  <title>CAD F&#243;rum : přepínač</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : přepínač]]></description>
  <pubDate>Sat, 17 Oct 2026 21:52:03 +0000</pubDate>
  <lastBuildDate>Mon, 14 Aug 2023 12:06:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=34530</WebWizForums:feedURL>
   <title><![CDATA[přepínač : Op&#283;t b&#225;je&#269;n&#233;, d&#237;ky moc... ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128763&amp;title=prepinac#128763</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=2196">Ondřej Urban</a><br /><strong>Předmět:</strong> 34530<br /><strong>Zasláno:</strong> 14.srp.2023 v 12:06<br /><br />Opět báječné, díky moc...]]>
   <pubDate>Mon, 14 Aug 2023 12:06:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128763&amp;title=prepinac#128763</guid>
   <title><![CDATA[přepínač : &#352;lo, zkuste: ;Layer Freeze/Thaw...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128753&amp;title=prepinac#128753</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 34530<br /><strong>Zasláno:</strong> 11.srp.2023 v 15:31<br /><br />Šlo, zkuste:<div><br></div><div><table width="99%"><tr><td><pre class="BBcode"></div><div><div>;Layer Freeze/Thaw toggle (Arkance Systems)</div><div><br></div><div>(vl-load-com)</div><div><br></div><div>(setq *acaddoc* (vla-get-activedocument (vlax-get-acad-object)))</div><div><br></div><div>(defun C:LFT ( / LFT_name flg lo)</div><div>&nbsp;(setq LFT_name "MOJEHLADINA") ; layer to process</div><div>&nbsp;(cond</div><div>&nbsp; &nbsp; &nbsp; ( (= (strcase (getvar 'CLayer)) (strcase LFT_name))</div><div>&nbsp; &nbsp; &nbsp; &nbsp; (princ "\nCannot freeze current layer")</div><div>&nbsp; &nbsp; &nbsp; )</div><div>&nbsp; &nbsp; &nbsp; ( (setq lo (tblobjname "LAYER" LFT_name))</div><div>&nbsp; &nbsp; &nbsp; &nbsp; (setq lo (vlax-ename-&gt;vla-object lo))</div><div>&nbsp; &nbsp; &nbsp; &nbsp; (vlax-put lo 'Freeze (setq flg (~ (vlax-get lo 'Freeze))))</div><div>&nbsp; &nbsp; &nbsp; &nbsp; (if (= flg 0) (vla-regen *acaddoc* acActiveViewport))</div><div>&nbsp; &nbsp; &nbsp; )</div><div>&nbsp; &nbsp; &nbsp; ( (princ (strcat "\nLayer " LFT_name " does not exist.")))</div><div>&nbsp;)</div><div>&nbsp;(princ)</div><div>)</div><div><br></div><div>(setq *LFTM_status* nil)</div><div><br></div><div>(defun C:LFTM ( / LFT_name)</div><div>&nbsp;(setq LFT_name "MOJEHLADINY*") ; layers to process (mask)</div><div>&nbsp;(command "_-LAYER" (if *LFTM_status* "_FR" "_TH") LFT_name "")</div><div>&nbsp;(setq *LFTM_status* (not *LFTM_status*))</div><div>&nbsp;(princ)</div><div>)</div><div><br></div><div>(princ "\nLFT and LFTM toggle loaded.")</div><div>(princ)</div></div><div></pre></td></tr></table></div>]]>
   <pubDate>Fri, 11 Aug 2023 15:31:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128753&amp;title=prepinac#128753</guid>
   <title><![CDATA[přepínač : Zdrav&#237;m,&#353;lo by tla&#269;&#237;tko funguj&#237;c&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128751&amp;title=prepinac#128751</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=2196">Ondřej Urban</a><br /><strong>Předmět:</strong> 34530<br /><strong>Zasláno:</strong> 11.srp.2023 v 12:56<br /><br />Zdravím,<div>šlo by tlačítko fungující jako přepínač?</div><div>Jedná se mě o rychlé zmrazení / rozmrazení dané hladiny.</div><div>Hladina by byla přímo definována v příkazu, nechci vybírat ! např: "text1"</div><div>Když by to šlo maskou*, bylo by to úžasné :-)&nbsp; &nbsp; např: "text*"</div><div><br></div><div>díky moc Ondřej</div>]]>
   <pubDate>Fri, 11 Aug 2023 12:56:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=34530&amp;PID=128751&amp;title=prepinac#128751</guid>
