  <title>CAD F&#243;rum : PC pre ACAD2007</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD hardware : PC pre ACAD2007]]></description>
  <pubDate>Wed, 28 Oct 2026 19:18:22 +0000</pubDate>
  <lastBuildDate>Tue, 10 Oct 2006 12:46:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=3218</WebWizForums:feedURL>
   <title><![CDATA[PC pre ACAD2007 : Vie mi teda niekto poradi&#357; model...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14903&amp;title=pc-pre-acad2007#14903</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 12:46<br /><br />Vie mi teda niekto poradiť model HP na A2007 ekvivalentný rýchlosťou opísanému modelu s A2005ou?<DIV>(HDD je 40GB Seagate U-ATA/100, 7200rpm)</DIV><DIV>Rychlosťou zatiaľ stačil, len kapacitne prestáva.</DIV>]]>
   <pubDate>Tue, 10 Oct 2006 12:46:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14903&amp;title=pc-pre-acad2007#14903</guid>
   <title><![CDATA[PC pre ACAD2007 : Na HW asi nie. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14902&amp;title=pc-pre-acad2007#14902</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 12:41<br /><br />Na HW asi nie.]]>
   <pubDate>Tue, 10 Oct 2006 12:41:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14902&amp;title=pc-pre-acad2007#14902</guid>
   <title><![CDATA[PC pre ACAD2007 :   Buba napsal(a):Pr&#225;ve &#382;e som...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14897&amp;title=pc-pre-acad2007#14897</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=58">Rostislav Říha</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 11:25<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Buba" alt="Původně odeslal(a) Buba" style="vertical-align: text-bottom;" /> <strong>Buba napsal(a):</strong><br /><br />Práve že som nepracovala v 2006 ale v 2005. :-(</td></tr></table> to je myslim jedno.]]>
   <pubDate>Tue, 10 Oct 2006 11:25:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14897&amp;title=pc-pre-acad2007#14897</guid>
   <title><![CDATA[PC pre ACAD2007 : Pr&#225;ve &#382;e som nepracovala v 2006...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14896&amp;title=pc-pre-acad2007#14896</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 11:20<br /><br />Práve že som nepracovala v 2006 ale v 2005. :-(]]>
   <pubDate>Tue, 10 Oct 2006 11:20:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14896&amp;title=pc-pre-acad2007#14896</guid>
   <title><![CDATA[PC pre ACAD2007 :   Buba napsal(a):Ob&#225;vam sa, ale...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14890&amp;title=pc-pre-acad2007#14890</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=58">Rostislav Říha</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 10:51<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Buba" alt="Původně odeslal(a) Buba" style="vertical-align: text-bottom;" /> <strong>Buba napsal(a):</strong><br /><br />Obávam sa, ale že keď prejdem na Acad2007, nebude stíhať.</td></tr></table> <OL><LI>rekl bych (a i ruzne recenze to potvrzuji) ze a2007 se vsemi jeho vymozenostmi nebude stihat NIC - proste zapnete nejaky realisticky visual style s vrzenymi stiny a pocitac zdechne:) - at uz je to znacka nebo noname.</LI><LI>Pokud budete ve 2007 kreslit zejm. ve 2D stejne, jako jste pracovala ve 2006ce, tak si asi prechodu ani nevsimnete</LI><LI>Name a noname - nekonecna diskuse:)...par postrehu:</LI><UL><LI>znackove jsou stabilnejsi - acad mene casto spadne.</LI><LI>nejosidnejsi jsou "poloznacky" typu autocont - uznavam, ze jde o subj. nazor, ale je podlozen srovnanim x pocitacu - nakonec se osvedcuje bud koupit znackovou stanici s vedomim, ze bude o neco drazsi, nebo koupit uplny noname od nejakeho kamarada vaseho IT - az Vam bude v kuchyni skladat ctvrte PC, tak uz se to nauci:)...poloznackova PC nam v atelieru zlobi, kuchynske noname mame ctyri a ten posledni je uz fakt dobry:))</LI></UL><LI>Pro 2007ku bych Vas comp vybavil lepsi grafikou, dobrou zkusenost mame s herni nvidii v kombinaci s rivatunerem - viz predch. diskuse tady. Do karty ati bych pro 2007ku nesel...</LI><LI>Nepisete, jak rychly mate disk - to JE dulezite...idealne byste mela mit v pocitaci 2 harddisky - swap by mel byt jinde, nez system...</LI><LI>Mate asi malo RAM - zalezi samozrejme na velikosti projektu, ale 2GB byste mit mela...</LI></OL>]]>
