  <title>CAD F&#243;rum : Definice cary</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Definice cary]]></description>
  <pubDate>Thu, 05 Nov 2026 18:46:52 +0000</pubDate>
  <lastBuildDate>Tue, 14 Aug 2007 17:22:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=5015</WebWizForums:feedURL>
   <title><![CDATA[Definice cary : Tak&#382;e jsme tro&#353;ku poheldal. Resolution...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24179&amp;title=definice-cary#24179</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 17:22<br /><br />Takže jsme trošku poheldal. Resolution u tvaru je vlastně totéž co rozlišení. Čím nižší hodnota tím je nižší kvalita zobrazení <DIV><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=101756" alt="Původně odeslal(a) http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=101756" style="vertical-align: text-bottom;" /> <strong>http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=101756 napsal(a):</strong><br /><br /></DIV><DIV><strong>Resolution<BR></strong>I hesitate to explain the resolution concept when the Help file does such a splendid job, but I'll provide a general overview. The higher you set the resolution, the higher the quality of the final shape; lower values create lower quality shapes. The higher the resolution, the higher the performance hit you will take-and vice versa. Simple linear objects don't require extremely high resolution to get a good quality shape file, those that are more complex--and contain arc information--do. The highest value you can set is 32,767, but rumor has it you would be insane to set it to that incredibly high value. I suggest trying a few different resolutions until you are happy with the results. The Help file provides some great examples of different resolution values and how they affect the same object.</DIV><DIV><DIV></td></tr></table></DIV></DIV>]]>
   <pubDate>Tue, 14 Aug 2007 17:22:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24179&amp;title=definice-cary#24179</guid>
   <title><![CDATA[Definice cary : No tomu slovu sice rozumim, ale...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24174&amp;title=definice-cary#24174</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1513">Peter M.</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 15:04<br /><br />No tomu slovu sice rozumim, ale nechapu ten vyznam v definici SHAPE (hodnota 128).<br><br>Anebo jinak - mate nekdo jiny navod, nez pomoci shape, jak si vytvorit vlastni sadu car TRAPEZOVYCH plechu ?<br>]]>
   <pubDate>Tue, 14 Aug 2007 15:04:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24174&amp;title=definice-cary#24174</guid>
   <title><![CDATA[Definice cary : Resolution je asi mysleno rozliseni...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24169&amp;title=definice-cary#24169</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 14:05<br /><br />Resolution je asi mysleno rozliseni nebo meritko,a le to je jen odhad z eng vyrazu.]]>
   <pubDate>Tue, 14 Aug 2007 14:05:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24169&amp;title=definice-cary#24169</guid>
   <title><![CDATA[Definice cary :  Nj, ale mam dojem, ze je to...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24164&amp;title=definice-cary#24164</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1513">Peter M.</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 13:02<br /><br />Nj, ale mam dojem, ze je to nejaky obecny trapez, ale ja potrebuji konkretni (nemam problem si vlnu nakreslit).<br>Tvorim pomoci ET -&gt; Makelinetype a Makeshape, jen nevim proc mi to ten ten shape neprevede na typ cary... chce to asi nejakou mezeru navic nebo co.<br><br>A !!!<br>&nbsp;Uz mi to ten shape prevedlo, ale kresli mito na zacatku a na konci caru navic, coz nechci...<br><br>Nikde jsem se take nedocetl, co znamena hodnota "Resolution" pri definici shape.<br><span style="font-size:10px"><br /><br />Upravil Peter M. - 14.srp.2007 v 13:15</span>]]>
   <pubDate>Tue, 14 Aug 2007 13:02:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24164&amp;title=definice-cary#24164</guid>
   <title><![CDATA[Definice cary : Pokud byste mel zajem, tak mam...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24163&amp;title=definice-cary#24163</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 12:54<br /><br />Pokud byste mel zajem, tak mam takovy dojem, ze artap jiz definici teto cary vytvoril.]]>
   <pubDate>Tue, 14 Aug 2007 12:54:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24163&amp;title=definice-cary#24163</guid>
   <title><![CDATA[Definice cary : Zdravim,neco delam asi spatne:Nadefinovalsem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24160&amp;title=definice-cary#24160</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1513">Peter M.</a><br /><strong>Předmět:</strong> 5015<br /><strong>Zasláno:</strong> 14.srp.2007 v 12:21<br /><br />Zdravim,<br>&nbsp;neco delam asi spatne:<br>&nbsp;Nadefinovalsem tvar trapezoveho plechu a ulozil jako shape. Snazim se z nej vytvorit typ cary, ale pise mi to "*Invalid* That's the continuous linetype!" a nikde nemuzu najit co to znamena.<br>]]>
   <pubDate>Tue, 14 Aug 2007 12:21:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5015&amp;PID=24160&amp;title=definice-cary#24160</guid>
