  <title>CAD F&#243;rum : šablona.idw</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : šablona.idw]]></description>
  <pubDate>Sun, 01 Nov 2026 22:38:10 +0000</pubDate>
  <lastBuildDate>Mon, 08 Jan 2007 12:22:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=3631</WebWizForums:feedURL>
   <title><![CDATA[šablona.idw :   McQuack napsal(a):vytvor si...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=17350&amp;title=sablonaidw#17350</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1835">Broňa</a><br /><strong>Předmět:</strong> 3631<br /><strong>Zasláno:</strong> 08.led.2007 v 12:22<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) McQuack" alt="Původně odeslal(a) McQuack" style="vertical-align: text-bottom;" /> <strong>McQuack napsal(a):</strong><br /><br />vytvor si novy standart v ktorom si predefinujes hrubky ciar, koty atd.&nbsp; a subor potom uloz do adresara Templates (Program Files\Autodesk\Inventor \Templates\)a potom si uz budes len prepinat styly podla potreby. <DIV>&nbsp;</DIV><DIV>dufam ze sme sa pochopili </DIV></td></tr></table> ]]>
   <pubDate>Mon, 08 Jan 2007 12:22:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=17350&amp;title=sablonaidw#17350</guid>
   <title><![CDATA[šablona.idw : vytvor si novy standart v ktorom...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=16959&amp;title=sablonaidw#16959</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1853">McQuack</a><br /><strong>Předmět:</strong> 3631<br /><strong>Zasláno:</strong> 19.pro.2006 v 12:56<br /><br />vytvor si novy standart v ktorom si predefinujes hrubky ciar, koty atd.&nbsp; a subor potom uloz do adresara Templates (Program Files\Autodesk\Inventor \Templates\)a potom si uz budes len prepinat styly podla potreby.<DIV>&nbsp;</DIV><DIV>dufam ze sme sa pochopili </DIV>]]>
   <pubDate>Tue, 19 Dec 2006 12:56:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=16959&amp;title=sablonaidw#16959</guid>
   <title><![CDATA[šablona.idw : Dobr&#253; den, m&#283;l bych jeden skromn&#253;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=16930&amp;title=sablonaidw#16930</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1835">Broňa</a><br /><strong>Předmět:</strong> 3631<br /><strong>Zasláno:</strong> 18.pro.2006 v 14:27<br /><br />Dobrý den,<DIV>měl bych jeden skromný dotaz.Když si vytvořím idw šablonu,kde mám nastavéné své hladiny a styly kót apod.,tak se mi po otevření této šablony zobrazí výstražné okno,kde je napsáno:</DIV><DIV>&nbsp;</DIV><DIV>"Konflikt stylů:</DIV><DIV>Následující definice v šabloně se liší od definic v knihovně stylů,použije se definice stylů.Kóta:Výchozí (DIN) atd.</DIV><DIV>Pokud je definice stylu v knihovně stylů určena pro nový dokument,aktualizujte šablonu novou definicí stylů.Pokud je definice stylu v šabloně určena pro nový dokument,upravte projrkt a na stavte parametr Použít knihovny stylů=Ne."</DIV><DIV>&nbsp;</DIV><DIV>Když dám po této výzvě Ok,tak se mi otevře šablona bez nastavených hladin.Protože tisknu i velké formáty výkresů na A4 tak stále přepisování tlouštěk čar je dost otravné.</DIV><DIV>Bohužel se mi tato výzva ukazuje v již v přednastavených .idw šablonách.</DIV><DIV>Nevím kde dělám a nebo kde jsem udělal chybu.<img src="http://www.cadforum.cz/forum/smileys/smiley5.gif" height="17" width="17" border="0" align="absmiddle" alt="C&#111;nfused" /></DIV><DIV>Prosím pomozte</DIV><DIV>Bronislav Horehleď</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Mon, 18 Dec 2006 14:27:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3631&amp;PID=16930&amp;title=sablonaidw#16930</guid>
