  <title>CAD F&#243;rum : dwg do cdr convert</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : dwg do cdr convert]]></description>
  <pubDate>Wed, 04 Nov 2026 08:04:09 +0000</pubDate>
  <lastBuildDate>Thu, 07 Aug 2008 21:11:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=6949</WebWizForums:feedURL>
   <title><![CDATA[dwg do cdr convert : zkuste ten WMF a nebo DXF pro...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33969&amp;title=dwg-do-cdr-convert#33969</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 6949<br /><strong>Zasláno:</strong> 07.srp.2008 v 21:11<br /><br />zkuste ten WMF a nebo DXF pro ruzne verze]]>
   <pubDate>Thu, 07 Aug 2008 21:11:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33969&amp;title=dwg-do-cdr-convert#33969</guid>
   <title><![CDATA[dwg do cdr convert : skusal som vyhladat ale nejak...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33968&amp;title=dwg-do-cdr-convert#33968</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9561">peto84</a><br /><strong>Předmět:</strong> 6949<br /><strong>Zasláno:</strong> 07.srp.2008 v 21:05<br /><br />skusal som vyhladat ale nejak mi nevedelo najst spravnu temu tu vo fore...<br><br>v coreli som skusal otvorit dwg, bola tam ta ponuka len corel mam 8 a autoCAD 2008, takze ho nevedel otvorit, ked som skusal ulozit ako dwg pre AC 2000 tak aj tak mi to nevedel corel otvorit, ale idem nainstalovat skusobnu verziu corel draw graphics suite X4 - to najnovsi corel, mozno to tam pojde, zatial dakujem za pomoc, ked to nepojde dam vediet.<br>]]>
   <pubDate>Thu, 07 Aug 2008 21:05:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33968&amp;title=dwg-do-cdr-convert#33968</guid>
   <title><![CDATA[dwg do cdr convert : Uz se to tu nekolikrat resilo....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33967&amp;title=dwg-do-cdr-convert#33967</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 6949<br /><strong>Zasláno:</strong> 07.srp.2008 v 20:56<br /><br />Uz se to tu nekolikrat resilo. Zkusil jste hledat v historii? <br><br>Corel umi precist DXF a jestli se nepletu tak i DWG. Nejlepsi zkusenosti mam ale s WMF.<br>]]>
   <pubDate>Thu, 07 Aug 2008 20:56:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33967&amp;title=dwg-do-cdr-convert#33967</guid>
   <title><![CDATA[dwg do cdr convert : Dobry den, som uzivatel zaciatocnik...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33966&amp;title=dwg-do-cdr-convert#33966</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9561">peto84</a><br /><strong>Předmět:</strong> 6949<br /><strong>Zasláno:</strong> 07.srp.2008 v 20:47<br /><br />Dobry den, som uzivatel zaciatocnik a potrebujem poradit ako prekonvertujem autoCAD subor s priponou DWG do CorelDRAW suboru pripony cdr.&nbsp;]]>
   <pubDate>Thu, 07 Aug 2008 20:47:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=6949&amp;PID=33966&amp;title=dwg-do-cdr-convert#33966</guid>
