  <title>CAD F&#243;rum : Väzba bod-bod v .iam</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Väzba bod-bod v .iam]]></description>
  <pubDate>Sun, 01 Nov 2026 02:32:16 +0000</pubDate>
  <lastBuildDate>Thu, 04 Jan 2007 12:51:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=3630</WebWizForums:feedURL>
   <title><![CDATA[Väzba bod-bod v .iam : Pou&#382;i&#357; funkciu Loft by ne&#353;lo? ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17208&amp;title=vazba-bodbod-v-iam#17208</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 04.led.2007 v 12:51<br /><br />Použiť funkciu Loft by nešlo?]]>
   <pubDate>Thu, 04 Jan 2007 12:51:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17208&amp;title=vazba-bodbod-v-iam#17208</guid>
   <title><![CDATA[Väzba bod-bod v .iam : &#270;akujem za rady.Porad&#237;te mi, ako...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17207&amp;title=vazba-bodbod-v-iam#17207</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1118">pedro</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 04.led.2007 v 12:42<br /><br />Ďakujem za rady.&nbsp;Poradíte mi, ako urobiť vysunutie pod iným uhlom ako 90° na rovinu náčrtu?]]>
   <pubDate>Thu, 04 Jan 2007 12:42:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17207&amp;title=vazba-bodbod-v-iam#17207</guid>
   <title><![CDATA[Väzba bod-bod v .iam : zkuste toto: v sestav&#283; Sou&#269;&#225;st1...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17081&amp;title=vazba-bodbod-v-iam#17081</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1741">rumcaiz</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 02.led.2007 v 10:30<br /><br />zkuste toto:<DIV>v sestavě</DIV><DIV>Součást1 - 1 úsečka (obecně jakákoli součást)</DIV><DIV>Součást2 - nová - v náčrtu nakreslit úsečku, pro náčrt zapnout adaptivitu. nechte tam prozatím jen ten náčrt</DIV><DIV>v sestavě vytvořte první vazbu mezi součást2 počátek úsečky - bod/hrana/pracosa... Součást1(mi to funguje nejlépe pokud rovina náčrtu Součásti2 není rovnoběžná s hranou/rovinou/pracosou... vazbeného prvku/objektu Součásti1) a pak i druhou vazbu (podobně jak tu první)</DIV><DIV>pak je náčrt Součást2 adaptivně spojen se&nbsp;Součást1.</DIV><DIV>následně už můžete do Součásti2 vstupovat, doplňovat další náčrty a prvky podle potřeby</DIV>]]>
   <pubDate>Tue, 02 Jan 2007 10:30:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17081&amp;title=vazba-bodbod-v-iam#17081</guid>
   <title><![CDATA[Väzba bod-bod v .iam : V&#225;&#353; postup je pon&#283;kud nestandardn&#237;....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17073&amp;title=vazba-bodbod-v-iam#17073</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=88">Mrázek</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 02.led.2007 v 08:52<br /><br /><P>Váš postup je poněkud nestandardní. Inventor je 3D modelář a pokud pracujete s objemovými modely, tak vše funguje O.K. (např. náčrt, vzniklý promítnutím hrany se při změně modelu zdrojového partu přizpůsobí ... je-li adaptivita zapnuta). </P><DIV>Moc nechápu, proč vazbíte součásti ve fázi náčrtu. Pokud potřebujete použít jeden náčrt pro více partů, tak použijte sdílení náčrtu.</DIV>]]>
   <pubDate>Tue, 02 Jan 2007 08:52:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17073&amp;title=vazba-bodbod-v-iam#17073</guid>
   <title><![CDATA[Väzba bod-bod v .iam : Nie&#269;o rob&#237;m nespr&#225;vne,nedar&#237; sa...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17054&amp;title=vazba-bodbod-v-iam#17054</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1118">pedro</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 30.pro.2006 v 13:16<br /><br />Niečo robím nesprávne,&nbsp;nedarí sa mi rozchodiť adaptivitu pri premietaní. Založím novú zostavu. Vytvorím v nej novú Súčasť1 - iba úsečku. Vytvorím Súčasť2 premietnutím úsečky zo Súčasti1 v&nbsp;tej istej&nbsp;rovine. Nastavím adaptivitu&nbsp;pre oba náčrty. Ak ľubovoľne zmením náčrt úsečky v Súčasti1 zmeny sa nijako neprejavia na Súčasti2 ... <img src="http://www.cadforum.sk/forum/smileys/smiley5.gif" height="17" width="17" border="0" align="absmiddle" alt="C&#111;nfused" />&nbsp;Netušíte, kde robím chybu?]]>
