Data Integrity Hotfix pro AutoCAD Plant 3D 2013
Název fóra: Architecture, MEP, Fabrication, Plant 3D
Popis fóra: Otázky ke stavařským aplikacím AutoCAD Architecture, AutoCAD MEP, k potrubní aplikaci AutoCAD Plant 3D, k Fabrication a Advance Steel
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=16726
Datum vytištění: 09.říj.2026 v 02:16
Téma: Data Integrity Hotfix pro AutoCAD Plant 3D 2013
Odeslal: statecny
Předmět: Data Integrity Hotfix pro AutoCAD Plant 3D 2013
Datum odeslání: 27.úno.2013 v 08:33
Byl uveden Data Integrity Hotfix pro AutoCAD Plant 3D 2013 a AutoCAD P&ID 2013 s SP1.
Hotfix stahujte na stránkách Autodesku:
Pro Plant 3D 2013: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21194788&linkID=14116968" rel="nofollow - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21194788&linkID=14116968
Pro AutoCAD P&ID: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21195589&linkID=11705366" rel="nofollow - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21195589&linkID=11705366
Seznam oprav:
3D Model
  • Modifying staircase step data occasionally causes the program to shut down unexpectedly.
  • If a block that contains piping is inserted into a non-project drawing, a recovery error message displays when the non-project drawing is opened.
Data Properties
  • Plant data in project drawings occasionally does not save properly. Data loss can occur when working with custom classes, if a drawing is removed and added again, or when modifying referenced (XREF) drawings.
P&ID Drawings
  • The exporttoautocad command breaks acquisition rules.
Isometric Drawings
  • Properties added to end connections (CONT'D ON) do not display in the isometric drawing.
Spec Editor
  • The Spec editor requires Admin rights to modify a piping spec or catalog.
    Note: With this hotfix applied, you are not required to have admin rights to modify a piping spec or catalog. However, other Spec Editor features do require that you run the Spec Editor with admin rights (using Run as administrator). For example, admin rights are required to modify the shared content folder or to edit description styles
Václav Statečný
Arkance Systems CZ s.r.o.
