  <title>CAD F&#243;rum : Pomoc-Fatal Error</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Pomoc-Fatal Error]]></description>
  <pubDate>Mon, 02 Nov 2026 09:32:44 +0000</pubDate>
  <lastBuildDate>Tue, 27 Jan 2009 09:42:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=7978</WebWizForums:feedURL>
   <title><![CDATA[Pomoc-Fatal Error : p.Michel:dakujem,aspon ste mi...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40293&amp;title=pomocfatal-error#40293</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10589">Pet5</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 27.led.2009 v 09:42<br /><br /><P>p.Michel:dakujem,aspon ste mi urobili dobru naladu zavcas rana. :)</P>]]>
   <pubDate>Tue, 27 Jan 2009 09:42:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40293&amp;title=pomocfatal-error#40293</guid>
   <title><![CDATA[Pomoc-Fatal Error : to alfred: dakujem,audit pomohol....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40292&amp;title=pomocfatal-error#40292</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10589">Pet5</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 27.led.2009 v 09:40<br /><br />to alfred: dakujem,audit pomohol.]]>
   <pubDate>Tue, 27 Jan 2009 09:40:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40292&amp;title=pomocfatal-error#40292</guid>
   <title><![CDATA[Pomoc-Fatal Error : .. aneb: neotravuj a sna&#382; se p&#345;ij&#237;t...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40290&amp;title=pomocfatal-error#40290</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 27.led.2009 v 09:28<br /><br />.. aneb:<EM> neotravuj a snaž se přijít na to, jak ten motor z Trabanta namontovat do Octavie, ať nám nemusí dodávat ten správný</EM>]]>
   <pubDate>Tue, 27 Jan 2009 09:28:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40290&amp;title=pomocfatal-error#40290</guid>
   <title><![CDATA[Pomoc-Fatal Error : Bohuzial,s takymito vykresmi pracujem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40287&amp;title=pomocfatal-error#40287</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10589">Pet5</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 27.led.2009 v 09:25<br /><br />Bohuzial,s takymito vykresmi pracujem denno-denne. Viem si predstavit,keby som poprosila kolegov,aby prosili klientov poslat ich v inom formate,tak by som tak dostala odpoved:Neotravuj a snaz sa prist na to,ako to urobit,aby si nemusela pytat ine formaty. :( <DIV>Tak sa musim trapit s tymto.</DIV>]]>
   <pubDate>Tue, 27 Jan 2009 09:25:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40287&amp;title=pomocfatal-error#40287</guid>
   <title><![CDATA[Pomoc-Fatal Error : Takov&#233;to chyby b&#253;vaj&#237; typick&#253;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40274&amp;title=pomocfatal-error#40274</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 26.led.2009 v 18:45<br /><br />Takovéto chyby bývají typickým důsledkem použití výkresu v nesprávném formátu (přípona je DWG, ale vnitřní formát neodpovídá DWG). Bohužel Audit/Recover nemusí nutně odhalit všechny podvratnosti, takže asi nepomůže.<DIV></DIV>Požádejte dodavatele o soubor v pravém formátu Autodesk DWG nebo raději v jeho textové verzi - DXF.]]>
   <pubDate>Mon, 26 Jan 2009 18:45:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40274&amp;title=pomocfatal-error#40274</guid>
   <title><![CDATA[Pomoc-Fatal Error : ve vlastn&#237;m v&#253;kresu i v&#269;ech p&#345;ipojen&#253;ch...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40273&amp;title=pomocfatal-error#40273</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 26.led.2009 v 18:10<br /><br />ve vlastním výkresu i včech připojených xrefech:<br><br>diagnostika výkresu -&nbsp;&#091;CMD&#093;DIAG&#091;/CMD&#093; <em>(_AUDIT)</em><br>restaurování výkresu - &#091;CMD&#093;RESTAURUJ&#091;/CMD&#093; <em>(_RECOVER)</em><br>vyčištění výkresu - &#091;CMD&#093;ČISTI&#091;/CMD&#093; <em>(_PURGE)</em><br><br>smazat filtry a přebytečná měřítka<br><br>případně zkusit vytisknout do DWF a na tiskárnu poslat až to.<br>]]>
   <pubDate>Mon, 26 Jan 2009 18:10:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40273&amp;title=pomocfatal-error#40273</guid>
   <title><![CDATA[Pomoc-Fatal Error : Nepom&#225;h&#225; ani rekonstrukce dat,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40272&amp;title=pomocfatal-error#40272</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=3130">zdrk</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 26.led.2009 v 18:07<br /><br />Nepomáhá ani rekonstrukce dat, případně zkuste obsah výkresu přenést do nového výkresu.<br />Původní výkres může obsahovat např. proxy entity, které se vašemu cadu nelíbí.]]>
   <pubDate>Mon, 26 Jan 2009 18:07:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40272&amp;title=pomocfatal-error#40272</guid>
   <title><![CDATA[Pomoc-Fatal Error : Zatial sa to deje len pri jednom...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40271&amp;title=pomocfatal-error#40271</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10589">Pet5</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 26.led.2009 v 17:55<br /><br />Zatial sa to deje len pri jednom konkretnom vykrese. Vyskusala som tlacit iny a to slo v pohode.]]>
   <pubDate>Mon, 26 Jan 2009 17:55:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40271&amp;title=pomocfatal-error#40271</guid>
   <title><![CDATA[Pomoc-Fatal Error : Dobry vecer,  poprosim o radu....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40270&amp;title=pomocfatal-error#40270</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10589">Pet5</a><br /><strong>Předmět:</strong> 7978<br /><strong>Zasláno:</strong> 26.led.2009 v 17:54<br /><br />Dobry vecer,<DIV>&nbsp;</DIV><DIV>poprosim o radu. Cely den som robila s vykresmi od toho isteho klienta.Vyzeraju,ze nie su v Autodesk aplikacii robene.</DIV><DIV>&nbsp;</DIV><DIV>Teraz,pri poslednom vykrese,ked som si dala pred tlacou nahlad,strasne sa autocad spomalil a v nahlade bolo pozadie cierne - ako ho mam v modeli. Ked som to skusila dat vytlacit,vyskocila hlaska:</DIV><DIV>&nbsp;</DIV><DIV>Fatal Error: Unhandled e06d7363h exception at 7c812aebh.</DIV><DIV>&nbsp;</DIV><DIV>Restartla som comp-nepomohlo, service pack mam nainstalovany. Kde je problem?</DIV><DIV>&nbsp;</DIV><DIV>Dakujem.</DIV>]]>
   <pubDate>Mon, 26 Jan 2009 17:54:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=7978&amp;PID=40270&amp;title=pomocfatal-error#40270</guid>
