  <title>CAD F&#243;rum : Změna typu čáry - Autolisp</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : Změna typu čáry - Autolisp]]></description>
  <pubDate>Sat, 15 Aug 2026 16:25:52 +0000</pubDate>
  <lastBuildDate>Fri, 11 Apr 2008 20:01:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=6310</WebWizForums:feedURL>
   <title><![CDATA[Změna typu čáry - Autolisp : Mas to u me WarCZ... diky moc....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30815&amp;title=zmena-typu-cary-autolisp#30815</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7456">MarS</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 11.dub.2008 v 20:01<br /><br />Mas to u me WarCZ... diky moc.]]>
   <pubDate>Fri, 11 Apr 2008 20:01:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30815&amp;title=zmena-typu-cary-autolisp#30815</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : (command &amp;#034;_rotate&amp;#034; polygon...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30814&amp;title=zmena-typu-cary-autolisp#30814</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7568">WarCZ</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 11.dub.2008 v 19:52<br /><br />(command "_rotate" polygon "" bodA 180 "")<br><br>Polygon - entita<br>bodA - bod kolem ktere otačim<br>]]>
   <pubDate>Fri, 11 Apr 2008 19:52:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30814&amp;title=zmena-typu-cary-autolisp#30814</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : Jak tak vidim tak uz deolas krychlu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30813&amp;title=zmena-typu-cary-autolisp#30813</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7456">MarS</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 11.dub.2008 v 19:09<br /><br />Jak tak vidim tak uz deolas krychlu :-) Tu uz mam hotovou jen me trapi jeden prikaz ve 2D modelu _rotate(otoceni) Nevite nahodou nekdo jak by mel vypadat prikaz pro pootoceni vepsaneho trojuhelnika o 60 stupnu ajako referencni bod pouzivam stred kruznice ktery mam definovany jako S a Trojuhelnik pojmenovany jako TR?? budu vdecny za kazdou radu. <br />muj kod: <strong>(defun C:kruh ()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(setq s (getpoint "Zadej stred:"))<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(setq r (getint " zadej polomer kruznice: "))<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(command "_circle" s r )<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(command "_polygon" 3 s "_i" r)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(setq tr (entlast))<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(command "_rotate" "tr" s 60)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />)</strong><br /><br />nejak nevim jak to napsat nebo spis kde delam chybu v tomhle su spis samouk..<span style="font-size:10px"><br /><br />Upravil MarS - 11.dub.2008 v 19:12</span>]]>
   <pubDate>Fri, 11 Apr 2008 19:09:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30813&amp;title=zmena-typu-cary-autolisp#30813</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : Pro&#353;el jsem ten lisp. M&#225;te tam...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30765&amp;title=zmena-typu-cary-autolisp#30765</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 15:10<br /><br /><DIV>Prošel jsem ten lisp. Máte tam opačně neviditelné hrany (namísto vzadu jsou vpředu).&nbsp;Lisp jsem trošku poopravil (ale asi to měl dělat Váš profesor, který Vás učí...) <img src="http://www.cadforum.cz/forum/smileys/smiley33.gif" height="17" width="17" border="0" align="absmiddle" alt="Ying%20Yang" /></DIV><DIV><a href="uploads/20080410_150755_pavel.lsp" target="_blank" rel="nofollow">zde je</A></DIV><DIV><strong>OT:</strong> Klobouk dolů před Vašim dědečkem!</DIV>]]>
   <pubDate>Thu, 10 Apr 2008 15:10:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30765&amp;title=zmena-typu-cary-autolisp#30765</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : d&#283;dovi je p&#345;es 70. Ohledn&#283; historie...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30761&amp;title=zmena-typu-cary-autolisp#30761</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7568">WarCZ</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 14:04<br /><br />dědovi je přes 70. Ohledně historie PC nema asi konkurenci. Doma ma 4 PC kdy ted posledni s Win XP a autocadem 2008. Aktivně konstruuje ( a pracuje ) a ma hromadu programu v Basicu na konstrukci. Ted se uči Cčko a ten autocad. Ja ho obdivuju pro něho je přechod z Win 98 na Win XP běh na dlouhou trať kdy si prvně přečetl tu 800 strankovou bibli. tak samo autocad...<br>]]>
   <pubDate>Thu, 10 Apr 2008 14:04:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30761&amp;title=zmena-typu-cary-autolisp#30761</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : :-) J&#243; pane, aktivn&#237; v&#283;k se prodlu&#382;uje....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30760&amp;title=zmena-typu-cary-autolisp#30760</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=54">Seiner</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 14:01<br /><br />:-) Jó pane, aktivní věk se prodlužuje. Já znám jednu rodinu, kde aktivně projektují 3 generace. A dědeček hravě strčí spoustu mlamojů do kapsy.]]>
   <pubDate>Thu, 10 Apr 2008 14:01:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30760&amp;title=zmena-typu-cary-autolisp#30760</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : OT: Kolikpak je tomu d&#283;de&#269;kovi?...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30759&amp;title=zmena-typu-cary-autolisp#30759</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 13:57<br /><br /><strong>OT:</strong> Kolikpak je tomu dědečkovi? Žeby nějaký zdatný důchodce?]]>
   <pubDate>Thu, 10 Apr 2008 13:57:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30759&amp;title=zmena-typu-cary-autolisp#30759</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : mockrat vam d&#283;kuji za pomoc tak...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30735&amp;title=zmena-typu-cary-autolisp#30735</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7568">WarCZ</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 09:56<br /><br />mockrat vam děkuji za pomoc tak hluboko to zatim řešit nemusim. určitě sem odkažu meho dědu, ktery bojuje už mnoho let s autocadem a konečně se připojil na internet. Mockrát všem děkuji a přeji pěkny den.<br>]]>
   <pubDate>Thu, 10 Apr 2008 09:56:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30735&amp;title=zmena-typu-cary-autolisp#30735</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : zapis je dob&#345;e, jinak to zjstite,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30734&amp;title=zmena-typu-cary-autolisp#30734</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21">svarc.vl</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 09:47<br /><br />zapis je dobře, jinak to zjstite, že řadek napišete přímo do příkazové řádky Autocadu. Když je to dobře vrátí Vám autocad hodnotu jinak napíše chybu. Taky by šlo měřítko čáry počítak z hrany krychle jako nějaký podíl]]>
   <pubDate>Thu, 10 Apr 2008 09:47:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30734&amp;title=zmena-typu-cary-autolisp#30734</guid>
   <title><![CDATA[Změna typu čáry - Autolisp : jo bylo to tim to m&#283; vubec nenapadalo......]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30732&amp;title=zmena-typu-cary-autolisp#30732</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7568">WarCZ</a><br /><strong>Předmět:</strong> 6310<br /><strong>Zasláno:</strong> 10.dub.2008 v 09:36<br /><br />jo bylo to tim to mě vubec nenapadalo...&nbsp; <br><br>Je tenhle zapis dobře ? <br>(setvar "<font face="Tahoma, Arial, Sans serif">LTSCALE" 0.5 ) <br><br>jde mi o to že je čara v mem rozměru jenom jednou přerušena ale i tak diky je to pro mě velky pokrok...<br></font>]]>
   <pubDate>Thu, 10 Apr 2008 09:36:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6310&amp;PID=30732&amp;title=zmena-typu-cary-autolisp#30732</guid>
