  <title>CAD F&#243;rum : find/replace</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : find/replace]]></description>
  <pubDate>Sat, 31 Oct 2026 19:29:48 +0000</pubDate>
  <lastBuildDate>Fri, 16 Nov 2007 14:31:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=5484</WebWizForums:feedURL>
   <title><![CDATA[find/replace : Tak je vyresenoprevod dwg na dxf...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26602&amp;title=find-replace#26602</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=468">KoTy</a><br /><strong>Předmět:</strong> 5484<br /><strong>Zasláno:</strong> 16.lis.2007 v 14:31<br /><br />Tak je vyreseno<br>prevod dwg na dxf jenom s temi cisly<br>a v text editoru ctrl+h<br>hledat:<br>"&nbsp; 1^p"<br>nahradit:<br>"&nbsp; 1^p."<br>a vymalovano<br>]]>
   <pubDate>Fri, 16 Nov 2007 14:31:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26602&amp;title=find-replace#26602</guid>
   <title><![CDATA[find/replace : Tip: p&#345;ipi&#353;te si v Nastaven&#237; -...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26591&amp;title=find-replace#26591</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 5484<br /><strong>Zasláno:</strong> 16.lis.2007 v 12:52<br /><br /><strong>Tip</strong>: připište si v <EM>Nastavení - Upravit profil - Používané CAD aplikace</EM> ...]]>
   <pubDate>Fri, 16 Nov 2007 12:52:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26591&amp;title=find-replace#26591</guid>
   <title><![CDATA[find/replace : coz oto to urcit ezvladle lec...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26590&amp;title=find-replace#26590</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=468">KoTy</a><br /><strong>Předmět:</strong> 5484<br /><strong>Zasláno:</strong> 16.lis.2007 v 12:46<br /><br />coz oto to urcit ezvladle lec ne v LT :((]]>
   <pubDate>Fri, 16 Nov 2007 12:46:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26590&amp;title=find-replace#26590</guid>
   <title><![CDATA[find/replace : I ty nejdivo&#269;ej&#353;&#237; po&#382;adavky nahrazov&#225;n&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26568&amp;title=find-replace#26568</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 5484<br /><strong>Zasláno:</strong> 16.lis.2007 v 09:01<br /><br />I ty nejdivočejší požadavky nahrazování a přehazování textů v DWG zvládne bezplatná utilita <strong>Xanadu srxText</strong> - viz <a href="http://www.xanadu.cz/vyvoj" target="_blank">www.xanadu.cz/vyvoj</A>]]>
   <pubDate>Fri, 16 Nov 2007 09:01:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26568&amp;title=find-replace#26568</guid>
   <title><![CDATA[find/replace : Dobry den chtel bych se zeptat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26565&amp;title=find-replace#26565</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=468">KoTy</a><br /><strong>Předmět:</strong> 5484<br /><strong>Zasláno:</strong> 16.lis.2007 v 08:54<br /><br />Dobry den chtel bych se zeptat zda je mozne pomoci prikazu find<br>nahradit hromadne urcite texty napr.<br>mam nekolik cisel 4 a 3 mistnych a potrebival bych pred kazde dat tecku<br><br>1588 =&gt; .1588<br>254 =&gt; .254<br>2577 =&gt; .2577<br><br>skosel jsem zastupne znaky # @ * ale to sice najde jakekoli cislo string ale nedokazu prinutit autoced aby pridal na zacatek tu tecku<br><br>dekuji za reakce<br>]]>
   <pubDate>Fri, 16 Nov 2007 08:54:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5484&amp;PID=26565&amp;title=find-replace#26565</guid>
