  <title>CAD F&#243;rum : Tisk do pdf</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Tisk do pdf]]></description>
  <pubDate>Mon, 19 Oct 2026 09:36:08 +0000</pubDate>
  <lastBuildDate>Fri, 09 Apr 2021 15:35:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=31849</WebWizForums:feedURL>
   <title><![CDATA[Tisk do pdf : D&#283;kuji ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123378&amp;title=tisk-do-pdf#123378</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=105">Kosík</a><br /><strong>Předmět:</strong> 31849<br /><strong>Zasláno:</strong> 09.dub.2021 v 15:35<br /><br />Děkuji]]>
   <pubDate>Fri, 09 Apr 2021 15:35:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123378&amp;title=tisk-do-pdf#123378</guid>
   <title><![CDATA[Tisk do pdf : je to promenn&#225;EPDFSHXviztehttp...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123377&amp;title=tisk-do-pdf#123377</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1753">splonk</a><br /><strong>Předmět:</strong> 31849<br /><strong>Zasláno:</strong> 09.dub.2021 v 14:45<br /><br />je to promenná&nbsp;EPDFSHX<div>vizte&nbsp;<a href="https://www.cadforum.cz/cz/variable.asp?cmd=EPDFSHX">https://www.cadforum.cz/cz/variable.asp?cmd=EPDFSHX</a></div><div><br></div><div>a umí to od 2016 -tak že 2017 to asi umí taky...</div>]]>
   <pubDate>Fri, 09 Apr 2021 14:45:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123377&amp;title=tisk-do-pdf#123377</guid>
   <title><![CDATA[Tisk do pdf : dobry den,Ano, um&#237; to ale mysl&#237;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123376&amp;title=tisk-do-pdf#123376</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1753">splonk</a><br /><strong>Předmět:</strong> 31849<br /><strong>Zasláno:</strong> 09.dub.2021 v 14:43<br /><br />dobry den,<div>Ano, umí to ale myslím si, novější verze Autocadu -&gt; vygeneruji PDFko kde k SHX tetu "zabalí" i text (v PDF je pak vidět jako poznámka) a podle toho ho Acrobat najde... Tvorbu těchto "poznámek" do PDF řídí nejakaka promenná v autocadu...&nbsp; -&gt; zkušenejší poradí</div>]]>
   <pubDate>Fri, 09 Apr 2021 14:43:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123376&amp;title=tisk-do-pdf#123376</guid>
   <title><![CDATA[Tisk do pdf : P&#345;eji p&#345;&#237;jemn&#253; denExistuje n&#283;jak&#225;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123374&amp;title=tisk-do-pdf#123374</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=105">Kosík</a><br /><strong>Předmět:</strong> 31849<br /><strong>Zasláno:</strong> 09.dub.2021 v 14:15<br /><br /><div>Přeji příjemný den</div><div>Existuje nějaká možnost, aby u vytištěného výkresu do pdf bylo možné v acrobat readeru využít funkci na hledání textu.</div><div>Děkuji</div><div>Jan Kosík<br></div>]]>
   <pubDate>Fri, 09 Apr 2021 14:15:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=31849&amp;PID=123374&amp;title=tisk-do-pdf#123374</guid>
