  <title>CAD F&#243;rum : problem s tlacou</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Architecture, MEP, Fabrication, Plant 3D : problem s tlacou]]></description>
  <pubDate>Fri, 09 Oct 2026 22:58:56 +0000</pubDate>
  <lastBuildDate>Fri, 06 Mar 2009 15:46:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=8228</WebWizForums:feedURL>
   <title><![CDATA[problem s tlacou : ked som sa snazil ich konvertovat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41735&amp;title=problem-s-tlacou#41735</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8228<br /><strong>Zasláno:</strong> 06.bře.2009 v 15:46<br /><br />ked som sa snazil ich konvertovat napisalo mi toto:<br />AutoCAD<br />---------------------------<br />Aec standard.stb does not contain a color mapping table and<br />cannot be used to convert drawings. Select a different<br />named plot style table.<br />---------------------------<br />OK&nbsp;&nbsp;&nbsp;<br />---------------------------<br /><br />musel som adresar Plot styles nakopirovat na C:\Documents and Settings\cadpc\Application Data\Autodesk\ACD-A 2008\enu\Plot Styles  inak boli v  c:\Documents and Settings\All Users\Application Data\Autodesk\ACD-A 2008\enu\<br /><br /><br />inak su to presne tie prikazy a este jeden na covert ctb suborov<br />CONVERTCTB<br /><br />dakujem pomohli ste. <img src="https://www.cadforum.cz/forum/smileys/smiley20.gif" border="0" align="middle" /> ]]>
   <pubDate>Fri, 06 Mar 2009 15:46:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41735&amp;title=problem-s-tlacou#41735</guid>
   <title><![CDATA[problem s tlacou :   Buba napsal(a): _CONVERTPSTYLES nastav&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41730&amp;title=problem-s-tlacou#41730</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=638">chose</a><br /><strong>Předmět:</strong> 8228<br /><strong>Zasláno:</strong> 06.bře.2009 v 14:37<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Buba" alt="Původně odeslal(a) Buba" style="vertical-align: text-bottom;" /> <strong>Buba napsal(a):</strong><br /><br /><P><FONT style="COLOR: black">_CONVERT</FONT>PSTYLES</P><DIV>nastaví sa systémová premenná&nbsp;<a href="ms-its:ACAD_ACR.chm::/PSTYLEMODE.htm" target="_blank" rel="nofollow"><FONT color=#0000ff>PSTYLEMODE</FONT></A>&nbsp;1 = named, 0 = color-dependent</DIV></td></tr></table><DIV></DIV><img src="http://www.cadforum.cz/forum/smileys/smiley32.gif" height="17" width="18" border="0" align="absmiddle" alt="Clap" />&nbsp;Díky]]>
   <pubDate>Fri, 06 Mar 2009 14:37:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41730&amp;title=problem-s-tlacou#41730</guid>
   <title><![CDATA[problem s tlacou : _CONVERTPSTYLES nastav&#237; sa syst&#233;mov&#225;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41729&amp;title=problem-s-tlacou#41729</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 8228<br /><strong>Zasláno:</strong> 06.bře.2009 v 14:19<br /><br /><P><FONT style="COLOR: black; : yellow">_CONVERT</FONT>PSTYLES</P><DIV>nastaví sa systémová premenná&nbsp;<a href="ms-its:ACAD_ACR.chm::/PSTYLEMODE.htm" target="_blank" rel="nofollow"><FONT color=#0000ff>PSTYLEMODE</FONT></A>&nbsp;1 = named, 0 = color-dependent</DIV>]]>
   <pubDate>Fri, 06 Mar 2009 14:19:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41729&amp;title=problem-s-tlacou#41729</guid>
   <title><![CDATA[problem s tlacou : Pravdepodobne m&#225;te vo v&#253;krese...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41728&amp;title=problem-s-tlacou#41728</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 8228<br /><strong>Zasláno:</strong> 06.bře.2009 v 14:17<br /><br />Pravdepodobne máte vo výkrese definovanú tlač použitím *.stb<DIV>Ak áno, tak si ju prekonvertujte na ctb.</DIV>]]>
   <pubDate>Fri, 06 Mar 2009 14:17:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41728&amp;title=problem-s-tlacou#41728</guid>
   <title><![CDATA[problem s tlacou : z nekjakych dovodov mi v tabulke...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41709&amp;title=problem-s-tlacou#41709</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9044">jan.anjel</a><br /><strong>Předmět:</strong> 8228<br /><strong>Zasláno:</strong> 06.bře.2009 v 11:31<br /><br />z nekjakych dovodov mi v tabulke stylov vykreslovania (plot style table) "zmizli" vsetky styli... neviem ako ich znovu nacitat. malo by ist o subory *.ctb aspon si myslim no nikde ich neviem najst. V prilohe su oznacene z druhej instalacie kde su v poriadku nacitane. Ma s tymto niekto skusenost?<br />nedari sa mi korektne zadat odkaz na obrazok preto je adresa v apostrofoch- prepacte, nie je to reklama<br />"fotky.sme.sk/fotka/57531/priradenie-pier"<span style="font-size:10px"><br /><br />Upravil jan.anjel - 06.bře.2009 v 11:37</span>]]>
   <pubDate>Fri, 06 Mar 2009 11:31:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8228&amp;PID=41709&amp;title=problem-s-tlacou#41709</guid>
