  <title>CAD F&#243;rum : HP DJ500ps - driver</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD hardware : HP DJ500ps - driver]]></description>
  <pubDate>Wed, 28 Oct 2026 03:11:27 +0000</pubDate>
  <lastBuildDate>Thu, 07 May 2009 09:36:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=8595</WebWizForums:feedURL>
   <title><![CDATA[HP DJ500ps - driver : V&#271;aka v&#353;etk&#253;m,u&#382; to chod&#237; ako...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43655&amp;title=hp-dj500ps-driver#43655</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 07.kvě.2009 v 09:36<br /><br />Vďaka všetkým,<br>už to chodí ako má. tem wumpclen to vyriešil.<br>]]>
   <pubDate>Thu, 07 May 2009 09:36:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43655&amp;title=hp-dj500ps-driver#43655</guid>
   <title><![CDATA[HP DJ500ps - driver : Vdaka.presne tak&#253;to subor som...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43646&amp;title=hp-dj500ps-driver#43646</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 07.kvě.2009 v 08:47<br /><br />Vdaka.<br>presne takýto subor som googlil na hp stránkach a nenasiel som nic...<br>este raz vdaka<br>]]>
   <pubDate>Thu, 07 May 2009 08:47:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43646&amp;title=hp-dj500ps-driver#43646</guid>
   <title><![CDATA[HP DJ500ps - driver : http://h20000.www2.hp.com/bizs...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43644&amp;title=hp-dj500ps-driver#43644</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 07.kvě.2009 v 08:21<br /><br /><a href="http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDe&#115;cripti&#111;n.jsp?lang=en&cc=us&swItem=pl-44400-3&jumpid=reg_R1002_USEN" target="_blank" rel="nofollow">http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&amp;cc=us&amp;swItem=pl-44400-3&amp;jumpid=reg_R1002_USEN</A>]]>
   <pubDate>Thu, 07 May 2009 08:21:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43644&amp;title=hp-dj500ps-driver#43644</guid>
   <title><![CDATA[HP DJ500ps - driver :    Mantl&#237;k napsal(a):V HP DJ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43640&amp;title=hp-dj500ps-driver#43640</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 20:39<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Mantlík" alt="Původně odeslal(a) Mantlík" style="vertical-align: text-bottom;" /> <strong>Mantlík napsal(a):</strong><br /><br />V HP DJ 500PS je nebo není HPGL/2 karta? (už si to nepamatuji. máme HP800 pod W2000/XP) Pokud není, tak asi nic jiného, než ten"...wumpclen" nebude (aspoň jsem nic nenašel), možná bude mít někdo něco staršího ....</td></tr></table><br><br>Ale ten "hpdj500800wumpclen.exe" nikde nenachádzam...<br>]]>
   <pubDate>Wed, 06 May 2009 20:39:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43640&amp;title=hp-dj500ps-driver#43640</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43635&amp;title=hp-dj500ps-driver#43635</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 19:49<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Mantlík" alt="Původně odeslal(a) Mantlík" style="vertical-align: text-bottom;" /> <strong>Mantlík napsal(a):</strong><br /><br />V HP DJ 500PS je nebo není HPGL/2 karta? (už si to nepamatuji. máme HP800 pod W2000/XP) Pokud není, tak asi nic jiného, než ten"...wumpclen" nebude (aspoň jsem nic nenašel), možná bude mít někdo něco staršího ....</td></tr></table><br><br>Nie, karta HPGL/2 tam nie je...<br>]]>
   <pubDate>Wed, 06 May 2009 19:49:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43635&amp;title=hp-dj500ps-driver#43635</guid>
   <title><![CDATA[HP DJ500ps - driver : V HP DJ 500PS je nebo nen&#237; HPGL/2...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43634&amp;title=hp-dj500ps-driver#43634</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 18:31<br /><br />V HP DJ 500PS je nebo není HPGL/2 karta? (už si to nepamatuji. máme HP800 pod W2000/XP) Pokud není, tak asi nic jiného, než ten"...wumpclen" nebude (aspoň jsem nic nenašel), možná bude mít někdo něco staršího ....]]>
