  <title>CAD F&#243;rum : Hromadne ulozeni BLOKU</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Hromadne ulozeni BLOKU]]></description>
  <pubDate>Sun, 18 Oct 2026 08:42:26 +0000</pubDate>
  <lastBuildDate>Mon, 28 May 2007 13:02:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=4632</WebWizForums:feedURL>
   <title><![CDATA[Hromadne ulozeni BLOKU : Tak ta &amp;#034;druh&#225; dne&#353;n&#237;&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22445&amp;title=hromadne-ulozeni-bloku#22445</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 13:02<br /><br />Tak ta "druhá dnešní" verze funguje opravdu perfektně&nbsp; <img src="http://www.cadforum.cz/forum/smileys/smiley20.gif" height="17" width="23" border="0" align="absmiddle" alt="Thumbs%20Up" />]]>
   <pubDate>Mon, 28 May 2007 13:02:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22445&amp;title=hromadne-ulozeni-bloku#22445</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Me to funguje bez problemu - krom...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22443&amp;title=hromadne-ulozeni-bloku#22443</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1513">Peter M.</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 12:46<br /><br />Me to funguje bez problemu - krom adresare nic nemusim odklikavat... <DIV>AC 2007</DIV><span style="font-size:10px"><br /><br />Upravil Peter M. - 28.kvě.2007 v 12:47</span>]]>
   <pubDate>Mon, 28 May 2007 12:46:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22443&amp;title=hromadne-ulozeni-bloku#22443</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : To jsem pr&#225;v&#283; d&#283;lal. St&#225;hl jsem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22434&amp;title=hromadne-ulozeni-bloku#22434</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 10:50<br /><br /><P>To jsem právě dělal. Stáhl jsem si dnešní verzi. (Anebo&nbsp;jste to už stihl změnit?)&nbsp;Možná to je nějaká chyba v mém konkrétním souboru. Bohužel teď nemám čas to zkoušet na jiných. </P><DIV>Nicméně to pro mne nijak nesnižuje význam téhle utilitky </DIV>]]>
   <pubDate>Mon, 28 May 2007 10:50:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22434&amp;title=hromadne-ulozeni-bloku#22434</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Zkuste aktu&#225;ln&#237; verzi WblockAll....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22432&amp;title=hromadne-ulozeni-bloku#22432</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 10:25<br /><br />Zkuste aktuální verzi WblockAll.]]>
   <pubDate>Mon, 28 May 2007 10:25:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22432&amp;title=hromadne-ulozeni-bloku#22432</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU :  To je fajn   Jenom to p&#345;i...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22431&amp;title=hromadne-ulozeni-bloku#22431</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 10:06<br /><br /><a href="http://www.cadforum.cz/forum/uploads/20070528_100406_hlaseni.txt" target="_blank"><DIV>To je fajn <img src="http://www.cadforum.cz/forum/smileys/smiley32.gif" height="17" width="18" border="0" align="absmiddle" alt="Clap" /></DIV><DIV>&nbsp;</DIV><DIV>Jenom&nbsp; to při pokusu&nbsp;hlásilo chyby&nbsp;na některých x-refech - viz přiložený soubor</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>uploads/20070528_100406_hlaseni.txt</DIV></A>]]>
   <pubDate>Mon, 28 May 2007 10:06:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22431&amp;title=hromadne-ulozeni-bloku#22431</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Hmm, tak ne - EXPERT nepom&#367;&#382;e,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22429&amp;title=hromadne-ulozeni-bloku#22429</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 28.kvě.2007 v 09:35<br /><br />Hmm, tak ne - EXPERT nepomůže, bylo to komplikovanější - export v Mapu vyřešen v aktualizované verzi <strong>WblockAll</strong> (viz Download).]]>
   <pubDate>Mon, 28 May 2007 09:35:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22429&amp;title=hromadne-ulozeni-bloku#22429</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Mysl&#237;m &#382;e to jde p&#345;es prom&#283;nnou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22424&amp;title=hromadne-ulozeni-bloku#22424</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 27.kvě.2007 v 21:28<br /><br />Myslím že to jde přes proměnnou EXPERT (nezkoušeno).]]>
   <pubDate>Sun, 27 May 2007 21:28:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22424&amp;title=hromadne-ulozeni-bloku#22424</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Tedy aby nevyskakovala p&#345;i exportu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22407&amp;title=hromadne-ulozeni-bloku#22407</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 25.kvě.2007 v 15:59<br /><br />Tedy aby nevyskakovala při exportu KAŽDÉHO bloku (tedy třeba 100x ?<DIV></DIV>]]>
   <pubDate>Fri, 25 May 2007 15:59:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22407&amp;title=hromadne-ulozeni-bloku#22407</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : &amp;#034;current&amp;#034; pravd&#283;podobn&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22406&amp;title=hromadne-ulozeni-bloku#22406</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 25.kvě.2007 v 15:58<br /><br /><P>"current" pravděpodobně znamená adresář, kde je uložen dwg, který máte otevřen</P><DIV>&nbsp;</DIV><DIV>Jinak můžete zvolit jakýkoliv adresář - např. D:/aaa&nbsp;&nbsp;&nbsp; Pozor - normální lomítko!</DIV><DIV>&nbsp;</DIV><DIV>Jinak když jsem to zkusil, jak odstranit, aby nevyskakovala okna "zahrnout informaci Map do exportu"?</DIV>]]>
   <pubDate>Fri, 25 May 2007 15:58:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22406&amp;title=hromadne-ulozeni-bloku#22406</guid>
   <title><![CDATA[Hromadne ulozeni BLOKU : Super, zdase, ze je to to co hledam...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22405&amp;title=hromadne-ulozeni-bloku#22405</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1513">Peter M.</a><br /><strong>Předmět:</strong> 4632<br /><strong>Zasláno:</strong> 25.kvě.2007 v 15:33<br /><br />Super, zdase, ze je to to co hledam - jen jak nastavit ten adresar (co znamena current - kde je to) ?]]>
   <pubDate>Fri, 25 May 2007 15:33:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4632&amp;PID=22405&amp;title=hromadne-ulozeni-bloku#22405</guid>