   <pubDate>Tue, 10 Oct 2006 10:51:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14890&amp;title=pc-pre-acad2007#14890</guid>
   <title><![CDATA[PC pre ACAD2007 : Neviem pos&#250;di&#357; AutoCont. M&#225;m cca...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14887&amp;title=pc-pre-acad2007#14887</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 09:27<br /><br />Neviem posúdiť AutoCont. Mám cca 3 ročnú stanicu, používam ACAD2005, a mala som ju super odladenú. Je pravda, že som si dávala na inštalácie a nastavenia pozor, ale zatiaľ mi fičí bez chyby. Obávam sa, ale že keď prejdem na Acad2007, nebude stíhať. Grafická karta je tam ATI Radeon 7500 64MB, DDR 1GB, CPU iPentium4 1,8A GHz/512k L2 400MHz ostatné je myslím nepodstatné.]]>
   <pubDate>Tue, 10 Oct 2006 09:27:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14887&amp;title=pc-pre-acad2007#14887</guid>
   <title><![CDATA[PC pre ACAD2007 : Chyst&#225;m se koupit workstation...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14885&amp;title=pc-pre-acad2007#14885</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=459">Kamil Hronovský</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 09:18<br /><br />Chystám se koupit workstation xw4400 od HP myslím, že by měla na Acad 2007 dostačovat. <br><br>D2C 1,86 MHz, 1 GB ram, 160 GB HDD, ATI FireGL V 3300.<br>]]>
   <pubDate>Tue, 10 Oct 2006 09:18:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14885&amp;title=pc-pre-acad2007#14885</guid>
   <title><![CDATA[PC pre ACAD2007 :    Buba napsal(a):S&#250; ale celkom...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14883&amp;title=pc-pre-acad2007#14883</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=83">VlJanecek</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 09:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Buba" alt="Původně odeslal(a) Buba" style="vertical-align: text-bottom;" /> <strong>Buba napsal(a):</strong><br /><br />Sú ale celkom dobre odladené a majú dobrý sevis.<div></div>Potrebujem praktické skúsenosti, čo je vyhovujúce.</td></tr></table><br>Se servisem asi mají různí uživatelé různé zkušenosti, v tom nemám přehled. Ale s odladěností pro CAD mám konkrétní zkušenost. Před časem jsme porovnávali stanici Autocont a HP. Papírově silnější Autocont (měl vyšší parametry) byl v Inventoru zhruba o třetinu pomalejší než ta stanice HP. Takže odladěnost se prakticky projevuje. V Autocadu to možná nebude tolik znát, ale stejně bych si vybíral spíš stanici od opravdových značek, HP, IBM nebo Dellu.<br><br>Vl.Janeček<br>]]>
   <pubDate>Tue, 10 Oct 2006 09:12:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14883&amp;title=pc-pre-acad2007#14883</guid>
   <title><![CDATA[PC pre ACAD2007 :   Buba napsal(a): Potrebujem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14882&amp;title=pc-pre-acad2007#14882</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 08:59<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Buba" alt="Původně odeslal(a) Buba" style="vertical-align: text-bottom;" /> <strong>Buba napsal(a):</strong><br /><br /><DIV></DIV>Potrebujem praktické skúsenosti, čo je vyhovujúce.</td></tr></table> <DIV>&nbsp;</DIV><DIV>Od vás, skúsených užívateľov.</DIV>]]>
   <pubDate>Tue, 10 Oct 2006 08:59:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14882&amp;title=pc-pre-acad2007#14882</guid>
   <title><![CDATA[PC pre ACAD2007 : S&#250; ale celkom dobre odladen&#233; a...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14881&amp;title=pc-pre-acad2007#14881</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 3218<br /><strong>Zasláno:</strong> 10.říj.2006 v 08:54<br /><br /><P>Sú ale celkom dobre odladené a majú dobrý sevis.</P><DIV></DIV>Potrebujem praktické skúsenosti, čo je vyhovujúce.]]>
   <pubDate>Tue, 10 Oct 2006 08:54:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3218&amp;PID=14881&amp;title=pc-pre-acad2007#14881</guid>
