  <title>CAD F&#243;rum : REFERENČNÍ DÍLY</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : REFERENČNÍ DÍLY]]></description>
  <pubDate>Wed, 28 Oct 2026 17:36:13 +0000</pubDate>
  <lastBuildDate>Wed, 26 Jun 2024 10:40:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=35237</WebWizForums:feedURL>
   <title><![CDATA[REFERENČNÍ DÍLY : Tady je cel&#253; k&#243;d:Sub Main ()&amp;#039;Testuje...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=35237&amp;PID=130116&amp;title=referencni-dily#130116</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=77333">Spartan54</a><br /><strong>Předmět:</strong> 35237<br /><strong>Zasláno:</strong> 26.čer.2024 v 10:40<br /><br /><div>Tady je celý kód:</div><div><br></div><div>Sub Main ()</div><br>'Testuje soubor na sestavu. Nelze spustit z dílu nebo výkresu. <br>If ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then<br><br>'Nalezne všechny podsestavy a díly v hlavní sestavě<br>&nbsp;&nbsp; &nbsp;Dim SeznamStep As New ArrayList<br>&nbsp;&nbsp; &nbsp;Dim doc As Document<br>&nbsp;&nbsp; &nbsp;Dim FNamePosStep As Long<br>&nbsp;&nbsp; &nbsp;Dim docFNameStep As String<br>&nbsp;&nbsp; &nbsp;Dim oDocs As Documents = ThisApplication.Documents <br>&nbsp;&nbsp; &nbsp;<br>&nbsp;&nbsp; &nbsp;SeznamStep.add(ThisApplication.ActiveDocument.FullFileName)<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;For Each doc In ThisApplication.ActiveDocument.AllReferencedDocuments<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;FNamePosStep = InStrRev(doc.FullFileName, "\", -1) &nbsp;<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;docFNameStep = Mid(doc.FullFileName, FNamePosStep + 1, Len(doc.FullFileName) - FNamePosStep)<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; If doc.DocumentType = kPartDocumentObject And doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" And iProperties.Value(docFNameStep, "Project", "Project") = Parameter("VÝROBNÍ_ČÍSLO") And&nbsp;doc.ComponentDefinition.BOMStructure &lt;&gt; "51972" And Err.Number = 0 Then<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;If iProperties.Value(docFNameStep, "Custom", "He_SkZb") = "201" Then<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;SeznamStep.add(doc.FullFileName)<br>'&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;MessageBox.Show(doc.FullFileName, "Title")<br><br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;doc = oDocs.Open(doc.FullFileName, True)<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;auto = iLogicVb.Automation<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;auto.RunExternalRule(doc,"TISK PDF_STEP\STEP")<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;doc.Close(True)<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;End If<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;End If<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;Next<br>Else<br><br>MessageBox.Show("Testovaný soubor není sestava. Toto pravidlo lze spustit pouze v sestavě.", "Zkontroluj umístění projektu a souburu!")<br><br>End If&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>End Sub<br><br>]]>
   <pubDate>Wed, 26 Jun 2024 10:40:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=35237&amp;PID=130116&amp;title=referencni-dily#130116</guid>
   <title><![CDATA[REFERENČNÍ DÍLY : Dobr&#253; den,m&#225;m vytvo&#345;en&#233; pravidlo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=35237&amp;PID=130115&amp;title=referencni-dily#130115</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=77333">Spartan54</a><br /><strong>Předmět:</strong> 35237<br /><strong>Zasláno:</strong> 26.čer.2024 v 08:57<br /><br /><div>Dobrý den,</div><div>mám vytvořené pravidlo pro automatické vytváření STEPů plechových dílů ze sestavy. Potřebuju, aby pravidlo nevytvořilo STEP ze součásti, která má nastavenou strukturu rozpisky jako referenční. Přidal jsem podmínku : doc.ComponentDefinition.BOMStructure &lt;&gt; "51972".</div><div>S touto podmínkou STEP nevytvoří, pokud je struktura rozpisky nastavena přímo na dílu. Pokud změním strukturu rozpisky jenom ve stromu sestavy, tak na díle zůstane normální a STEP se vytvoří.</div><div>Nemáte radu jak toto ošetřit?<br></div>]]>
   <pubDate>Wed, 26 Jun 2024 08:57:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=35237&amp;PID=130115&amp;title=referencni-dily#130115</guid>
