDate>Tue, 06 Apr 2021 23:59:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123349&amp;title=definice-car#123349</guid>
   <title><![CDATA[Definice čar : Viz podobn&#253; dotaz zde:Import typ&#367;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123340&amp;title=definice-car#123340</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=81">vbehun</a><br /><strong>Předmět:</strong> 31821<br /><strong>Zasláno:</strong> 06.dub.2021 v 19:04<br /><br />Viz podobný dotaz zde:<div><div><a href="https://www.cadforum.cz/forum/forum_posts.asp?TID=26198">Import typů čar</a></div><div>a také tady:</div><div><a href="http://blog.kdata.cz/cad-software/article/autocad-tvorba-typu-cary-z-prikazove-radky/" target="_blank" rel="nofollow">AutoCAD - tvorba "vlastního typu čáry" z příkazové řádky</a></div><div><a href="http://blog.kdata.cz/cad-software/article/autocad-tvorba-vlastniho-typu-cary-obsahujiciho-tvary-a-text-pomoci-nastroju-z-express-tools/" target="_blank" rel="nofollow">AutoCAD - tvorba "vlastního typu čáry" obsahujícího “tvary” a text pomocí nástrojů z “Express tools”</a></div></div><div><br></div><div>---klávesa F1 (help)---</div><div><br></div><div>Je tady i on-line nápověda:</div><div><div><a href="http://help.autodesk.com/view/ACD/2021/CSY/" target="_blank" rel="nofollow">Hlavní stránka české online nápovědy</a></div><div><a href="http://help.autodesk.com/view/ACD/2021/CSY/?guid=GUID-5A6E6759-8A9A-4A8A-9AEE-EE9DB72F792D" target="_blank" rel="nofollow">Vlastní typy čar a definice typů čar</a></div></div><div></div><div><br></div><div>a dá se nainstalovat také off-line nápověda:</div><div><div><a href="https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Installati&#111;n-AutoCAD/files/GUID-4E2B453C-8F43-4F84-B95B-9ACA97E10568-htm.html" target="_blank" rel="nofollow">How can I obtain local offline Help?</a></div></div><span style="font-size:10px"><br /><br />Upravil vbehun - 06.dub.2021 v 19:26</span>]]>
   <pubDate>Tue, 06 Apr 2021 19:04:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123340&amp;title=definice-car#123340</guid>
   <title><![CDATA[Definice čar : Hezk&#233; velikonoce.Jak se pros&#237;ma)...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123326&amp;title=definice-car#123326</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=94724">sucha.ladislava</a><br /><strong>Předmět:</strong> 31821<br /><strong>Zasláno:</strong> 05.dub.2021 v 17:26<br /><br />Hezké velikonoce.<div>Jak se prosím&nbsp;</div><div>a) definují nové čáry&nbsp;</div><div>b) mění stávající čáry</div><div>c) jak se přenáší na jiné pc (jsou součástí šablony?</div><div><br></div><div>Děkuji</div>]]>
   <pubDate>Mon, 05 Apr 2021 17:26:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31821&amp;PID=123326&amp;title=definice-car#123326</guid>
