  <title>CAD F&#243;rum : DWG export  a barvy</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : DWG export  a barvy]]></description>
  <pubDate>Mon, 14 Sep 2026 19:21:11 +0000</pubDate>
  <lastBuildDate>Fri, 05 Jan 2007 09:07:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=3690</WebWizForums:feedURL>
   <title><![CDATA[DWG export  a barvy : Zdravim, muze mi nekdo poradit,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=3690&amp;PID=17240&amp;title=dwg-export-a-barvy#17240</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1404">Rudolf Vyhnalek</a><br /><strong>Předmět:</strong> 3690<br /><strong>Zasláno:</strong> 05.led.2007 v 09:07<br /><br />Zdravim, muze mi nekdo poradit, jak zaridit, aby pri exportu do DWG Revit prevzal barvy od sebe? Smazani ID barev v nastaveni hladin nefunguje. Diky<DIV></DIV>]]>
   <pubDate>Fri, 05 Jan 2007 09:07:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=3690&amp;PID=17240&amp;title=dwg-export-a-barvy#17240</guid>
