Tak tentokrát již oficiální release SP2 (zatím pro Architecture a MEP 2013), včetně 32-bitové verze. Viz stránka Download.
Přehled oprav v SP2:
Improvements made in Update 2 build (20121003_2115): Autodesk® Revit® Architecture 2013 Enhancements Improves stability when upgrading 2012 project which contains analytical walls. Improves stability when adjusting multiple sketch lines of a floor at the same moment. Improves stability when editing the gutters on a roof object with the Add/Remove Segment tool. Improves stability when renaming a Stair run type or landing to ‘none’. Improves stability when using the ribbon Cancel Edit Mode button to exit Stair Edit Mode. Improves stability when using an open profile for a wall sweep. Improves stability when splitting a wall. Autodesk® Revit® Platform 2013 Enhancements Improves stability when Save to Central or Sync with Central. Improves stability when utilizing Create Assembly Views from the project browser. Improves stability when editing a label within the family editor. Improves stability when saving file to a location with low disc space. Improves stability when launching Export gbXML – Settings dialog. Improves stability and memory usage within graphics display. Improves stability during IFC data import which contains openings with no usable geometry. Improves stability when importing IFC data which imported into Revit 2012 with warnings. Improves import of clipped solids during IFC import. Improves IFC Export to support buildingSMART International IFC certification. Improves stability when linking or attached DWG files. Improves stability of printing after Export to DWG or DXF format. Improves stability when creating, duplicating or deleting a material in the Material Editor. Improves the retention of part parameters within a part upgraded from Revit 2012. Corrects ribbon tab population after installing .NET 4.5 Improves stability while editing calculated values within a schedule after deleting a parameter used in a formula. Improves stability with schedules which contains a filter based upon a user defined parameter and elements in linked files do not contain the user defined parameter. Improves stability when opening Sun Settings dialog. Improves stability when editing Text Notes. Improves stability when upgrading Revit 2012 project to Revit 2013. Improves stability when moving a Crop Region which utilizes the disjoin option
