  <title>CAD F&#243;rum : SPELL</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : SPELL]]></description>
  <pubDate>Tue, 15 Sep 2026 08:38:29 +0000</pubDate>
  <lastBuildDate>Mon, 05 Jan 2009 15:55:46 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=7833</WebWizForums:feedURL>
   <title><![CDATA[SPELL : HM. Potom, ale IMHO potom by v...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39501&amp;title=spell#39501</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=148">j.matel</a><br /><strong>Předmět:</strong> 7833<br /><strong>Zasláno:</strong> 05.led.2009 v 15:55<br /><br />HM. Potom, ale IMHO potom by v Custom instalacii nemala byt moznost neinstalovat slovniky, ked to bez nich "nefunguje". Dik.]]>
   <pubDate>Mon, 05 Jan 2009 15:55:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39501&amp;title=spell#39501</guid>
   <title><![CDATA[SPELL : Slovn&#237;k se nastavuje prom&#283;nnou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39484&amp;title=spell#39484</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 7833<br /><strong>Zasláno:</strong> 05.led.2009 v 11:47<br /><br />Slovník se nastavuje proměnnou &#091;VAR&#093;DCTMAIN&#091;/VAR&#093;. Slovník ale bude potřeba - stačí jej i nakopírovat (např. CSY.DCT).]]>
   <pubDate>Mon, 05 Jan 2009 11:47:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39484&amp;title=spell#39484</guid>
   <title><![CDATA[SPELL : Nainstaloval som 2009LT bez pravopisu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39483&amp;title=spell#39483</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=148">j.matel</a><br /><strong>Předmět:</strong> 7833<br /><strong>Zasláno:</strong> 05.led.2009 v 10:58<br /><br />Nainstaloval som 2009LT bez pravopisu - slovnikov, (tak ako doposial pri starsich verziach) a teraz pri pokuse upravoat text sa vzdy zobrazi dialog s informaciou, ze nemoze byt spustena kontrola pravopisu lebo nie je k dispozicii slovnik.<br><br>K nastaveniam sa vsak nedostanem, pretoze nemam hlavny slovnik. Da sa to zrusit aj bez doinstalovania slovnikov?<br>]]>
   <pubDate>Mon, 05 Jan 2009 10:58:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7833&amp;PID=39483&amp;title=spell#39483</guid>
