  <title>CAD F&#243;rum : Pevnostná analýza</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Pevnostná analýza]]></description>
  <pubDate>Sun, 13 Sep 2026 15:37:15 +0000</pubDate>
  <lastBuildDate>Mon, 09 Feb 2009 13:35:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=8058</WebWizForums:feedURL>
   <title><![CDATA[Pevnostná analýza :     &amp;lt;&amp;gt;  /* Style Definitions...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40742&amp;title=pevnostna-analyza#40742</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=5243">pepet</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 09.úno.2009 v 13:35<br /><br /><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow"><!-- /* Style Definiti&#111;ns */ p.Ms&#111;normal, li.Ms&#111;normal, div.Ms&#111;normal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-paginati&#111;n:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-:CS; mso-fareast-:CS;}a:, span.MsoHyper {color:blue; text-decorati&#111;n:underline; text-underline:single;}a:visited, span.MsoHyperFollowed {color:purple; text-decorati&#111;n:underline; text-underline:single;}@page Secti&#111;n1 {size:21.0cm 842.0pt; margin:17.85pt 38.0pt 17.85pt 37.35pt; mso-er-margin:35.45pt; mso-footer-margin:35.45pt; mso-paper-source:0;}div.Secti&#111;n1 {page:Secti&#111;n1;}--><!--&#091;if gte mso 10&#093;><> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Normální tabulka";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-parent:"";	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;	mso-para-margin:0cm;	mso-para-margin-bottom:.0001pt;	mso-pagination:widow-orphan;	font-size:10.0pt;	font-family:"Times New Roman";	mso-ansi-language:#0400;	mso-fareast-language:#0400;	mso-bidi-language:#0400;}<!&#091;endif&#093;--></a><div><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Podľa toho čo som odskúšalnie je problém s odvodenou súčasťou ale s spojitosťou geometrie. <br>Napríkladpri konštrukcii tvaru U&nbsp;z&nbsp;jaklov spojených čelo s&nbsp;bokom nevedel vytvoriťsieť, ale ak sú rohy zrezané pod 45 st. tak výpočet prebehne na odvodenej súčasti zo zostavy.</a></div><div><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Ťažko povedať či Vaša konštrukciasa dá spočítať v&nbsp;AIP, ale skúste nespojitosti vyplniť zvarmi alebo inakvymodelovať a&nbsp;až potom odvodiť, poprípade vymodelovať v odvodenej súčasti, možno pomôže.<br><br></a></div><div><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Ďalšia možnosť je použiť vyššístupeň a&nbsp;to ANSYS Workbench, ten vie pracovať so zostavami alebo stiahnuťzo </a><a href="http://labs.autodesk.com/technologies/advanced_simulati&#111;n/" target="_blank" rel="nofollow">http://labs.autodesk.com/technologies/advanced_simulation/</a>rozšírenie aj to vie pracovať so zostavami (kontakty), len pre AIP 2009 32 / 64bit.</div><span style="font-size:10px"><br /><br />Upravil pepet - 09.úno.2009 v 13:38</span>]]>
   <pubDate>Mon, 09 Feb 2009 13:35:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40742&amp;title=pevnostna-analyza#40742</guid>
   <title><![CDATA[Pevnostná analýza : Pr&#225;v&#283; jsem provedl pevnostn&#237; anal&#253;zu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40736&amp;title=pevnostna-analyza#40736</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=71">Pavel Žáček</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 09.úno.2009 v 13:03<br /><br />Právě jsem provedl pevnostní analýzu součásti, která vznikla jako odvozená součást ze sestavy. AIP2008 nehlásil žádné omezení. Součást ani nebyla od původní sestavy odpojená, takže po úpravě sestavy ji lze aktualizovat a znovu přepočítat.]]>
   <pubDate>Mon, 09 Feb 2009 13:03:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40736&amp;title=pevnostna-analyza#40736</guid>
   <title><![CDATA[Pevnostná analýza : Inventor neumoznuje provadet pevnostni...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40733&amp;title=pevnostna-analyza#40733</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=2854">Radek001</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 09.úno.2009 v 12:00<br /><br />Inventor neumoznuje provadet pevnostni analyzu v sestavach (*.iam), ale pouze v dilech *.ipt. Kdysi jsem zkousel analyzovat sestavu ulozenu jako odvozene teleso, neslo mi to. Pokud vím, ani posledni verze 2009 nezmenila toto omezeni.<DIV>Takze pro analyzu jednoznacne ulozit / modelovat jako jeden part.</DIV><DIV>Rad</DIV>]]>