   <pubDate>Wed, 06 May 2009 18:31:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43634&amp;title=hp-dj500ps-driver#43634</guid>
   <title><![CDATA[HP DJ500ps - driver : PROS&#205;M, m&#244;&#382;e mi niekto poveda&#357;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43629&amp;title=hp-dj500ps-driver#43629</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 17:14<br /><br />PROSÍM, môže mi niekto povedať ktorý driver mám použiť pre plotter HPDesignjet500ps, model C7770C, 42 palcový. Po hľadaniach na HP stránkachsom našiel toto: hpdj500800wumglen.exe, hpdj510wumglen.exe Ak sa donich pozriem, ani jeden z nich priamo nepodporuje spomínaný plotter.(sú tam síce 500ps ale len + HPGL2 Card a potom este 500ps Plus 42".Lenže ja mám iba obyčajný 500ps (...prehltol by som ešte eventuelne500ps in Rol 42") Potom som našiel ešte hpdj500800wumpcltc.exe - tensom na začiatku nainštaloval, čo bola zrejme chyba...tlačiť tlačí, alenedá sa vôbec čítať záložka Printing preferencies....namiestolatinských textov sú tam háky báky...Preinštalovanie nepomáha, pamätási stále ten starý. Vymazal som mu súbory driveru zo systému a sompripravený znova inštalovať, ale ten správny driver. Ale ktorý to je,to si už netrúfam povedať...<img src="https://www.cadforum.cz/forum/smileys/smiley19.gif" border="0" align="absmiddle" alt="Cry" /><img src="https://www.cadforum.cz/forum/smileys/smiley5.gif" border="0" align="absmiddle" alt="C&#111;nfused" /><img src="https://www.cadforum.cz/forum/smileys/smiley7.gif" border="0" align="absmiddle" alt="Angry" /><br>Vopred ďakujem za info.]]>
   <pubDate>Wed, 06 May 2009 17:14:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43629&amp;title=hp-dj500ps-driver#43629</guid>
   <title><![CDATA[HP DJ500ps - driver :    J.Richter napsal(a):Dobr&#253;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43617&amp;title=hp-dj500ps-driver#43617</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 08:45<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) J.Richter" alt="Původně odeslal(a) J.Richter" style="vertical-align: text-bottom;" /> <strong>J.Richter napsal(a):</strong><br /><br />Dobrý den, instaloval jste správnou jazykovou verzi ovladače?</td></tr></table><br><br>Ovládač som stiahol z HP webstránky...vybral som angličtinu...názov stiahnuteho súboru je "hpdj500800wumpclen.exe". Je to samorozbaľovací súbor...<img src="https://www.cadforum.cz/forum/smileys/smiley19.gif" border="0" align="absmiddle" alt="Cry" /><br>Môžem touto cestou poprosiť niekoho kto prevádzkuje HPDJ500ps pod WXP32 či by mi mohol poslať link alebo rovno driver ktory je 100% v poriadku?<br>Ďakujem<br><br><br><br>]]>
   <pubDate>Wed, 06 May 2009 08:45:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43617&amp;title=hp-dj500ps-driver#43617</guid>
   <title><![CDATA[HP DJ500ps - driver : Dobr&#253; den, instaloval jste spr&#225;vnou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43614&amp;title=hp-dj500ps-driver#43614</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9075">J.Richter</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 06.kvě.2009 v 08:36<br /><br />Dobrý den, instaloval jste správnou jazykovou verzi ovladače?]]>
   <pubDate>Wed, 06 May 2009 08:36:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43614&amp;title=hp-dj500ps-driver#43614</guid>
   <title><![CDATA[HP DJ500ps - driver : Pekn&#253; de&#328;,k&#250;pil som star&#353;&#237; HP...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43608&amp;title=hp-dj500ps-driver#43608</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 8595<br /><strong>Zasláno:</strong> 05.kvě.2009 v 23:54<br /><br />Pekný deň,<br>kúpil som starší HP DJ500ps. Tlačí, ale pri tlačení sa mi na záložkách objavujú haky baky...myslím že driver mám správny, OS je XP32 a ten je myslím nastavený tiež správne...Tuší niekto v čom môže byť problém?<br>Vďaka.<br><br><img src="uploads/20090505_235350_HP_DJ500-driver.jpg" height="489" width="503" border="0" /><br>]]>
   <pubDate>Tue, 05 May 2009 23:54:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8595&amp;PID=43608&amp;title=hp-dj500ps-driver#43608</guid>
