  <title>CAD F&#243;rum : Hlaska</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Hlaska]]></description>
  <pubDate>Fri, 04 Sep 2026 13:39:51 +0000</pubDate>
  <lastBuildDate>Fri, 11 Jan 2008 12:38:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=5782</WebWizForums:feedURL>
   <title><![CDATA[Hlaska : sk&#250;ste si nastavi&#357; v&#228;&#269;&#353;&#237; po&#269;et...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28094&amp;title=hlaska#28094</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1675">cestár</a><br /><strong>Předmět:</strong> 5782<br /><strong>Zasláno:</strong> 11.led.2008 v 12:38<br /><br />skúste si nastavi väčí počet desatinných miest, 0,0 = 0,0 ale 0,0008 sa nerovná 0,00000]]>
   <pubDate>Fri, 11 Jan 2008 12:38:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28094&amp;title=hlaska#28094</guid>
   <title><![CDATA[Hlaska : asi USS - viz: http://www.cad...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28088&amp;title=hlaska#28088</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 5782<br /><strong>Zasláno:</strong> 11.led.2008 v 11:57<br /><br />asi USS - viz:<DIV><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=2247" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=2247</A></DIV>]]>
   <pubDate>Fri, 11 Jan 2008 11:57:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28088&amp;title=hlaska#28088</guid>
   <title><![CDATA[Hlaska : Zdravim, vietemi niekdo poradit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28087&amp;title=hlaska#28087</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=793">Janci</a><br /><strong>Předmět:</strong> 5782<br /><strong>Zasláno:</strong> 11.led.2008 v 11:52<br /><br /><P>Zdravim,</P><DIV></DIV>vietemi niekdo poradit co znamena hlaska " Usecky nejsou koplanarni"?<DIV>Mam dve roznobezne usecky a chcem ich skosit, pridadne ich mam prekrizene a chcel jednu podla druhej odstrihnut. A ocas mi vyhodi spominanu hlasku. Najprv som myslel ze to neako suvisi zo suradnicou Z, ale tu mam pri oboch useckach nulovu. Tak neviem. Pracujem v AutoCAD2008.&nbsp;</DIV>]]>
   <pubDate>Fri, 11 Jan 2008 11:52:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5782&amp;PID=28087&amp;title=hlaska#28087</guid>