   <pubDate>Mon, 09 Feb 2009 12:00:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40733&amp;title=pevnostna-analyza#40733</guid>
   <title><![CDATA[Pevnostná analýza : a ked je to zvarana konstrukcia...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40729&amp;title=pevnostna-analyza#40729</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10537">murgy</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 09.úno.2009 v 11:37<br /><br />a ked je to zvarana konstrukcia z jaklov, mam si to ulozit ako jeden part alebo to mozem zatazit aj ako celok? ]]>
   <pubDate>Mon, 09 Feb 2009 11:37:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40729&amp;title=pevnostna-analyza#40729</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40725&amp;title=pevnostna-analyza#40725</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=5243">pepet</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 09.úno.2009 v 11:09<br /><br /><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow"><!-- /* Style Definiti&#111;ns */ p.Ms&#111;normal, li.Ms&#111;normal, div.Ms&#111;normal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-paginati&#111;n:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-:CS; mso-fareast-:CS;}@page Secti&#111;n1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-er-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;}div.Secti&#111;n1 {page:Secti&#111;n1;}--><!--&#091;if gte mso 10&#093;><> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Normální tabulka";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-parent:"";	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;	mso-para-margin:0cm;	mso-para-margin-bottom:.0001pt;	mso-pagination:widow-orphan;	font-size:10.0pt;	font-family:"Times New Roman";	mso-ansi-language:#0400;	mso-fareast-language:#0400;	mso-bidi-language:#0400;}<!&#091;endif&#093;--></a><p><span style=""><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Pokiaľ má&nbsp;sila lenjednu zložku a&nbsp;to kolmú na danú plochu, ktorá je rovinná, tak je podľa mňajedno ktorý zo spôsobov ( sila / tlak) zvolíte. Osobne by som použil silu.<o:p></o:p></a></span></p><p><span style=""><o:p><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">&nbsp;</a></o:p></span></p><p><span style=""><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Spôsob zaťaženie tlakomby som použil, napr. ak by bol určitý nosník zakrúžený (čiastočne zakrúžený) a&nbsp;niesolby nádrž s&nbsp;tekutinou, sypkým materiálom, vtedy je zaťaženie radiálne na zakrúženýnosník a&nbsp;treba použiť tlak a&nbsp;nie silu.<o:p></o:p></a></span></p><p><span style=""><o:p><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">&nbsp;</a></o:p></span></p><span style="font-size: 12pt; font-family: &quot;Times New Roman&quot;;"><a href="file:///C:%5CDOCUME%7E1%5Cpetert%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" target="_blank" rel="nofollow">Keď zaťažíte jednu plochu silou napr. 10N alebo tuto plochu rozdelíte nadve a&nbsp;obe plochy použijete pri výbere tej istej sily tak reakcia je stálelen 10N. Z&nbsp;toho vyplýva že by malo byt jedno na koľko plôch aplikujete zaťažujúcusilu (nenásobí sa sila počtom plôch). Ale v&nbsp;každom prípade si to treba skontrolovaťv&nbsp;reakciách (cez pravé tlačitko -&gt; Reakčné sily).</a></span><span style="font-size:10px"><br /><br />Upravil pepet - 09.úno.2009 v 11:10</span>]]>
   <pubDate>Mon, 09 Feb 2009 11:09:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40725&amp;title=pevnostna-analyza#40725</guid>
   <title><![CDATA[Pevnostná analýza : Zdrav&#237;m chcel by som sa sp&#253;ta&#357;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40709&amp;title=pevnostna-analyza#40709</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10537">murgy</a><br /><strong>Předmět:</strong> 8058<br /><strong>Zasláno:</strong> 08.úno.2009 v 15:52<br /><br />Zdravím<br />chcel by som sa spýtať na pevnostnú analýzu. Mám vymodelovaný taký stojan z jaklov, chcem ho zaťažiť hmotnosťou 800kg. problém mám v tom že neviem ako. mám to zaťažiť tlakom alebo silou? ak zaťažím všetky stykové plochy tak mám tlak alebo silu ktorou to zaťažujem podeliť počtom plôch alebo ako?<br />ak bude treba tak dodam aj obrazok ak som to nenapisal dosť jasne :)<br />vopred dakujem]]>
   <pubDate>Sun, 08 Feb 2009 15:52:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8058&amp;PID=40709&amp;title=pevnostna-analyza#40709</guid>
