  <title>CAD F&#243;rum : Popis vrstevnic</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Civil 3D, Map, InfraWorks, GIS : Popis vrstevnic]]></description>
  <pubDate>Sun, 04 Oct 2026 05:38:10 +0000</pubDate>
  <lastBuildDate>Tue, 29 Apr 2008 14:48:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=6430</WebWizForums:feedURL>
   <title><![CDATA[Popis vrstevnic : POVRCHY -- P&#344;IDAT POPISKY POVRCHU...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31283&amp;title=popis-vrstevnic#31283</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1287">Romain</a><br /><strong>Předmět:</strong> 6430<br /><strong>Zasláno:</strong> 29.dub.2008 v 14:48<br /><br />POVRCHY -- PŘIDAT POPISKY POVRCHU -- VRSTEVNICE-VÍCENÁSOBNÁ]]>
   <pubDate>Tue, 29 Apr 2008 14:48:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31283&amp;title=popis-vrstevnic#31283</guid>
   <title><![CDATA[Popis vrstevnic : Viz tip 6114 a dal&#353;&#237; P&#345;&#237;buzn&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31281&amp;title=popis-vrstevnic#31281</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 6430<br /><strong>Zasláno:</strong> 29.dub.2008 v 12:20<br /><br />Viz <a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=6114" target="_blank">tip 6114</A> a další Příbuzné tipy.]]>
   <pubDate>Tue, 29 Apr 2008 12:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31281&amp;title=popis-vrstevnic#31281</guid>
   <title><![CDATA[Popis vrstevnic : Dobr&#253; den, sna&#382;&#237;m se vy&#345;e&#353;it...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31280&amp;title=popis-vrstevnic#31280</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=7982">luky6</a><br /><strong>Předmět:</strong> 6430<br /><strong>Zasláno:</strong> 29.dub.2008 v 11:43<br /><br />Dobrý den,<DIV>snažím se vyřešit takovou banalitku. mám vytvořený povrch z bodů a povinných spojnic. Styl povrchu zadám <EM>Hranice &amp; Vrstevnice.</EM> Všechno je OK, můžu měnit intervaly vrstevnic atd., ale potřeboval bych, aby vrstevnice měli popisky, kvůli snazší orientaci ve zpracovávaném prostoru. Jak na to? Zkoušel jsem přidat popisky, po jedný vrstevnici to jde ale globálně pro celej povrch nevím jak.</DIV><DIV>Díky za pomoc.</DIV>]]>
   <pubDate>Tue, 29 Apr 2008 11:43:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6430&amp;PID=31280&amp;title=popis-vrstevnic#31280</guid>
