  <title>CAD F&#243;rum : Civil 3D, Map, InfraWorks, GIS</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Civil 3D, Map, InfraWorks, GIS : Poslední 10 Příspěvky]]></description>
  <pubDate>Fri, 06 Nov 2026 13:55:50 +0000</pubDate>
  <lastBuildDate>Thu, 10 Sep 2026 06:55:08 +0000</lastBuildDate>
  <ttl>30</ttl>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_topic_feed.asp?FID=7</WebWizForums:feedURL>
   <title><![CDATA[Civil 3D, Map, InfraWorks, GIS : Šablona pro VFK2DWG]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131883&amp;title=sablona-pro-vfk2dwg#131883</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1207">_vlk</a><br /><strong>Předmět:</strong> Šablona pro VFK2DWG<br /><strong>Zasláno:</strong> 10.zář.2026 v 06:55<br /><br />Děkuji!]]>
   <pubDate>Thu, 10 Sep 2026 06:55:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131883&amp;title=sablona-pro-vfk2dwg#131883</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131881&amp;title=sablona-pro-vfk2dwg#131881</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36651">spackovaE</a><br /><strong>Předmět:</strong> Šablona pro VFK2DWG<br /><strong>Zasláno:</strong> 09.zář.2026 v 16:55<br /><br />Dobrý den,<br />šablonu přikládám ke stažení.<br />Pěkný den!]]>
   <pubDate>Wed, 09 Sep 2026 16:55:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131881&amp;title=sablona-pro-vfk2dwg#131881</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131879&amp;title=sablona-pro-vfk2dwg#131879</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36651">spackovaE</a><br /><strong>Předmět:</strong> Šablona pro VFK2DWG<br /><strong>Zasláno:</strong> 09.zář.2026 v 16:54<br /><br /><a href="uploads/36651/VFK2DWGTemplate.zip" target="_blank" rel="nofollow">VFK2DWGTemplate.zip</a>]]>
   <pubDate>Wed, 09 Sep 2026 16:54:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131879&amp;title=sablona-pro-vfk2dwg#131879</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131878&amp;title=sablona-pro-vfk2dwg#131878</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1207">_vlk</a><br /><strong>Předmět:</strong> Šablona pro VFK2DWG<br /><strong>Zasláno:</strong> 09.zář.2026 v 13:24<br /><br />Dobrý den,<div>kde najdu šablonu výkresu pro import katastrální mapy pomocí VFK2DWG (Dopravák)?</div>]]>
   <pubDate>Wed, 09 Sep 2026 13:24:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36017&amp;PID=131878&amp;title=sablona-pro-vfk2dwg#131878</guid>
   <title><![CDATA[Civil 3D, Map, InfraWorks, GIS : Rozdíl mezi tmavým a světlým zobrazením]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131871&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131871</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> Rozdíl mezi tmavým a světlým zobrazením<br /><strong>Zasláno:</strong> 07.zář.2026 v 15:23<br /><br /><div>Jako vždy - trefa do černého.&nbsp;</div><div>Díky</div>]]>
   <pubDate>Mon, 07 Sep 2026 15:23:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131871&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131871</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131870&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131870</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> Rozdíl mezi tmavým a světlým zobrazením<br /><strong>Zasláno:</strong> 07.zář.2026 v 15:03<br /><br />Možná se jen chybně překompilovaly grafické prvky z CUIx. Zkuste smazat soubor <i>map.mnr</i> ve složce Support:<div><i>"c:\Users\USERNAME\AppData\Roaming\Autodesk\PRODUCTNAME 2027\csy\Support"</i></div><div>a spustit znovu.</div><div>(pokud to tedy v tom světlém bylo v p]]>
   <pubDate>Mon, 07 Sep 2026 15:03:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131870&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131870</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131868&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131868</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> Rozdíl mezi tmavým a světlým zobrazením<br /><strong>Zasláno:</strong> 07.zář.2026 v 11:27<br /><br /><div>Zdravím</div><div>Možná to je prkotina, ale dosud jsem se s tím nesetkal ...</div><div>Nainstaloval jsem kolegyni Autocad Mapú 2027 a "zútulnil" (nastavil a doplnil) jsem ho , jak je tu obvyklé, včetně panelu rychlého přístupu (tj. nahoře) a stavového řádku dole).</div><di]]>
   <pubDate>Mon, 07 Sep 2026 11:27:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36013&amp;PID=131868&amp;title=rozdil-mezi-tmavym-a-svetlym-zobrazenim#131868</guid>
   <title><![CDATA[Civil 3D, Map, InfraWorks, GIS : CIVIL TOOLS 2027]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36008&amp;PID=131862&amp;title=civil-tools-2027#131862</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=36651">spackovaE</a><br /><strong>Předmět:</strong> CIVIL TOOLS 2027<br /><strong>Zasláno:</strong> 02.zář.2026 v 12:10<br /><br />Dobrý den,<br />aplikace Dopravák (nástupce Civil Tools) pro C3D 2027 byl vydán a je ke stažení zde help.arkance-systems.com<br />Eliška Špačková]]>
   <pubDate>Wed, 02 Sep 2026 12:10:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36008&amp;PID=131862&amp;title=civil-tools-2027#131862</guid>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36008&amp;PID=131861&amp;title=civil-tools-2027#131861</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=37440">marko10</a><br /><strong>Předmět:</strong> CIVIL TOOLS 2027<br /><strong>Zasláno:</strong> 01.zář.2026 v 20:37<br /><br />Dobrý den, po sdělení ukončení aplikace vfk2dwg jako samosatné aplikace, prosím o termínu uvedení CIVIL Tools 2027.<br /><br />Děkuji<br />Marko Szabó]]>
   <pubDate>Tue, 01 Sep 2026 20:37:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36008&amp;PID=131861&amp;title=civil-tools-2027#131861</guid>
   <title><![CDATA[Civil 3D, Map, InfraWorks, GIS : Rychlé stínování není dostupné]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=36000&amp;PID=131837&amp;title=rychle-stinovani-neni-dostupne#131837</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=120">KMachálek</a><br /><strong>Předmět:</strong> Rychlé stínování není dostupné<br /><strong>Zasláno:</strong> 10.srp.2026 v 17:04<br /><br />Díky moc, bylo to tou grafikou notebooku. Už to funguje.]]>
   <pubDate>Mon, 10 Aug 2026 17:04:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=36000&amp;PID=131837&amp;title=rychle-stinovani-neni-dostupne#131837</guid>