   <pubDate>Sat, 30 Dec 2006 13:16:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17054&amp;title=vazba-bodbod-v-iam#17054</guid>
   <title><![CDATA[Väzba bod-bod v .iam :   pedro napsal(a): Radil ste...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17024&amp;title=vazba-bodbod-v-iam#17024</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=88">Mrázek</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 27.pro.2006 v 11:21<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) pedro" alt="Původně odeslal(a) pedro" style="vertical-align: text-bottom;" /> <strong>pedro napsal(a):</strong><br /><br /><P ="Ms&#111;normal"><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">&nbsp;Radil ste mi použiť premietanie v&nbsp;náčrtoch z&nbsp;iných súčastí. Žiaľ ani to sa neaktualizuje pri zmene vzorovej súčasti. Alebo sa to dá nejako zaväzbiť?</P><DIV></SPAN></FONT>&nbsp;</DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT>&nbsp;</DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">No ... riešim opačnú otázku ako doteraz. Možno nejako pohodlne spojiť dva ipt do jedného? Nenašiel som spôsob, ako by mi hore popísaný spôsob umožnil urobiť ohyb trubky. Mám to zatiaľ vymodelované ako spoj dvoch trubiek pod uhlom a chcem ich spojiť dokopy.</SPAN></FONT></DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT>&nbsp;</DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><O:P>Veselého Silvestra a veľa sťastia v Novom roku!</O:P></SPAN></FONT></DIV></td></tr></table> <DIV>&nbsp;</DIV><DIV>K prvnímu problému - součásti musejí mít nastavenou adaptivitu (ve stromě historie přes pravé tlačítko). Jinak se chovají tak jak píšete - převezme se tvar v okamžiku modelování, ale při změně jedné součásti se druhá neaktualizuje. Pouze pozor - adaptivita docela zatěžuje systém, takže nastavit pouze tam, kde to nezbytně potřebujete!</DIV><DIV>Druhý problém -spojení dvou součástí- řeší odvozená součást. (nový part - příkaz "odvozená součást" - načíst sestavu - uložit....udělá to nový part, složený z dílů sestavy a je to asociativní, tedy při změně zdrojové sestavy se změní i odvozená součást).</DIV>]]>
   <pubDate>Wed, 27 Dec 2006 11:21:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17024&amp;title=vazba-bodbod-v-iam#17024</guid>
   <title><![CDATA[Väzba bod-bod v .iam : V&#271;aka za odpove&#271; aj za vin&#353;. Ne&#250;spe&#353;ne...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17023&amp;title=vazba-bodbod-v-iam#17023</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1118">pedro</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 27.pro.2006 v 11:10<br /><br /><P =Ms&#111;normal><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Vďaka za odpoveď aj za vinš. Neúspešne som sa pokúšal použiť štandardné nástroje ako Vysunutie v&nbsp;zostave po povrch inej súčasti. Dobrá sa zdala funkcia Zvýšiť úroveň. Žiaľ ani tá sama neaktualizuje tvar plochy prevzatý z&nbsp;inej súčasti pri zmene tej vzorovej. Radil ste mi použiť premietanie v&nbsp;náčrtoch z&nbsp;iných súčastí. Žiaľ ani to sa neaktualizuje pri zmene vzorovej súčasti. Alebo sa to dá nejako zaväzbiť?</P><DIV></SPAN></FONT><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">No ale nakoniec sa mi podarilo postúpiť o&nbsp;riadny kus ďalej. V&nbsp;zostave sa&nbsp;možno prepínať medzi štandardnou sadou nástrojov a&nbsp;Generátorom rámečku a&nbsp;to je práve to, čo som potreboval. Týmto som v&nbsp;pohode poukladal všetky trubky na Koncept.ipt vytvorený z&nbsp;úsečiek - osí trubiek a&nbsp;pospájal ich – vymodeloval prieniky pomocou funkcie Drážka ... Takto vytvorený model samostatne reaguje na všetky zmeny v&nbsp;Koncept.ipt tak, ako som si to predstavoval.