  <title>CAD F&#243;rum : jak udelat z ipt dxf?</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : jak udelat z ipt dxf?]]></description>
  <pubDate>Mon, 03 Aug 2026 23:41:54 +0000</pubDate>
  <lastBuildDate>Tue, 07 Jul 2009 14:18:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=8906</WebWizForums:feedURL>
   <title><![CDATA[jak udelat z ipt dxf? : dik.  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44906&amp;title=jak-udelat-z-ipt-dxf#44906</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=5788">kubes0000</a><br /><strong>Předmět:</strong> 8906<br /><strong>Zasláno:</strong> 07.čvc.2009 v 14:18<br /><br />dik.]]>
   <pubDate>Tue, 07 Jul 2009 14:18:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44906&amp;title=jak-udelat-z-ipt-dxf#44906</guid>
   <title><![CDATA[jak udelat z ipt dxf? : Vytvo&#345;te si v&#253;kres a potom pou&#382;ijte...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44905&amp;title=jak-udelat-z-ipt-dxf#44905</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4272">Lukas.H</a><br /><strong>Předmět:</strong> 8906<br /><strong>Zasláno:</strong> 07.čvc.2009 v 14:07<br /><br />Vytvořte si výkres a potom použijte příkaz "Uložit kopii jako". vyberte formát DXF.]]>
   <pubDate>Tue, 07 Jul 2009 14:07:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44905&amp;title=jak-udelat-z-ipt-dxf#44905</guid>
   <title><![CDATA[jak udelat z ipt dxf? : dobry den ,v inventore si nakreslim...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44904&amp;title=jak-udelat-z-ipt-dxf#44904</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=5788">kubes0000</a><br /><strong>Předmět:</strong> 8906<br /><strong>Zasláno:</strong> 07.čvc.2009 v 14:02<br /><br />dobry den ,<br><br>v inventore si nakreslim suciastku vo formate ipt, a potrebujem z nej urobit dfx format aby som ju mohol dostat na CNC plazmu, <br><br>dakujem za opoved . <br>]]>
   <pubDate>Tue, 07 Jul 2009 14:02:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=8906&amp;PID=44904&amp;title=jak-udelat-z-ipt-dxf#44904</guid>
