  <title>CAD F&#243;rum : Spojení do křivky</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : Spojení do křivky]]></description>
  <pubDate>Mon, 17 Aug 2026 20:32:31 +0000</pubDate>
  <lastBuildDate>Wed, 04 Jul 2007 14:18:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=4798</WebWizForums:feedURL>
   <title><![CDATA[Spojení do křivky : Tak ta promenna &amp;#034;peditaccept&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23304&amp;title=spojeni-do-krivky#23304</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1045">johny</a><br /><strong>Předmět:</strong> 4798<br /><strong>Zasláno:</strong> 04.čvc.2007 v 14:18<br /><br />Tak ta promenna "peditaccept" je sikovna, kdyby jen o ni clovek vedel :)<DIV>Pred casem jsem to taky resil, jeste jsem po tom chtel aby to pospojovalo ikdyz tam jsou male mezery (do 5 cm) a aby slo objekty vybrat pred spustenim prikazu...</DIV><DIV>&nbsp;</DIV><DIV>(defun C:ske( / ss index n Ano tepent) ;spoj "krivky" s mezerou do 0.05<BR>&nbsp; (command "_select" pause)<BR>&nbsp; (setq ss (ssget "_p"))<BR>&nbsp;&nbsp;&nbsp; (setq index 0<BR>&nbsp;&nbsp; n (sslength ss))<BR>&nbsp;&nbsp;&nbsp; (repeat n<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (setq typent (cdr (assoc 0 (entget (ssname ss index)))))<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (if (or (equal typent "LINE") (equal typent "ARC"))<BR>&nbsp; (setq Ano T))<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (setq index (+ 1 index)))<BR>&nbsp; <BR>&nbsp; (command "_pedit" "_m" "_p" "")<BR>&nbsp; (if Ano (command "_y")) ;Kdyz je cara nebo oblouk<BR>&nbsp; (command "_j" "_j" "_e" "0.05" "")<BR>&nbsp; (princ)<BR>)</DIV><DIV>&nbsp;</DIV><DIV>Takze ten cyklus se&nbsp;necha nahradit vypnutim te sikovene promenne...</DIV>]]>
   <pubDate>Wed, 04 Jul 2007 14:18:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23304&amp;title=spojeni-do-krivky#23304</guid>
   <title><![CDATA[Spojení do křivky : D&#237;ky moc, je to p&#345;esn&#283; to co jsem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23185&amp;title=spojeni-do-krivky#23185</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1612">BenaCZ</a><br /><strong>Předmět:</strong> 4798<br /><strong>Zasláno:</strong> 25.čer.2007 v 15:29<br /><br />Díky moc, je to přesně to co jsem chtěl.]]>
   <pubDate>Mon, 25 Jun 2007 15:29:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23185&amp;title=spojeni-do-krivky#23185</guid>
   <title><![CDATA[Spojení do křivky : Pokud jsem to dob&#345;e pochopil,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23184&amp;title=spojeni-do-krivky#23184</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=3641">chlebovsky</a><br /><strong>Předmět:</strong> 4798<br /><strong>Zasláno:</strong> 25.čer.2007 v 15:24<br /><br /><DIV>Pokud jsem to dobře pochopil, tak se Vám jedná o to, že se vám neukončí příkaz editace křivky.</DIV><DIV>Myslím že když přepíšete ten command tak by to mělo fungovat.</DIV><DIV>&nbsp;</DIV><DIV>(command "_pedit" pause "_j" (ssget) "" "")</DIV><DIV>&nbsp;</DIV><DIV>doporučuji psát i to "p" anglicky "_j" bude to fungovat vždy</DIV><DIV>Martin.</DIV>]]>
   <pubDate>Mon, 25 Jun 2007 15:24:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23184&amp;title=spojeni-do-krivky#23184</guid>
   <title><![CDATA[Spojení do křivky : No j&#225; to &#345;e&#353;&#237;m prozat&#237;m PLJOIN,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23179&amp;title=spojeni-do-krivky#23179</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 4798<br /><strong>Zasláno:</strong> 25.čer.2007 v 14:39<br /><br />No já to řeším prozatím PLJOIN, makro podobného typu jak zamýšlíte Vy by se ale hodilo neboť PLJOIN ve vyšších verzích je trošku nespolehlivé.]]>
   <pubDate>Mon, 25 Jun 2007 14:39:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23179&amp;title=spojeni-do-krivky#23179</guid>
   <title><![CDATA[Spojení do křivky : Mohli byste mi pros&#237;m poradit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23169&amp;title=spojeni-do-krivky#23169</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1612">BenaCZ</a><br /><strong>Předmět:</strong> 4798<br /><strong>Zasláno:</strong> 25.čer.2007 v 12:24<br /><br />Mohli byste mi prosím poradit jak zfunkčnit tento lisp? jedná se o zrychlené spojení čar do 1 křivky.<br /><br />;;; spoji cary do krivky<br />(defun C:spojitdokrivky&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(/ PDACPT)<br />;;;nastaví peditaccept<br />  (setq PDACPT (getvar "peditaccept"))<br />  (setvar "peditaccept" 1)<br /><br />;;;vlastní funkce<br />  (command "_pedit" pause "p" pause)<br />  (princ)<br />;;; obnovuje původní peditaccept<br />  (setvar "peditaccept" PDACPT)<br />  (princ)<br />)<br /><br />Lisp funguje, jen nedokážu po spojení čar do křivky ukončit dialog _pedit  <img src="https://www.cadforum.cz/forum/smileys/smiley5.gif" border="0" align="middle" />  Díky moc za radu. Bena]]>
   <pubDate>Mon, 25 Jun 2007 12:24:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=4798&amp;PID=23169&amp;title=spojeni-do-krivky#23169</guid>