</SPAN></FONT></DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT>&nbsp;</DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">No ... riešim opačnú otázku ako doteraz. Možno nejako pohodlne spojiť dva ipt do jedného? Nenašiel som spôsob, ako by mi hore popísaný spôsob umožnil urobiť ohyb trubky. Mám to zatiaľ vymodelované ako spoj dvoch trubiek pod uhlom a chcem ich spojiť dokopy.</SPAN></FONT></DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"></SPAN></FONT>&nbsp;</DIV><DIV><FONT face=Arial color=black size=2><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p>Veselého Silvestra a veľa sťastia v Novom roku!</o:p></SPAN></FONT></DIV>]]>
   <pubDate>Wed, 27 Dec 2006 11:10:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=17023&amp;title=vazba-bodbod-v-iam#17023</guid>
   <title><![CDATA[Väzba bod-bod v .iam : J&#225; pracuji je&#353;t&#283; na verzi 9 a...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16973&amp;title=vazba-bodbod-v-iam#16973</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=88">Mrázek</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 20.pro.2006 v 12:24<br /><br />Já pracuji ještě na verzi 9 a tam nějak výrazněji jednodušší způsob není možný. Vím, že verze 11 se dost posunula v plochách, takže možná by se toho nějak dalo využít. Bohužel - nemám kde vyzkoušet.<DIV>Dříve popsaný způsob vypadá sice trochu krkolomně, ale není to tak strašně a hlavně to funguje. Ale netvrdím, že to je způsob jediný. Čím má modelář větší možnosti, tím více existuje cest, jak se dostat ke stejnému výsledku (to vidím hlavně při práci v Catii).</DIV>]]>
   <pubDate>Wed, 20 Dec 2006 12:24:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16973&amp;title=vazba-bodbod-v-iam#16973</guid>
   <title><![CDATA[Väzba bod-bod v .iam : &#270;akujem pekneza radu. Tro&#353;ku ma...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16970&amp;title=vazba-bodbod-v-iam#16970</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1118">pedro</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 20.pro.2006 v 11:26<br /><br />Ďakujem pekne&nbsp;za radu. Trošku ma to sklamalo, lebo som dúfal v jednoduchšie riešenie. Asi so mnou budete súhlasiť, že by to&nbsp;mohlo ísť&nbsp;aj tak, že v parte vysuniem povrchovú válcovú plochu zhodnú s nadväzujúcou trubkou, a vysunutie urobím&nbsp;po ňu.&nbsp;Nedá sa táto plocha odvodiť priamo z povrchu už existujúcej súčasti - predstavujem si niečo ako 3D premietanie geometrie, tak ako to funguje v 2D náčrtoch? ]]>
   <pubDate>Wed, 20 Dec 2006 11:26:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16970&amp;title=vazba-bodbod-v-iam#16970</guid>
   <title><![CDATA[Väzba bod-bod v .iam : Pokud se jedn&#225; o vysunut&#237; k rovn&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16969&amp;title=vazba-bodbod-v-iam#16969</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=88">Mrázek</a><br /><strong>Předmět:</strong> 3630<br /><strong>Zasláno:</strong> 20.pro.2006 v 11:09<br /><br />Pokud se jedná o vysunutí k rovné ploše, tam to jde. Pokud potřebujete dotáhnout k sobě např. dvě trubky (když tvoříte ten rám kola), udělejte je delší a pak je navzájem ořízněte (rovina náčrtu kolmá na osu ořezávající trubky, náčrt získáte projekcí). Bohužel musíte jít přes náčrt a vysunutí (odebrání materiálu), Inventor neumí v sestavě boolovské operace mezi party. To jde v odvozené součásti, ale to byste se dostal oklikou tam, kde jste začal - odvozená součást je part, nikoliv assembly.]]>
   <pubDate>Wed, 20 Dec 2006 11:09:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3630&amp;PID=16969&amp;title=vazba-bodbod-v-iam#16969</guid>
