  <title>CAD F&#243;rum : Neviditelné hrany</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Neviditelné hrany]]></description>
  <pubDate>Fri, 11 Sep 2026 02:46:20 +0000</pubDate>
  <lastBuildDate>Sun, 17 Feb 2008 17:32:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=5996</WebWizForums:feedURL>
   <title><![CDATA[Neviditelné hrany : Viz tip 5187: http://www.cadf...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29311&amp;title=neviditelne-hrany#29311</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 5996<br /><strong>Zasláno:</strong> 17.úno.2008 v 17:32<br /><br />Viz tip 5187:<DIV><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=5187" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=5187</A></DIV>]]>
   <pubDate>Sun, 17 Feb 2008 17:32:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29311&amp;title=neviditelne-hrany#29311</guid>
   <title><![CDATA[Neviditelné hrany : V Registry pomoc&#237; kl&#237;&#269;e: HKCU\...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29207&amp;title=neviditelne-hrany#29207</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=915">Martin Rebenda</a><br /><strong>Předmět:</strong> 5996<br /><strong>Zasláno:</strong> 14.úno.2008 v 06:37<br /><br /><FONT>V <SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">Registry</SPAN></ACR&#079;NYM> pomocí klíče: HKCU\Software\<ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">Autodesk</SPAN></ACR&#079;NYM>\<ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">In</SPAN></ACR&#079;NYM><SPAN =kwd1>v</SPAN><ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">entor</SPAN></ACR&#079;NYM>\<ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">Registry</SPAN></ACR&#079;NYM><SPAN =kwd1>V</SPAN>ersionXX.0\System\Preferences\Display<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-: CS; mso-fareast-: CS; mso-bidi-: AR-SA">kde hodnotu <TT><SPAN style="FONT-FAMILY: Arial">Hidden Line Pattern</SPAN></TT> změňte z pů<SPAN =kwd1>v</SPAN>odní hodnoty <B>ffff</B> (resp. 3ff) na <B>fff</B> (čáry/mezery <SPAN =kwd1>v</SPAN> poměru 2:1) nebo <B>ff</B> (čáry/mezery <SPAN =kwd1>v</SPAN> poměru 1:1). Poté zno<SPAN =kwd1>v</SPAN>u spusťte <ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">In</SPAN></ACR&#079;NYM><SPAN =kwd1>v</SPAN><ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">entor</SPAN></ACR&#079;NYM>. Podmínkou zobrazení skrytých hran <FONT>jsou zapnuté <SPAN =kwd1>v</SPAN>olby "Skryté <SPAN =kwd1>hrany</SPAN>" <SPAN =kwd1>v</SPAN> Možnosti &gt; Nasta<SPAN =kwd1>v</SPAN>ení aplikace &gt; Zobrazení. <SPAN =kwd1><SPAN style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-: CS; mso-fareast-: CS; mso-bidi-: AR-SA">V</SPAN></SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-: CS; mso-fareast-: CS; mso-bidi-: AR-SA"> <ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">In</SPAN></ACR&#079;NYM><SPAN =kwd1>v</SPAN><ACR&#079;NYM><SPAN style="FONT-FAMILY: Arial">entor</SPAN></ACR&#079;NYM>u 2008 je na<SPAN =kwd1>v</SPAN>íc potřeba <SPAN =kwd1>v</SPAN>ypnout <SPAN =kwd1>v</SPAN>olbu "Zobrazit skryté <SPAN =kwd1>hrany</SPAN> jako těleso" (myšleno "jako plné") <SPAN =kwd1>v</SPAN>e <SPAN =kwd1>v</SPAN>ýše u<SPAN =kwd1>v</SPAN>edeném dialogu.</SPAN></FONT></SPAN></FONT>]]>
   <pubDate>Thu, 14 Feb 2008 06:37:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29207&amp;title=neviditelne-hrany#29207</guid>
   <title><![CDATA[Neviditelné hrany : Dobr&#253; den!Jak postupovat u Inventoru...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29205&amp;title=neviditelne-hrany#29205</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=14">honsa</a><br /><strong>Předmět:</strong> 5996<br /><strong>Zasláno:</strong> 13.úno.2008 v 19:55<br /><br />Dobrý den!<br>Jak postupovat u Inventoru 2008, pokud chci viděl neviditelné hrany u IPT modelu čarou přerušovanou při drátovém pohledu. U Inventoru profesional 10 se bezproblémově změnila v registrech hodnota koncovky hexadecimálního čísla ffff na fff (jedno f se ubralo). Ale pro 2008 (12) je na stejném místě v registru koncovka&nbsp; 3ff celé&nbsp; v desítkové soustavě 1023.<br>Děkuji nejen za sebe. Josef <br>]]>
   <pubDate>Wed, 13 Feb 2008 19:55:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=5996&amp;PID=29205&amp;title=neviditelne-hrany#29205</guid>
