  <title>CAD F&#243;rum : Modelace závitu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Modelace závitu]]></description>
  <pubDate>Thu, 03 Sep 2026 22:42:41 +0000</pubDate>
  <lastBuildDate>Mon, 08 Nov 2021 14:18:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=32600</WebWizForums:feedURL>
   <title><![CDATA[Modelace závitu : Sta&#269;&#237; D&#237;k ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124897&amp;title=modelace-zavitu#124897</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36894">emanuel1200</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 14:18<br /><br /><div>Stačí&nbsp; <br></div><div><br></div><div><br></div><div>Dík</div><div><br></div>]]>
   <pubDate>Mon, 08 Nov 2021 14:18:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124897&amp;title=modelace-zavitu#124897</guid>
   <title><![CDATA[Modelace závitu : Sta&#269;&#237; to takto n&#283;jak? S profilem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124896&amp;title=modelace-zavitu#124896</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=63825">issin</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 13:39<br /><br /><img src="uploads/63825/zavit2.jpg" border="0" /><br /><br />Stačí to takto nějak? S profilem je potřeba si pohrát dle strojnických tabulek.]]>
   <pubDate>Mon, 08 Nov 2021 13:39:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124896&amp;title=modelace-zavitu#124896</guid>
   <title><![CDATA[Modelace závitu : Je m&#283; jasn&#233; ,&#382;e tam bude zaoblen&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124892&amp;title=modelace-zavitu#124892</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36894">emanuel1200</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 10:54<br /><br /><div>Je mě jasné ,že tam bude zaoblení , ale potřebuji to v reále.Když to vymodeluji tak jak bych to obráběl to znamení M6xl musí být i ve výkrese se stejným stoupáním a profilem pravouhlého trojúhelníku.V mé&nbsp; verzi je ve výkrese stoupání správné ,profil ne a ve vaší verzi profil správný stoupání ne.Můžete to poslat v ipt.?</div><div><br></div><div><br></div><div>Děkuji<br></div>]]>
   <pubDate>Mon, 08 Nov 2021 10:54:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124892&amp;title=modelace-zavitu#124892</guid>
   <title><![CDATA[Modelace závitu : Je jedno jak&#233; d&#283;l&#225;te stoup&#225;n&#237;....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124891&amp;title=modelace-zavitu#124891</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=63825">issin</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 10:38<br /><br />Je jedno jaké děláte stoupání. Je potřeba přizpůsobit profil, tedy trojúhelník musí mít stranu dle stoupání, rovněž je potřeba počítat se zaoblením vrcholů,...]]>
   <pubDate>Mon, 08 Nov 2021 10:38:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124891&amp;title=modelace-zavitu#124891</guid>
   <title><![CDATA[Modelace závitu : Nev&#237;m zda to podle V&#225;s d&#283;l&#225;m spr&#225;vn&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124889&amp;title=modelace-zavitu#124889</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36894">emanuel1200</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 09:52<br /><br /><div>Nevím zda to podle Vás dělám správně ale pokud ano tak stoupání závitu nevychází 1 mm.</div><div>Potřebuji modelaci M6 x 1 .</div><div><br></div><div>Dík za reakci<br></div>]]>
   <pubDate>Mon, 08 Nov 2021 09:52:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124889&amp;title=modelace-zavitu#124889</guid>
   <title><![CDATA[Modelace závitu : je&#353;t&#283; jsem si v&#353;iml jednoho probl&#233;mu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124885&amp;title=modelace-zavitu#124885</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=63825">issin</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 03:34<br /><br />ještě jsem si všiml jednoho problému - začátek závitu. Profil musí být nakreslen NAD válcem, jinak nebude zcela od začátku.]]>
   <pubDate>Mon, 08 Nov 2021 03:34:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124885&amp;title=modelace-zavitu#124885</guid>
   <title><![CDATA[Modelace závitu : Rozm&#283;ry spir&#225;ly jsou &#353;patn&#283;. Rozte&#269;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124884&amp;title=modelace-zavitu#124884</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=63825">issin</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 08.lis.2021 v 02:52<br /><br />Rozměry spirály jsou špatně. Rozteč musí být jako na obrázku<br /><br /><img src="uploads/63825/zavit.jpg" border="0" />]]>
   <pubDate>Mon, 08 Nov 2021 02:52:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124884&amp;title=modelace-zavitu#124884</guid>
   <title><![CDATA[Modelace závitu : Dobr&#253; den ,nemohu p&#345;ij&#237;t na chybu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124881&amp;title=modelace-zavitu#124881</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36894">emanuel1200</a><br /><strong>Předmět:</strong> 32600<br /><strong>Zasláno:</strong> 07.lis.2021 v 09:23<br /><br /><div>Dobrý den ,</div><div>nemohu přijít na chybu při modelaci závitu.</div><div>Rozměry jsou dobré ale vymodelovaný profil plochý.</div><div><br></div><div>Dík <a href="uploads/36894/Modelace_M6_závitu.ipt" target="_blank" rel="nofollow">uploads/36894/Modelace_M6_závitu.ipt</a><br></div>]]>
   <pubDate>Sun, 07 Nov 2021 09:23:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=32600&amp;PID=124881&amp;title=modelace-zavitu#124881</guid>
