Problem s instalaci Invertoru 10 na WIN7
Název fóra: Inventor
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=14240
Datum vytištění: 02.lis.2026 v 02:26
Téma: Problem s instalaci Invertoru 10 na WIN7
Odeslal: zelwa
Předmět: Problem s instalaci Invertoru 10 na WIN7
Datum odeslání: 08.led.2012 v 13:36
Zdravim,
 mam problem s instalaci Invertoru 10 na WIN7 /64bit vezi.  Jak jsem zde na foru nasel uz zde bylo reseno a nekolik typu, ktere my pomohli, ale nastal jeden problem, ktery tady nikdo neresil. Pri probyhajici instalaci skoro u konce instalace, kdy probyha aktualizace systemu - zapis hodnot do systemovych registru nastane tenhle problem:
Chyba 1406. Nelze zapsat hodnotu do klice \Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Implemented Categories\{7DD95801-9882-11CF-9FA9-00AA006C42C4}. Presvedcte se, ze mate ke klici dostatecny pristup, nebo se obratte na pracovniky odborne pomoci.
dale pripojuji Autodesk Inventor 10 Setup.log:
[1/8/2012 11:46:46] === Installation started on USER-PC by UseR ===
[1/8/2012 11:46:46] [Info] Windows Installer upgrade is not required
[1/8/2012 11:46:46] System Version = 5.0.7601.17514
[1/8/2012 11:46:46] Installation skipped: MSI Runtime 3.0
[1/8/2012 11:46:46] [Info] .NET Framework Runtime upgrade is not required
[1/8/2012 11:46:46] System Version = 4.0.40305.0
[1/8/2012 11:46:46] Installation skipped: .NET Framework Runtime 1.1
[1/8/2012 11:46:46] Installation skipped: .NET Framework Runtime 1.1 SP1
[1/8/2012 11:46:46] [Info] MDAC upgrade is not required
[1/8/2012 11:46:46] System Version = 6.1.7601.17514
[1/8/2012 11:46:46] Installation skipped: MDAC 2.7
[1/8/2012 11:46:46] Installation skipped: Microsoft WSE 2.0 Runtime
[1/8/2012 11:46:46] Installation started: Autodesk Inventor 10
[1/8/2012 11:46:46] Command = msiexec /i D:\inv1_series10\bin\acadfeui\Inventor.msi /L*v C:\Users\UseR\AppData\Local\Temp\AIS10Install.log
[1/8/2012 11:55:29] [Error: 1603] Při instalaci došlo k závažné chybě.
[1/8/2012 11:55:29] Installation failed: Autodesk Inventor 10
[1/8/2012 11:55:29] Installation aborted
[1/8/2012 11:55:32] === Installation ended ===
Prosim zkuzte my prosim poradit co stim, mozna je to jenom banalitka o ktere nevim.
Datum odeslání: 08.led.2012 v 14:53
Ano, je to banalita. Inventor 10 (z roku 2005) prostě není kompatibilní s operačním systémem uvedeným v roce 2009.
Pro Win7 64 potřebujete alespoň Inventor 2010 - viz:
http://www.cadforum.cz/cadforum/qaID.asp?tip=5531 - http://www.cadforum.cz/cadforum/qaID.asp?tip=5531
