Uveden SP1 pro AutoCAD Architecture 2012
Název fóra: Architecture, MEP, Fabrication, Plant 3D
Popis fóra: Otázky ke stavařským aplikacím AutoCAD Architecture, AutoCAD MEP, k potrubní aplikaci AutoCAD Plant 3D, k Fabrication a Advance Steel
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=13592
Datum vytištění: 08.říj.2026 v 01:11
Téma: Uveden SP1 pro AutoCAD Architecture 2012
Předmět: Uveden SP1 pro AutoCAD Architecture 2012
Datum odeslání: 20.zář.2011 v 16:01
Service Pack 1 pro AutoCAD Architecture 2012 (všechny varianty) je ke stažení na stránce Download, viz též:
http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2012-tip8195 - http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2012-tip8195
Přehled oprav:
The following defects have been fixed:
Drawing Manager
  • Selecting a sheet with a long name may cause unexpected behavior in AutoCAD Architecture.
  • Opening a project with a large number of files in a 64-bit machine may cause AutoCAD Architecture to crash.
IFC
  • Space containment does not work on a 64-bit operating system.
Multi-View Block
  • Exporting multi-view blocks to AutoCAD may result in an incorrect size.
Profile
  • Some AEC ARX files are loaded when running AutoCAD Architecture with an AutoCAD profile.
Renovation
  • Renovation function fails when you add a door or window object during renovation mode.
  • Sometimes the renovation toggle remains enabled even after exiting the renovation mode.
Section
  • Building geometry may change after you activate and then disable the live section.
  • Roof or roof cap solid hatch might be displayed in section incompletely.
Space/Zone
  • Some merged space area are calculated incorrectly.
  • When the unit area is inconsistent with its unit length, the calculated space area might be inaccurate.
Structural Member
  • Adjusting column grid can cause beams to lose connection with the columns.
Tag
  • Adding tags for doors on multiple reference copies may cause unexpected behavior in AutoCAD Architecture.
Wall
  • REPOSITIONALONG command does not work for doors and windows.
  • Running the JOIN command on two connected walls may cause unexpected behavior in AutoCAD Architecture.
  • When you offset a wall using another wall with the same direction as the reference, the offset wall may be created in the opposite direction.
  • The Below Cut Plan display component of doors or window may not display.
Plus obsah SP1 pro holý AutoCAD 2012.
