  <title>CAD F&#243;rum : Priehladnost objektov</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Architecture, MEP, Fabrication, Plant 3D : Priehladnost objektov]]></description>
  <pubDate>Wed, 07 Oct 2026 05:41:51 +0000</pubDate>
  <lastBuildDate>Thu, 12 Feb 2009 01:04:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=8065</WebWizForums:feedURL>
   <title><![CDATA[Priehladnost objektov : podarilo sa mi &amp;#034;objavit&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40857&amp;title=priehladnost-objektov#40857</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 12.úno.2009 v 01:04<br /><br />podarilo sa mi "objavit" ako sa to da. je to jednoduche, stacilo zmenit material v properties/design/3d visualization/material...<br><br><br>Pani, dakujem za radu <img src="https://www.cadforum.cz/forum/smileys/smiley32.gif" border="0" align="absmiddle" alt="Clap" /><br>]]>
   <pubDate>Thu, 12 Feb 2009 01:04:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40857&amp;title=priehladnost-objektov#40857</guid>
   <title><![CDATA[Priehladnost objektov : skusal som teda tento prikaz,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40856&amp;title=priehladnost-objektov#40856</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 12.úno.2009 v 00:47<br /><br />skusal som teda tento prikaz, ale je to v podstate len prikaz na zmenu vizualneho stylu, podobne ako cez visual style manager. su tam zakladne vizualne styly a moznost vybrat i "other" (Enter an option &#091;2dwireframe/3dwireframe/3dHidden/Realistic/Conceptual/Other&#093; <br>&lt;2dwireframe&gt;:) alebo mnou nadefinovane a tam sa da nadefinovat na dany styl len globalna priehladnost, teda na cely dany vizualny styl. <br>Je moznost ako bolo spomenute vyssi k tomu priradit material a ten by mal ako vlastnost priehladnost. <br>To je ale iba teoria ktoru prakticky neovladam, teda neviem ako by sa to malo dat pouzit v rezime modelovania.<br>Dakujem za zaujem o tuto temu.<br>]]>
   <pubDate>Thu, 12 Feb 2009 00:47:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40856&amp;title=priehladnost-objektov#40856</guid>
   <title><![CDATA[Priehladnost objektov : Ale i v re&#382;imu modelov&#225;n&#237; p&#345;eci...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40787&amp;title=priehladnost-objektov#40787</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 10.úno.2009 v 09:15<br /><br />Ale i v režimu modelování přeci můžete zobrazit 3D objekty s jejich materiálovými vlastnostmi - viz &#091;CMD&#093;SHADEMODE&#091;/CMD&#093;. "Skleněné" objekty pak budou průhledné.]]>
   <pubDate>Tue, 10 Feb 2009 09:15:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40787&amp;title=priehladnost-objektov#40787</guid>
   <title><![CDATA[Priehladnost objektov : Dakujem za typ.To je ale v pripade...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40767&amp;title=priehladnost-objektov#40767</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 09.úno.2009 v 21:43<br /><br />Dakujem za typ.<br>To je ale v pripade renderingu. Mna zaujima ci je to mozne i v rezime modelovania. V 3d Max je mozne upravit vlastnost kazdeho jedneho objektu.(napr. priehladnost)<br>&nbsp;Napadlo ma ci to nie je tak i CAD.]]>
   <pubDate>Mon, 09 Feb 2009 21:43:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40767&amp;title=priehladnost-objektov#40767</guid>
   <title><![CDATA[Priehladnost objektov : Ide to rie&#353;i&#357; cez priraden&#253; materi&#225;l,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40764&amp;title=priehladnost-objektov#40764</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=569">Marián Mošať</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 09.úno.2009 v 20:54<br /><br />Ide to riešiť cez priradený materiál, ktorý má nadefinovanú priehľadnosť AEC objektu.<br>&nbsp;]]>
   <pubDate>Mon, 09 Feb 2009 20:54:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40764&amp;title=priehladnost-objektov#40764</guid>
   <title><![CDATA[Priehladnost objektov : Potreboval by som urcite objekty...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40731&amp;title=priehladnost-objektov#40731</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8065<br /><strong>Zasláno:</strong> 09.úno.2009 v 11:57<br /><br />Potreboval by som urcite objekty vo vykrese spriehladnit. Vo Vizual Style manager je mozne spriehladnit vsetky objekty. Je nejaka moznost urobit niektore objekty priehladne a ine nie? Napr. cast budovy bude nepriehladna, strecha a krov priehladna?]]>
   <pubDate>Mon, 09 Feb 2009 11:57:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8065&amp;PID=40731&amp;title=priehladnost-objektov#40731</guid>
